Home » Archived » BIRT » Dynamic parameter properties
Dynamic parameter properties [message #757572] Sat, 19 November 2011 10:51 Go to next message
Is there a way to dynamically change some of the properties of a parameter?
For example, I want to be able to change the value of the property "Is required" on one of my parameters.
This is because I only want parameter B to be required if parameter A != a certain value.
More specifically, I would like to do something like this..
var paramValue = reportContext.getParameterValue("ImpactAssessmentType"); //report parameter
if (paramValue == "(Show All)") // if 'Show All' was selected
        ii = -1;
        // change param2's "Is required" property to false
else
        ii = 0;
        // leave param2's "Is required" property alone
Re: Dynamic parameter properties [message #757577 is a reply to message #757572] Sat, 19 November 2011 14:54 Go to previous messageGo to next message
180 views and no help? I thought this would be pretty standard. Any help please?
[Updated on: Mon, 21 November 2011 12:46] by Moderator
Re: Dynamic parameter properties [message #757841 is a reply to message #757577] Mon, 21 November 2011 13:48 Go to previous messageGo to next message
You can change parameters before the report is opened in the viewer, but
once it is opened the viewer will initiate the parameter dialog and it
is to late to change the values. You may be able to use a custom
parameter page using the BIRT tag libraries and some script to implement
a custom page to do this.
http://birtworld.blogspot.com/2007/09/22-birt-tag-library-building-custom.html
Jason
Re: Dynamic parameter properties [message #758119 is a reply to message #757841] Mon, 21 November 2011 18:28 Go to previous messageGo to next message
Hmm ok, maybe something that should be added to BIRT, seems like other people would want to do this too. Thanks.
Re: Dynamic parameter properties [message #758120 is a reply to message #758119] Mon, 21 November 2011 18:29 Go to previous messageGo to next message
Sorry trying to get the 5 posts so i can post an image in a different thread.
[Updated on: Mon, 21 November 2011 18:29] by Moderator
Re: Dynamic parameter properties [message #758121 is a reply to message #758120] Mon, 21 November 2011 18:29 Go to previous messageGo to next message
Re: Dynamic parameter properties [message #758311 is a reply to message #758119] Tue, 22 November 2011 12:04 Go to previous message
Can you open a bugzilla request for this?
Jason
Previous Topic:Embedding a datasource in the rptdesign file?
Next Topic:Cannot open connection
Current Time: Fri Jul 25 08:37:00 EDT 2025
Powered by FUDForum. Page generated in 0.29068 seconds
