Home » Modeling » Epsilon » GMF editor doesn't draw nodes
GMF editor doesn't draw nodes [message #757365] Thu, 17 November 2011 20:42 Go to next message
I create a ecore model and then annotated the .emf file, after that I generate the GMF Editor by right-clicking the .emf file. An error occured:
Description Resource Path Location Type
This method must return a result of type boolean KAOSStandardViewProvider.java /Kaos.diagram/src/KAOSStandard/diagram/providers line 145 Java Problem
I change that line by returning true.
Then I ran a new Eclipse instance and the editor doesn't let me create any of the nodes. Just the links, but without the nodes I cannot test them.
Any idea to what this mite be?
I don't know if is relevante but I have many nodes with polygon figures, and the coordinates that I specified in the .emf file don't appear in the .gmfgraph file.
Can anyone help me? I get several warnings, but no errors.
Re: GMF editor doesn't draw nodes [message #757460 is a reply to message #757365] Fri, 18 November 2011 09:10 Go to previous messageGo to next message
Acutally the problem was that I forgot to put the containment true in the root element of my model. But now I got this errors:
AgentMonitors2CreationTool_desc cannot be resolved or is not a field	KAOSStandardPaletteFactory.java	/Kaos.diagram/src/KAOSStandard/diagram/part	line 348	Java Problem
AgentMonitors2CreationTool_title cannot be resolved or is not a field	KAOSStandardPaletteFactory.java	/Kaos.diagram/src/KAOSStandard/diagram/part	line 347	Java Problem
AgentPerforms3CreationTool_desc cannot be resolved or is not a field	KAOSStandardPaletteFactory.java	/Kaos.diagram/src/KAOSStandard/diagram/part	line 364	Java Problem
AgentPerforms3CreationTool_title cannot be resolved or is not a field	KAOSStandardPaletteFactory.java	/Kaos.diagram/src/KAOSStandard/diagram/part	line 363	Java Problem
ConflictBtwnGoals4CreationTool_desc cannot be resolved or is not a field	KAOSStandardPaletteFactory.java	/Kaos.diagram/src/KAOSStandard/diagram/part	line 380	Java Problem
ConflictBtwnGoals4CreationTool_title cannot be resolved or is not a field	KAOSStandardPaletteFactory.java	/Kaos.diagram/src/KAOSStandard/diagram/part	line 379	Java Problem
GoalToOperatLink5CreationTool_desc cannot be resolved or is not a field	KAOSStandardPaletteFactory.java	/Kaos.diagram/src/KAOSStandard/diagram/part	line 396	Java Problem
GoalToOperatLink5CreationTool_title cannot be resolved or is not a field	KAOSStandardPaletteFactory.java	/Kaos.diagram/src/KAOSStandard/diagram/part	line 395	Java Problem
ObjectIsConcerned6CreationTool_desc cannot be resolved or is not a field	KAOSStandardPaletteFactory.java	/Kaos.diagram/src/KAOSStandard/diagram/part	line 412	Java Problem
ObjectIsConcerned6CreationTool_title cannot be resolved or is not a field	KAOSStandardPaletteFactory.java	/Kaos.diagram/src/KAOSStandard/diagram/part	line 411	Java Problem
RelationConnObject7CreationTool_desc cannot be resolved or is not a field	KAOSStandardPaletteFactory.java	/Kaos.diagram/src/KAOSStandard/diagram/part	line 428	Java Problem
RelationConnObject7CreationTool_title cannot be resolved or is not a field	KAOSStandardPaletteFactory.java	/Kaos.diagram/src/KAOSStandard/diagram/part	line 427	Java Problem
The required feature 'targetMetaFeature' of 'Type Link Model Facet' must be set	KAOS.gmfgen	/Kaos/model	Unknown	EMF Problem
Validation failed unexpectedly for 'Default Size Attributes 200'. See log for details.	KAOS.gmfgen	/Kaos/model	Unknown	EMF Problem
Validation failed unexpectedly for 'Default Size Attributes 40'. See log for details.	KAOS.gmfgen	/Kaos/model	Unknown	EMF Problem
Validation failed unexpectedly for 'Default Size Attributes 60'. See log for details.	KAOS.gmfgen	/Kaos/model	Unknown	EMF Problem
Validation failed unexpectedly for 'Default Size Attributes 80'. See log for details.	KAOS.gmfgen	/Kaos/model	Unknown	EMF Problem
Validation failed unexpectedly for 'Design Label Model Facet'. See log for details.	KAOS.gmfgen	/Kaos/model	Unknown	EMF Problem
Validation failed unexpectedly for 'External Parser'. See log for details.	KAOS.gmfgen	/Kaos/model	Unknown	EMF Problem
Validation failed unexpectedly for 'Feature Label Model Facet'. See log for details.	KAOS.gmfgen	/Kaos/model	Unknown	EMF Problem
Does anyone know how to resolve them?
