Home » Language IDEs » C / C++ IDE (CDT) » CDT using Visual C++(Problems linking with latest CDT using Visual C++ Win7/Win64)
CDT using Visual C++ [message #756803] |
Tue, 15 November 2011 02:50  |
Latest CDT update using Indigo, I get a failure during link.
fatal error LNK1112: module machine type 'X86' conflicts with target machine type 'x64'
Below is the console output from a clean build, with a "PRE BUILD" script that does a build using the same commands as the seen from the CDT build. The script compiles, links, then runs the HelloWorld Sample. Then the CDT runs (as far as I can tell) the same command sequence, but fails. Can any one help??
**** Build of configuration Debug for project HelloWorld ****
**** Internal Builder is used for build ****
vctest.bat
C:\usr\toolbox\workspace\projects\HelloWorld\Debug>call C:\usr\lib\SDK\Windows\v7.1\Bin\SetEnv.Cmd /Debug /x64 /win7
ERROR: The system was unable to find the specified registry key or value.
Setting SDK environment relative to C:\usr\lib\SDK\Windows\v7.1\.
Targeting Windows 7 x64 Debug
cd
which cl.exe
C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\Bin\amd64\cl.exe
which link.exe
C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\Bin\amd64\link.exe
A subdirectory or file src already exists.
cl /c /DWIN64 /D_AMD64_ /EHs /MD /Zi /nologo /Fosrc\HelloWorld.obj ..\src\HelloWorld.cpp
HelloWorld.cpp
link /VERBOSE /debug /nologo /OUT:HelloWorld.exe src\HelloWorld.obj
Starting pass 1
Processed /DEFAULTLIB:msvcprt
Processed /DEFAULTLIB:MSVCRT
Processed /DEFAULTLIB:OLDNAMES
Searching libraries
Searching C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\Lib\amd64\msvcprt.lib:
Found "__declspec(dllimport) public: class std::basic_ostream<char,struct std::char_traits<char> > & __cdecl std::basic_ostream<char,struct std::char_traits<char> >::operator<<(class std::basic_ostream<char,struct std::char_traits<char> > & (__cdecl*)(class std::basic_ostream<char,struct std::char_traits<char> > &))" (__imp_??6?$basic_ostream@DU?$char_traits@D@std@@@std@@QEAAAEAV01@P6AAEAV01@AEAV01@@Z@Z)
Referenced in HelloWorld.obj
Loaded msvcprt.lib(MSVCP100.dll)
Found "__declspec(dllimport) class std::basic_ostream<char,struct std::char_traits<char> > & __cdecl std::endl(class std::basic_ostream<char,struct std::char_traits<char> > &)" (__imp_?endl@std@@YAAEAV?$basic_ostream@DU?$char_traits@D@std@@@1@AEAV21@@Z)
Found "__declspec(dllimport) class std::basic_ostream<char,struct std::char_traits<char> > std::cout" (__imp_?cout@std@@3V?$basic_ostream@DU?$char_traits@D@std@@@1@A)
Found "__declspec(dllimport) public: void __cdecl std::basic_ios<char,struct std::char_traits<char> >::setstate(int,bool)" (__imp_?setstate@?$basic_ios@DU?$char_traits@D@std@@@std@@QEAAXH_N@Z)
Found "__declspec(dllimport) public: __int64 __cdecl std::ios_base::width(__int64)" (__imp_?width@ios_base@std@@QEAA_J_J@Z)
Found "__declspec(dllimport) public: __int64 __cdecl std::basic_streambuf<char,struct std::char_traits<char> >::sputn(char const *,__int64)" (__imp_?sputn@?$basic_streambuf@DU?$char_traits@D@std@@@std@@QEAA_JPEBD_J@Z)
Found "__declspec(dllimport) public: int __cdecl std::basic_streambuf<char,struct std::char_traits<char> >::sputc(char)" (__imp_?sputc@?$basic_streambuf@DU?$char_traits@D@std@@@std@@QEAAHD@Z)
