Home » Eclipse Projects » Virgo » Gradle : Bundlor plugin in Groovy (Gradle : Bundlor plugin in Groovy)
Gradle : Bundlor plugin in Groovy [message #754540] Thu, 03 November 2011 03:02 Go to next message
I am using Gradle and hence want to write a Bundlor plugin in Groovy. This plugin can then be used by any team in my organization. Where can I get it?
Pranav
Re: Gradle : Bundlor plugin in Groovy [message #754580 is a reply to message #754540] Thu, 03 November 2011 07:17 Go to previous messageGo to next message
There is no Gradle plugin in at this point for Bundlor but it would be great to have it as a part of the Bundlor project and I'm interested in Gradle so would happily help you write it.
You can find Bundlor on our Milestone download page [http://www.eclipse.org/virgo/download/milestones.php] and the source code is in the GIT repo shown here. http://wiki.eclipse.org/Virgo/Source
What do you think?
Chris.
Re: Gradle : Bundlor plugin in Groovy [message #754611 is a reply to message #754580] Thu, 03 November 2011 10:02 Go to previous messageGo to next message
Sure Chris. I will go through the source. In the mean time, can you please give me some hits, how to start it. I am also evaluating if it is possible to call Ant task from Groovy.
Pranav
Re: Gradle : Bundlor plugin in Groovy [message #755487 is a reply to message #754611] Tue, 08 November 2011 11:13 Go to previous messageGo to next message
So the Gradle plugin should extend the Java plugin that comes with Gradle and just overwrite the Manifest step. The main entry point in to Bundlor is the ManifestGenerator Class. I'd have a look at the 'org.eclipse.virgo.bundlor.ant.internal.AntBundlorExecutor' Class in the Ant plugin and see how it does things. You should just be able to copy code really, depends exactly what the Gradle SPI looks like.
Chris.
Re: Gradle : Bundlor plugin in Groovy [message #756891 is a reply to message #755487] Tue, 15 November 2011 08:09 Go to previous messageGo to next message
Hi Chris,
I have written Gradle plugin for Bundlor using Ant task and it is working fine.
I am not able to find the repository (may be Maven or SpringSource) hosting com.springsource.bundlor.ant, com.springsource.bundlor and com.springsource.bundlor.blint. Please let me know the repository URL, group id and version for these artifacts.
Currently to test my plugin, I have downloaded all the above modules and their dependencies and placed them in my internal binary repository used by my build file.
Pranav
Re: Gradle : Bundlor plugin in Groovy [message #756897 is a reply to message #756891] Tue, 15 November 2011 08:20 Go to previous messageGo to next message
When we moved to Eclispe, we moved the active repos as well. Have a look here.
http://build.eclipse.org/rt/virgo/maven/bundles/milestone/org/eclipse/virgo/bundlor/
Chris.
Re: Gradle : Bundlor plugin in Groovy [message #757022 is a reply to message #756897] Wed, 16 November 2011 01:05 Go to previous messageGo to next message
Few of the dependencies for org.eclipse.virgo.bundlor.blint-1.1.0.M01 are still pointing to 3.0.0.M05 and those are giving me error (module not found) now
org.eclipse.virgo.util#org.eclipse.virgo.util.osgi;3.0.0.M05
org.eclipse.virgo.util#org.eclipse.virgo.util.parser.manifest;3.0.0.M05
org.eclipse.virgo.util#org.eclipse.virgo.util.common;3.0.0.M05
org.eclipse.virgo.util#org.eclipse.virgo.util.math;3.0.0.M05
Where do I get these modules? Or I would suggest changing versions to 3.0.1.RELEASE in POM
Pranav
Re: Gradle : Bundlor plugin in Groovy [message #757025 is a reply to message #757022] Wed, 16 November 2011 01:26 Go to previous messageGo to next message
The latest Bundlor is pointing at 3.0.1.RELEASE but we need to ship another milestone of Bundlor to get that out. I recommend building against the very latest of Bundlor in the GIT repo and then you will find all your dependencies are present in the Maven repo. Let me know if you need it to be published in maven and I'll do another milestone for you.
Chris.
Re: Gradle : Bundlor plugin in Groovy [message #757035 is a reply to message #757025] Wed, 16 November 2011 02:49 Go to previous messageGo to next message
Hi Chris,
It would be great if you publish the latest version to Maven repo.
Pranav
Re: Gradle : Bundlor plugin in Groovy [message #757443 is a reply to message #757035] Fri, 18 November 2011 08:18 Go to previous messageGo to next message
I've done a release of Bundlor milestone 1.1.0.M02. You can find links to the download and release notes here. http://www.eclipse.org/virgo/download/milestones.php
This milestone is also published in Maven along with all it's dependencies.
Let me know if you need anything else.
Chris.
Re: Gradle : Bundlor plugin in Groovy [message #781094 is a reply to message #757443] Fri, 20 January 2012 09:12 Go to previous message
How did you get on with this, it would be great if you would be willing to donate your plugin so others can use it?
Chris.
Previous Topic:Working with Virgo and Hibernate
Next Topic:Problema configuring virgo on eclipse
Current Time: Fri Jul 25 09:52:10 EDT 2025
Powered by FUDForum. Page generated in 0.07280 seconds
