Home » Modeling » TMF (Xtext) » How to add attributes to an abstract component
How to add attributes to an abstract component [message #757582] Sat, 19 November 2011 16:18 Go to next message
hi,
I would like to add an "element property" to my abstract component.
Because every component needs the element properties. How can I accomplish this?
Component:
	 Textfield | TextArea | Label
Label:
	'label' name=ID '{' text=STRING properties=ElementProperties?'}'
Textfield:
	'textfield' name=ID '{' text=STRING properties=ElementProperties?'}'
TextArea:
	'textarea' name=ID '{' 'sizeX' sizeX = INT & 'sizeY' sizeY = INT properties=ElementProperties?'}'
I don't want to do this for each component:
	«IF (b.properties.colspan != null)»
	    		«b.name»Constraint.gridwidth = «b.properties.colspan»;
	    	«ENDIF»
	    	«IF (b.properties.rowspan != null)»
	    		«b.name»Constraint.gridheight = «b.properties.rowspan»;
	    	«ENDIF»
	    	«IF (b.properties.alignment != null)»
	    		«b.name»Constraint.fill = «b.name»Constraint«b.properties.alignment»;
	    	«ENDIF»
regards,
jens
Re: How to add attributes to an abstract component [message #757586 is a reply to message #757582] Sat, 19 November 2011 16:53 Go to previous messageGo to next message
i do not get your problem. your component eclass gets a name and a properties
so this happens automatically. at least with the grammar you shared.
~Christian
Re: How to add attributes to an abstract component [message #757587 is a reply to message #757586] Sat, 19 November 2011 17:05 Go to previous messageGo to next message
hi Christian,
sorry I didn't get that: "your component eclass gets a name and a properties
so this happens automatically"
I wanted to do something like this. Could you give me an example please.
  def setProperties(Component c) '''
	«IF (c.properties.colspan != null)»
    		«c.name»Constraint.gridwidth = «c.properties.colspan»;
    	«ENDIF»
    	«IF (c.properties.rowspan != null)»
    		«c.name»Constraint.gridheight = «c.properties.rowspan»;
    	«ENDIF»
    	«IF (c.properties.alignment != null)»
    		«c.name»Constraint.fill = «c.name»Constraint«c.properties.alignment»;
    	«ENDIF»
so that I don't have to do it for all my components:..
    def dispatch compile (Button b, Panel p) '''
    	JButton «b.name» = new JButton("«b.text»");
    	«IF (b.actionmessage!=null)»
    	«b.name».addActionListener(new ActionListener() {
    	public void actionPerformed(ActionEvent e) {
    		JOptionPane.showMessageDialog(null,"«b.actionmessage»");
		«ENDIF»
		«IF (b.properties != null)»
    		GridBagConstraints «b.name»Constraint = new GridBagConstraints();
	    	«b.name»Constraint.gridx = «b.properties.position.gridX»;
	    	«b.name»Constraint.gridy = «b.properties.position.gridY»;
	    	«p.name».add(«b.name», «b.name»Constraint);
	    	«ENDIF»
	    	«ENDIF»
	    	«ENDIF»
    	«ELSE»
    		«p.name».add(«b.name»);
    	«ENDIF»
    	«c.eClass.» ?????????
regards,
jens
[Updated on: Sat, 19 November 2011 17:09] by Moderator
Re: How to add attributes to an abstract component [message #757588 is a reply to message #757587] Sat, 19 November 2011 17:08 Go to previous messageGo to next message
as i said: this works with the grammar you shared!!!!!
here is the metamodel generated
  <eClassifiers xsi:type="ecore:EClass" name="Component">
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="name" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="properties" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
  </eClassifiers>
~Christian
Re: How to add attributes to an abstract component [message #757589 is a reply to message #757588] Sat, 19 November 2011 17:22 Go to previous messageGo to next message
see http://www.eclipse.org/Xtext/documentation/2_1_0/020-grammar-language.php#metamodelInference_4 too
Re: How to add attributes to an abstract component [message #757591 is a reply to message #757588] Sat, 19 November 2011 18:01 Go to previous messageGo to next message
hi Christian,
I am sorry. I missed "properties=ElementProperties?"
in one of my components. Now it works. Thanks.
But I have still one question:
A construct like this is not possible?
(The advantage of this would be, that I don't have to write
"properties=ElementProperties?" in each of my components.)
Component:
	 (Textfield | TextArea)
Textfield:
	'textfield' name=ID '{' text=STRING'}'
TextArea:
	'textarea' name=ID '{' 'sizeX' sizeX = INT & 'sizeY' sizeY = INT '}'
regards,
jens.
Re: How to add attributes to an abstract component [message #757592 is a reply to message #757591] Sat, 19 November 2011 18:10 Go to previous message
it actually is possible
Previous Topic:How to decide which generator to use
Next Topic:[Xtext 2.1.1][SOLVED] create custom loop scope
Current Time: Sun Jul 27 14:38:31 EDT 2025
Powered by FUDForum. Page generated in 0.03768 seconds