Found "__declspec(dllimport) public: class std::basic_streambuf<char,struct std::char_traits<char> > * __cdecl std::basic_ios<char,struct std::char_traits<char> >::rdbuf(void)const " (__imp_?rdbuf@?$basic_ios@DU?$char_traits@D@std@@@std@@QEBAPEAV?$basic_streambuf@DU?$char_traits@D@std@@@2@XZ)
Found "__declspec(dllimport) public: char __cdecl std::basic_ios<char,struct std::char_traits<char> >::fill(void)const " (__imp_?fill@?$basic_ios@DU?$char_traits@D@std@@@std@@QEBADXZ)
Found "__declspec(dllimport) public: int __cdecl std::ios_base::flags(void)const " (__imp_?flags@ios_base@std@@QEBAHXZ)
Found "__declspec(dllimport) public: __int64 __cdecl std::ios_base::width(void)const " (__imp_?width@ios_base@std@@QEBA_JXZ)
Found "__declspec(dllimport) public: class std::basic_ostream<char,struct std::char_traits<char> > & __cdecl std::basic_ostream<char,struct std::char_traits<char> >::flush(void)" (__imp_?flush@?$basic_ostream@DU?$char_traits@D@std@@@std@@QEAAAEAV12@XZ)
Found "__declspec(dllimport) public: class std::basic_ostream<char,struct std::char_traits<char> > * __cdecl std::basic_ios<char,struct std::char_traits<char> >::tie(void)const " (__imp_?tie@?$basic_ios@DU?$char_traits@D@std@@@std@@QEBAPEAV?$basic_ostream@DU?$char_traits@D@std@@@2@XZ)
Found "__declspec(dllimport) public: bool __cdecl std::ios_base::good(void)const " (__imp_?good@ios_base@std@@QEBA_NXZ)
Found "__declspec(dllimport) public: void __cdecl std::basic_ostream<char,struct std::char_traits<char> >::_Osfx(void)" (__imp_?_Osfx@?$basic_ostream@DU?$char_traits@D@std@@@std@@QEAAXXZ)
Found "__declspec(dllimport) bool __cdecl std::uncaught_exception(void)" (__imp_?uncaught_exception@std@@YA_NXZ)
Found __IMPORT_DESCRIPTOR_MSVCP100
Referenced in msvcprt.lib(MSVCP100.dll)
Found __NULL_IMPORT_DESCRIPTOR
MSVCP100_NULL_THUNK_DATA
Searching C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\Lib\amd64\MSVCRT.lib:
Found __CxxFrameHandler3
Loaded MSVCRT.lib(MSVCR100.dll)
Found strlen
Found mainCRTStartup
Loaded MSVCRT.lib(crtexe.obj)
Found __IMPORT_DESCRIPTOR_MSVCR100
Referenced in MSVCRT.lib(MSVCR100.dll)
Found __CxxSetUnhandledExceptionFilter
Referenced in MSVCRT.lib(crtexe.obj)
Loaded MSVCRT.lib(unhandld.obj)
Found _amsg_exit
Found __imp___getmainargs
Found _dowildcard
Loaded MSVCRT.lib(wildcard.obj)
Found _newmode
Loaded MSVCRT.lib(_newmode.obj)
Found atexit
Loaded MSVCRT.lib(atonexit.obj)
Found _RTC_Terminate
Loaded MSVCRT.lib(_initsect_.obj)
Found __C_specific_handler
Referenced in MSVCRT.lib(atonexit.obj)
Found _XcptFilter
Found __imp__exit
Found __imp__cexit
Found __imp_exit
Found __imp___initenv
Found _IsNonwritableInCurrentImage
Loaded MSVCRT.lib(pesect.obj)
Found _initterm
Found __xc_a
Loaded MSVCRT.lib(cinitexe.obj)
Processed /DEFAULTLIB:kernel32.lib
Processed /DISALLOWLIB:libcmt.lib
Processed /DISALLOWLIB:libcmtd.lib
Processed /DISALLOWLIB:msvcrtd.lib
Found _initterm_e
Found __native_startup_state
Loaded MSVCRT.lib(natstart.obj)
Found __imp__configthreadlocale
Found __globallocalestatus
Loaded MSVCRT.lib(xthdloc.obj)
Found __imp___setusermatherr
Found _matherr
Loaded MSVCRT.lib(merr.obj)
Found _setargv
Loaded MSVCRT.lib(dllargv.obj)
Found _commode
Loaded MSVCRT.lib(xncommod.obj)
Found __imp__commode
Found _fmode
Loaded MSVCRT.lib(xtxtmode.obj)
Found __imp__fmode
Found __imp___set_app_type
Found __security_init_cookie
Loaded MSVCRT.lib(gs_support.obj)
MSVCR100_NULL_THUNK_DATA
