GMF editor doesn't draw nodes [message #757365] |
Thu, 17 November 2011 20:42  |
I create a ecore model and then annotated the .emf file, after that I generate the GMF Editor by right-clicking the .emf file. An error occured:
Quote:Description Resource Path Location Type
This method must return a result of type boolean KAOSStandardViewProvider.java /Kaos.diagram/src/KAOSStandard/diagram/providers line 145 Java Problem
I change that line by returning true.
Then I ran a new Eclipse instance and the editor doesn't let me create any of the nodes. Just the links, but without the nodes I cannot test them.
Any idea to what this mite be?
I don't know if is relevante but I have many nodes with polygon figures, and the coordinates that I specified in the .emf file don't appear in the .gmfgraph file.
Can anyone help me? I get several warnings, but no errors.
Re: GMF editor doesn't draw nodes [message #757502 is a reply to message #757483] |
Fri, 18 November 2011 11:34   |
I have this simple .emf file, and I get an error regarding the polygon figure. It says that polygon cannot be resolved into a type.
@namespace(uri="kaos", prefix="kaos")
package KAOSStandard;
@gmf.diagram(foo="bar")
class KAOS {
val CompartmentNode[*] hasCompartmentNode;
val Nodes[*] hasNodes;
val Links[*] hasLinks;
abstract class Links {
attr String TransformationSource;
abstract class CompartmentNode {
attr String name;
@gmf.node(label="name", label.placement="external")
abstract class Nodes {
attr String name;
attr String IstarActorContainer;
@gmf.node(color="0,191,255", border.color="0,191,255", size="80,50", figure="polygon", polygon.x="30,70,50,10", polygon.y="10,10,40,40")
class Goal extends Nodes {
attr boolean isRoot = false;
attr String formalDef;
attr String informalDef;
Re: GMF editor doesn't draw nodes [message #757869 is a reply to message #757460] |
Fri, 18 November 2011 11:48  |
It may also be helpful to actually delete the gmfgen and generated
source code (assuming you have no hand-crafted stuff in any of it at
this time) before regenerating. EMF can sometimes get a little confused
when you make changes that are too substantial :-)
Steffen
On 18/11/2011 14:10, Patr wrote:
> Acutally the problem was that I forgot to put the containment true in
> the root element of my model. But now I got this errors:
> AgentMonitors2CreationTool_desc cannot be resolved or is not a
> field KAOSStandardPaletteFactory.java
> /Kaos.diagram/src/KAOSStandard/diagram/part line 348 Java Problem
> AgentMonitors2CreationTool_title cannot be resolved or is not a
> /Kaos.diagram/src/KAOSStandard/diagram/part line 347 Java Problem
> AgentPerforms3CreationTool_desc cannot be resolved or is not a
> /Kaos.diagram/src/KAOSStandard/diagram/part line 364 Java Problem
> AgentPerforms3CreationTool_title cannot be resolved or is not a
> /Kaos.diagram/src/KAOSStandard/diagram/part line 363 Java Problem
> ConflictBtwnGoals4CreationTool_desc cannot be resolved or is not a
> /Kaos.diagram/src/KAOSStandard/diagram/part line 380 Java Problem
> ConflictBtwnGoals4CreationTool_title cannot be resolved or is not a
> /Kaos.diagram/src/KAOSStandard/diagram/part line 379 Java Problem
> GoalToOperatLink5CreationTool_desc cannot be resolved or is not a
> /Kaos.diagram/src/KAOSStandard/diagram/part line 396 Java Problem
> GoalToOperatLink5CreationTool_title cannot be resolved or is not a
> /Kaos.diagram/src/KAOSStandard/diagram/part line 395 Java Problem
> ObjectIsConcerned6CreationTool_desc cannot be resolved or is not a
> /Kaos.diagram/src/KAOSStandard/diagram/part line 412 Java Problem
> ObjectIsConcerned6CreationTool_title cannot be resolved or is not a
> /Kaos.diagram/src/KAOSStandard/diagram/part line 411 Java Problem
> RelationConnObject7CreationTool_desc cannot be resolved or is not a
> /Kaos.diagram/src/KAOSStandard/diagram/part line 428 Java Problem
> RelationConnObject7CreationTool_title cannot be resolved or is not a
> /Kaos.diagram/src/KAOSStandard/diagram/part line 427 Java Problem
> The required feature 'targetMetaFeature' of 'Type Link Model Facet'
> must be set KAOS.gmfgen /Kaos/model Unknown EMF Problem
> Validation failed unexpectedly for 'Default Size Attributes 200'. See
> log for details. KAOS.gmfgen /Kaos/model Unknown EMF Problem
> Validation failed unexpectedly for 'Default Size Attributes 40'. See
> Validation failed unexpectedly for 'Default Size Attributes 60'. See
> Validation failed unexpectedly for 'Default Size Attributes 80'. See
> Validation failed unexpectedly for 'Design Label Model Facet'. See log
> Validation failed unexpectedly for 'External Parser'. See log for
> Validation failed unexpectedly for 'Feature Label Model Facet'. See
> Does anyone know how to resolve them?
Re: GMF editor doesn't draw nodes [message #757870 is a reply to message #757502] |
Fri, 18 November 2011 12:39  |
I think, it is trying to find a polygon Java class implementing the figure.
Best,
Steffen
> class KAOS {
> attr String name;
> attr String name;
FUDForum. Page generated in 0.04305 seconds
