Home » Eclipse Projects » WindowBuilder » Does Window Builder Eclipse plugin support JavaME and AWT?
Does Window Builder Eclipse plugin support JavaME and AWT? [message #757240] Thu, 17 November 2011 05:12 Go to next message
Hi all,
I want to create a custom category that contains JavaME components and a custom category that contains custom AWT components. Is that possible to be doneadded to the Eclipse window builder plugin default palette? If so can you provide me a relevant link? Dragging and dropping components from each category to the Design view will result in creating JavaME (javax.microedition) or AWT (java.awt) complex GUIs correspondingly.
Thank you in advance.
Re: Does Window Builder Eclipse plugin support JavaME and AWT? [message #757368 is a reply to message #757240] Thu, 17 November 2011 22:17 Go to previous messageGo to next message
Have you read the docs on customizing the palette? I would suggest starting with those.
Re: Does Window Builder Eclipse plugin support JavaME and AWT? [message #757728 is a reply to message #757368] Mon, 21 November 2011 06:23 Go to previous messageGo to next message
Is it possible to create a palette that contains only javax.microedition.lcdui components?
I found and read this page:
code.google.com/javadevtools/wbpro/NewComponentsTutorial.pdf
but didn't make things clear for me.
Are there any other relevant links that could help?
I appreciate your help.
Re: Does Window Builder Eclipse plugin support JavaME and AWT? [message #757748 is a reply to message #757728] Mon, 21 November 2011 08:21 Go to previous message
You should be able to remove everything from the palette and then add back anything you want (using any categories that you want). Use the Palette Manager to do this.
Previous Topic:Custom Editor
Next Topic:debug designtime
Current Time: Fri Jul 25 23:54:59 EDT 2025
Powered by FUDForum. Page generated in 0.20944 seconds