Found "void __cdecl terminate(void)" (?terminate@@YAXXZ)
Referenced in MSVCRT.lib(unhandld.obj)
Found _unlock
Found __dllonexit
Found _lock
Found __imp__onexit
Found __security_cookie_complement
Referenced in MSVCRT.lib(gs_support.obj)
Loaded MSVCRT.lib(gs_cookie.obj)
Searching C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\Lib\amd64\OLDNAMES.lib:
Searching C:\usr\lib\SDK\Windows\v7.1\Lib\X64\kernel32.lib:
Found __imp_Sleep
Loaded kernel32.lib(KERNEL32.dll)
Found __imp_EncodePointer
Found __imp_SetUnhandledExceptionFilter
Found __imp_DecodePointer
Found __imp_QueryPerformanceCounter
Found __imp_GetTickCount
Found __imp_GetCurrentThreadId
Found __imp_GetCurrentProcessId
Found __imp_GetSystemTimeAsFileTime
Found __IMPORT_DESCRIPTOR_KERNEL32
Referenced in kernel32.lib(KERNEL32.dll)
KERNEL32_NULL_THUNK_DATA
Finished searching libraries
Finished pass 1
Starting pass 2
HelloWorld.obj
Finished pass 2
HelloWorld.exe
!!!Hello World!!!
HelloWorld.cpp
link /VERBOSE /MACHINE:X64 /debug /nologo /OUT:HelloWorld.exe src\HelloWorld.obj
Starting pass 1
src\HelloWorld.obj : fatal error LNK1112: module machine type 'X86' conflicts with target machine type 'x64'
Build error occurred, build is stopped
Time consumed: 2977 ms.
Re: CDT using Visual C++ [message #757347 is a reply to message #757032] |
Thu, 17 November 2011 15:42   |
It seems CDT in eclipse only works with 32Bit on Windows. If I setup Visual C++ for 32Bit all works fine.
But is set for 64Bit then it still seems to create a 32Bit obj. And then fails trying to link it.
This seems to happen no matter what I do to try and get it to use the 64bit compiler, specifying full paths or whatever.
Is there somewhere the path to the compiler stored by the tool chain? Can it be changed??
The problem does not seem like it can be in the setup, as in the pre-build steps my vctest.bat file
runs a compile and link and execute just fine in both 64 and 32 bit setups.
I would use MinGW if it supported 64bit.
vctest.bat
C:\usr\toolbox\workspace\projects\HelloWorld\Debug>echo cd
cd
C:\usr\toolbox\workspace\projects\HelloWorld\Debug>cd
C:\usr\toolbox\workspace\projects\HelloWorld\Debug>echo which cl.exe
which cl.exe
C:\usr\toolbox\workspace\projects\HelloWorld\Debug>which cl.exe
C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\Bin\cl.exe
C:\usr\toolbox\workspace\projects\HelloWorld\Debug>echo which link.exe
which link.exe
C:\usr\toolbox\workspace\projects\HelloWorld\Debug>which link.exe
C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\Bin\link.exe
C:\usr\toolbox\workspace\projects\HelloWorld\Debug>mkdir src
C:\usr\toolbox\workspace\projects\HelloWorld\Debug>echo cl /c /DWIN32 /D_AMD64_ /EHs /MD /Zi /nologo /Fosrc\HelloWorld.obj ..\src\HelloWorld.cpp
C:\usr\toolbox\workspace\projects\HelloWorld\Debug>cl /c /DWIN32 /D_AMD64_ /EHs /MD /Zi /nologo /Fosrc\HelloWorld.obj ..\src\HelloWorld.cpp
HelloWorld.cpp
C:\usr\toolbox\workspace\projects\HelloWorld\Debug>echo link /VERBOSE /MACHINE:X86 /debug /nologo /OUT:HelloWorld.exe src\HelloWorld.obj
C:\usr\toolbox\workspace\projects\HelloWorld\Debug>link /VERBOSE /MACHINE:X86 /debug /nologo /OUT:HelloWorld.exe src\HelloWorld.obj
Starting pass 1
Searching libraries
Searching C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\Lib\msvcprt.lib:
