Home » Modeling » TMF (Xtext) » Grammar problem (newbie)
Grammar problem (newbie) [message #757605] Sun, 20 November 2011 05:23 Go to next message
I have the following rule in a reasonably complex grammar that I am porting from ANTLR
BidPriority: PRIORITY priorityLevel=INT;
PRIORITY: 'p';
This matches p 1, but won't match p1.
Is there any way I can match p1?
Re: Grammar problem (newbie) [message #757607 is a reply to message #757605] Sun, 20 November 2011 05:38 Go to previous messageGo to next message
i guess you have to use a terminal rule for this (plus a valueconverter that gives you the int part of the whole stuff)
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
BidPriority: priorityLevel=PRIORITY;
terminal PRIORITY returns ecore::EInt: 'p' ('0'..'9')+;
public class MyDslRuntimeModule extends org.xtext.example.mydsl2.AbstractMyDslRuntimeModule {
	public Class<? extends IValueConverterService> bindIValueConverterService() {
		return MyDslValueConverterService.class;
public class MyDslValueConverterService extends DefaultTerminalConverters {
	@ValueConverter(rule = "PRIORITY")
	public IValueConverter<Integer> PRIORITY() {
		return new IValueConverter<Integer>() {
			public Integer toValue(String string, INode node)
					throws ValueConverterException {
				return Integer.valueOf(string.substring(1));
			public String toString(Integer value)
				return "p" + value.toString();
if you want to use something like p1 at a place you would use and id
you have to introduce a datatype rule for this
Stuff: ID | PRIORITY;
stuff=Stuff
~Christian
Re: Grammar problem (newbie) [message #757610 is a reply to message #757605] Sun, 20 November 2011 05:45 Go to previous messageGo to next message
p1 is matched by the ID rule. It is hard to say what the best option would be for your use case. Possibly a data type rule with a value converter.
That way you would not have to introduce "unnecessary" keywords.
Bipriority: priorityLevel=Priority;
Priority returns ecore::EInt: ID;
And a value converter for Priority that throws a value conversion exception if the format is not p<Number> and extracts the number.
Alex
Re: Grammar problem (newbie) [message #757814 is a reply to message #757610] Mon, 21 November 2011 14:22 Go to previous message
Christian/Alex,
Many thanks for the replies - As I have control of the grammar I have decided to introduce a # so I can define the priority e.g. p#1 which I can manage through a terminal. However, it is good to know that I can revert back to my original syntax, which I may well do once I have got the grammar fully ported.
John
Previous Topic:understanding ImportManager
Next Topic:How i load resources dynamically
Current Time: Sat Jul 26 10:23:05 EDT 2025
Powered by FUDForum. Page generated in 0.03883 seconds