Re: GMF editor doesn't draw nodes [message #757473 is a reply to message #757460] Fri, 18 November 2011 10:12 Go to previous messageGo to next message
Hi Patricia,
I tried your metamodel with the latest version of Epsilon/GMF but I got similar validation errors in the .gmfgen - which I suspect are also responsible for the GMF code generator producing bad code. I've checked with the filesystem metamodel (http://eclipse.org/gmt/epsilon/doc/articles/eugenia-gmf-tutorial/) to make sure that recent changes in GMF haven't broken EuGENia and it seems to be working fine so I'm guessing the problem lies somewhere in your metamodel.
To pin down the real source of the error, I'd suggest trying slimming down your metamodel by commenting out everything else except for a few classes (including the root) and then trying to add more classes gradually until the errors start reappearing.
Dimitris
Re: GMF editor doesn't draw nodes [message #757483 is a reply to message #757473] Fri, 18 November 2011 10:28 Go to previous messageGo to next message
Thank you Dimitris, I will try that.
Re: GMF editor doesn't draw nodes [message #757502 is a reply to message #757483] Fri, 18 November 2011 11:34 Go to previous messageGo to next message
I have this simple .emf file, and I get an error regarding the polygon figure. It says that polygon cannot be resolved into a type.
@namespace(uri="kaos", prefix="kaos")
package KAOSStandard;
@gmf.diagram(foo="bar")
class KAOS {
  val CompartmentNode[*] hasCompartmentNode;
  val Nodes[*] hasNodes;
  val Links[*] hasLinks;
abstract class Links {
  attr String TransformationSource;
abstract class CompartmentNode {
  attr String name;
@gmf.node(label="name", label.placement="external")
abstract class Nodes {
  attr String name;
  attr String IstarActorContainer;
@gmf.node(color="0,191,255", border.color="0,191,255", size="80,50", figure="polygon", polygon.x="30,70,50,10", polygon.y="10,10,40,40")
class Goal extends Nodes {
  attr boolean isRoot = false;
  attr String formalDef;
  attr String informalDef;
Re: GMF editor doesn't draw nodes [message #757522 is a reply to message #757502] Fri, 18 November 2011 13:27 Go to previous messageGo to next message
Patr, the "polygon" figure type is only available in the latest interim version of Epsilon, and not on the stable 0.9.1 version. Do you have the latest interim version installed from here?
Re: GMF editor doesn't draw nodes [message #757573 is a reply to message #757522] Sat, 19 November 2011 11:50 Go to previous message
Oh, my bad. I didn't instal that version. Thanks Antonio
Re: GMF editor doesn't draw nodes [message #757869 is a reply to message #757460] Fri, 18 November 2011 11:48 Go to previous message
It may also be helpful to actually delete the gmfgen and generated
source code (assuming you have no hand-crafted stuff in any of it at
this time) before regenerating. EMF can sometimes get a little confused
when you make changes that are too substantial :-)
Steffen
Re: GMF editor doesn't draw nodes [message #757870 is a reply to message #757502] Fri, 18 November 2011 12:39 Go to previous message
I think, it is trying to find a polygon Java class implementing the figure.
Best,
Steffen
> class KAOS {
> attr String name;
> attr String name;
Previous Topic:[Eugenia] Call operations from Formatting.eol
Next Topic:[EVL] Quick fixes are not found
Current Time: Sat Jul 26 10:22:26 EDT 2025
Powered by FUDForum. Page generated in 0.26850 seconds