Found "__declspec(dllimport) public: class std::basic_ostream<char,struct std::char_traits<char> > & __thiscall std::basic_ostream<char,struct std::char_traits<char> >::operator<<(class std::basic_ostream<char,struct std::char_traits<char> > & (__cdecl*)(class std::basic_ostream<char,struct std::char_traits<char> > &))" (__imp_??6?$basic_ostream@DU?$char_traits@D@std@@@std@@QAEAAV01@P6AAAV01@AAV01@@Z@Z)
Found "__declspec(dllimport) class std::basic_ostream<char,struct std::char_traits<char> > & __cdecl std::endl(class std::basic_ostream<char,struct std::char_traits<char> > &)" (__imp_?endl@std@@YAAAV?$basic_ostream@DU?$char_traits@D@std@@@1@AAV21@@Z)
Found "__declspec(dllimport) public: void __thiscall std::basic_ios<char,struct std::char_traits<char> >::setstate(int,bool)" (__imp_?setstate@?$basic_ios@DU?$char_traits@D@std@@@std@@QAEXH_N@Z)
Found "__declspec(dllimport) public: __int64 __thiscall std::ios_base::width(__int64)" (__imp_?width@ios_base@std@@QAE_J_J@Z)
Found "__declspec(dllimport) public: __int64 __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::sputn(char const *,__int64)" (__imp_?sputn@?$basic_streambuf@DU?$char_traits@D@std@@@std@@QAE_JPBD_J@Z)
Found "__declspec(dllimport) public: int __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::sputc(char)" (__imp_?sputc@?$basic_streambuf@DU?$char_traits@D@std@@@std@@QAEHD@Z)
Found "__declspec(dllimport) public: class std::basic_streambuf<char,struct std::char_traits<char> > * __thiscall std::basic_ios<char,struct std::char_traits<char> >::rdbuf(void)const " (__imp_?rdbuf@?$basic_ios@DU?$char_traits@D@std@@@std@@QBEPAV?$basic_streambuf@DU?$char_traits@D@std@@@2@XZ)
Found "__declspec(dllimport) public: char __thiscall std::basic_ios<char,struct std::char_traits<char> >::fill(void)const " (__imp_?fill@?$basic_ios@DU?$char_traits@D@std@@@std@@QBEDXZ)
Found "__declspec(dllimport) public: int __thiscall std::ios_base::flags(void)const " (__imp_?flags@ios_base@std@@QBEHXZ)
Found "__declspec(dllimport) public: __int64 __thiscall std::ios_base::width(void)const " (__imp_?width@ios_base@std@@QBE_JXZ)
Found "__declspec(dllimport) public: class std::basic_ostream<char,struct std::char_traits<char> > & __thiscall std::basic_ostream<char,struct std::char_traits<char> >::flush(void)" (__imp_?flush@?$basic_ostream@DU?$char_traits@D@std@@@std@@QAEAAV12@XZ)
Found "__declspec(dllimport) public: class std::basic_ostream<char,struct std::char_traits<char> > * __thiscall std::basic_ios<char,struct std::char_traits<char> >::tie(void)const " (__imp_?tie@?$basic_ios@DU?$char_traits@D@std@@@std@@QBEPAV?$basic_ostream@DU?$char_traits@D@std@@@2@XZ)
Found "__declspec(dllimport) public: bool __thiscall std::ios_base::good(void)const " (__imp_?good@ios_base@std@@QBE_NXZ)
Found "__declspec(dllimport) public: void __thiscall std::basic_ostream<char,struct std::char_traits<char> >::_Osfx(void)" (__imp_?_Osfx@?$basic_ostream@DU?$char_traits@D@std@@@std@@QAEXXZ)
Found MSVCP100_NULL_THUNK_DATA
Searching C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\Lib\MSVCRT.lib:
Found ___security_cookie
Found ___CxxFrameHandler3
Found @__security_check_cookie@4
Loaded MSVCRT.lib(secchk.obj)
Found _strlen
Found _mainCRTStartup
Found ___report_gsfailure
Referenced in MSVCRT.lib(secchk.obj)
Loaded MSVCRT.lib(gs_report.obj)
Found ___CxxSetUnhandledExceptionFilter
Found __amsg_exit
Found __imp____getmainargs
Found __dowildcard
Found __newmode
Found _atexit
Found __RTC_Terminate
Found __imp___cexit
Found __imp___exit
Found __XcptFilter
Found __imp__exit
Found __imp____initenv
Found __IsNonwritableInCurrentImage
Found __initterm
Found ___xc_a
Found __initterm_e
Found ___native_startup_state
Found __SEH_epilog4
Loaded MSVCRT.lib(sehprolg4.obj)
Found __except_handler4
Referenced in MSVCRT.lib(pesect.obj)
Referenced in MSVCRT.lib(sehprolg4.obj)
Loaded MSVCRT.lib(chandler4gs.obj)
Found __imp___configthreadlocale
Found ___globallocalestatus
Found __setdefaultprecision
Loaded MSVCRT.lib(fp8.obj)
Found __imp____setusermatherr
Found __matherr
Found __setargv
Found __commode
Found __imp___commode
Found __imp___fmode
Found __fmode
Found __imp____set_app_type
Found ___security_init_cookie
Found MSVCR100_NULL_THUNK_DATA
Found __crt_debugger_hook
Referenced in MSVCRT.lib(gs_report.obj)
Found __unlock
Found ___dllonexit
Found __lock
Found __imp___onexit
Found __except_handler4_common
Referenced in MSVCRT.lib(chandler4gs.obj)
Found __invoke_watson
Referenced in MSVCRT.lib(fp8.obj)
Found __controlfp_s
Searching C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\Lib\OLDNAMES.lib:
Searching C:\usr\lib\SDK\Windows\v7.1\Lib\kernel32.lib:
Found __imp__InterlockedExchange@8
Found __imp__Sleep@4
Found __imp__InterlockedCompareExchange@12
Found __imp__HeapSetInformation@16
Found __imp__EncodePointer@4
Found __imp__TerminateProcess@8
Found __imp__GetCurrentProcess@0
Found __imp__UnhandledExceptionFilter@4
Found __imp__SetUnhandledExceptionFilter@4
Found __imp__IsDebuggerPresent@0
Found __imp__DecodePointer@4
Found __imp__QueryPerformanceCounter@4
Found __imp__GetTickCount@0
Found __imp__GetCurrentThreadId@0
Found __imp__GetCurrentProcessId@0
Found __imp__GetSystemTimeAsFileTime@4
Found KERNEL32_NULL_THUNK_DATA
Finished pass 1
Searching libraries
Found __load_config_used
Loaded MSVCRT.lib(loadcfg.obj)
Starting pass 2
HelloWorld.obj
MSVCRT.lib(fp8.obj)
Finished pass 2
C:\usr\toolbox\workspace\projects\HelloWorld\Debug>echo HelloWorld.exe
HelloWorld.exe
C:\usr\toolbox\workspace\projects\HelloWorld\Debug>HelloWorld.exe
!!!Hello World!!!
C:\usr\toolbox\workspace\projects\HelloWorld\Debug>dir
Volume in drive C is Windows7_OS
Volume Serial Number is 76A5-1E42
Directory of C:\usr\toolbox\workspace\projects\HelloWorld\Debug
11/17/2011 12:27 PM <DIR> .
11/17/2011 12:27 PM <DIR> ..
11/17/2011 12:27 PM 24,064 HelloWorld.exe
11/17/2011 12:27 PM 300,536 HelloWorld.ilk
11/17/2011 12:27 PM 461,824 HelloWorld.pdb
11/17/2011 12:05 PM <DIR> src
11/17/2011 12:27 PM 225,280 vc100.pdb
4 File(s) 1,011,704 bytes
3 Dir(s) 69,252,898,816 bytes free
Build complete for project HelloWorld
Time consumed: 1061 ms.
Re: CDT using Visual C++ [message #757598 is a reply to message #757347] |
Sun, 20 November 2011 01:48   |
Below is a code snippet from org.eclipse.cdt\windows\org.eclipse.cdt.msw.build\src\org\eclipse\cdt\msw\build\WinEnvironmentVariableSupplier.java
As can be seen the VC and SDK paths are added, but fail to take account of any target platform settings. So you get a default
32bit environment, no matter what you do. The values are appended from registry values and the compiler is set to that value "\bin" when it should be "\bin\amd64" for a 64bit target. Same problem for the SDK.
So even if CDT has an org.eclipse.cdt.core.win32.x86_64 plugin, it is never going to generate a 64bit application only 32bit.
Visual C++ uses a different compiler and the SDK has different libraries for 64bit that are in different directories from the 32bit versions. Given the structure of the Visual C++ directories and the SDK it is not possible to update the Registry values to bypass this issue. Also I note that the Microsoft SDK when installed into a non-default location does not correctly update the paths in the SDK registry entries correctly. That can result in more confusion.
As CDT appends it values the front of the path, not the end, a correctly set environment also does not allow this to work.
I would suggest that there needs to be an option for 64bit targets. And a way to disable the CDT from disturbing the path as setup by the user. When I specifically specified a path set up in a project it was still corrupted by the internal path overrides. Not a good thing.
// Current support is for Windows SDK 7.1 with Visual C++ 10.0
// Secondary support for Windows SDK 7.0 with Visual C++ 9.0
private static String getSDKDir() {
WindowsRegistry reg = WindowsRegistry.getRegistry();
String sdkDir = reg.getLocalMachineValue("SOFTWARE\\Microsoft\\Microsoft SDKs\\Windows\\v7.1", "InstallationFolder");
if (sdkDir != null)
return sdkDir;
return reg.getLocalMachineValue("SOFTWARE\\Microsoft\\Microsoft SDKs\\Windows\\v7.0", "InstallationFolder");
private static String getVCDir() {
String vcDir = reg.getLocalMachineValue("SOFTWARE\\Microsoft\\VisualStudio\\SxS\\VC7", "10.0");
if (vcDir != null)
return vcDir;
return reg.getLocalMachineValue("SOFTWARE\\Microsoft\\VisualStudio\\SxS\\VC7", "9.0");
public static IPath[] getIncludePath() {
// Include paths
List<IPath> includePaths = new ArrayList<IPath>();
if (sdkDir != null) {
includePaths.add(new Path(sdkDir.concat("Include")));
includePaths.add(new Path(sdkDir.concat("Include\\gl")));
if (vcDir != null) {
includePaths.add(new Path(vcDir.concat("Include")));
return includePaths.toArray(new IPath[0]);
private static void addvar(IBuildEnvironmentVariable var) {
envvars.put(var.getName(), var);
private static synchronized void initvars() {
if (envvars != null)
return;
envvars = new HashMap<String, IBuildEnvironmentVariable>();
// The SDK Location
sdkDir = getSDKDir();
vcDir = getVCDir();
if (sdkDir == null && vcDir == null) {
return;
// INCLUDE
StringBuffer buff = new StringBuffer();
IPath includePaths[] = getIncludePath();
for (IPath path : includePaths) {
buff.append(path.toOSString()).append(';');
addvar(new WindowsBuildEnvironmentVariable("INCLUDE", buff.toString(), IBuildEnvironmentVariable.ENVVAR_PREPEND));
// LIB
if (vcDir != null)
buff.append(vcDir).append("Lib;");
if (sdkDir != null)
buff.append(sdkDir).append("Lib;");
addvar(new WindowsBuildEnvironmentVariable("LIB", buff.toString(), IBuildEnvironmentVariable.ENVVAR_PREPEND));
// PATH
buff.append(vcDir).append("..\\Common7\\IDE;");
buff.append(vcDir).append("..\\Common7\\Tools;");
buff.append(vcDir).append("Bin;");
buff.append(vcDir).append("vcpackages;");
Re: CDT using Visual C++ [message #759548 is a reply to message #757909] |
Tue, 29 November 2011 01:36  |
>>Exactly. So in a batch file you could call vcvarsall.bat (as is
>>explained in the link I sent in my last message) to change to a 64bit
>>environment, then invoke Eclipse from there.
>>Or you can change your system-wide PATH variable to FIRST include the
>>64bit versions, THEN the 32bit versions of cl.exe and link.exe.
Neither of these suggestions will work. CDT prepends 32 Bit path values to the environment. To over ride it, you have to manually type them into
the C++ Build>environment panel.
I was wrong earlier when I said that did not work, I found I had made a typo typing in one of the more important entries. But that has to be done for each project. I find that prone to errors. The environment does not seem to come with a copy of an given configuration from another project, which would make things a bit easier.
I normally set my visual C++ using
I also normally set up the MinGW environment at the same time as I use that for some projects.
Editing long paths in small input fields is not my idea of fun.
Current Time: Thu Sep 25 05:14:02 EDT 2025
Powered by FUDForum. Page generated in 0.05100 seconds
