Home » Eclipse Projects » WindowBuilder » Switch Java Class To WindowBuilder
Switch Java Class To WindowBuilder [message #756930] Tue, 15 November 2011 10:09 Go to next message
hi guys
i am new in Window Builder it is powerful
- i finish created java class i have 20 class and lucky i found Window Builder plug in
now i want to open my java class in Window Builder format that means i can navigate between source and design
please help me if there any way to do
index.php/fa/6143/0/
index.php/fa/6142/0/
[Updated on: Tue, 15 November 2011 10:11] by Moderator
Re: Switch Java Class To WindowBuilder [message #756991 is a reply to message #756930] Tue, 15 November 2011 16:30 Go to previous messageGo to next message
Have you tried opening your class using the WindowBuilder Editor?
Re: Switch Java Class To WindowBuilder [message #756992 is a reply to message #756930] Tue, 15 November 2011 16:30 Go to previous messageGo to next message
Re: Switch Java Class To WindowBuilder [message #757017 is a reply to message #756992] Tue, 15 November 2011 22:39 Go to previous messageGo to next message
Hi Eric Claybeg
How i can Open WindowBuilder Editor if i have exists JAVA class which created in normal way
Re: Switch Java Class To WindowBuilder [message #757019 is a reply to message #757017] Tue, 15 November 2011 23:50 Go to previous messageGo to next message
Have you tried the Open WIth command?
I would strongly suggest reviewing the WindowBuilder docs as this is covered there. This is also a very basic feature of Eclipse itself.
Re: Switch Java Class To WindowBuilder [message #757024 is a reply to message #757019] Wed, 16 November 2011 01:24 Go to previous message
thanks a lot dear
i try with Open With command it work fine
i feel i can do any thing with JAVA eclipse
thanks Eric
Previous Topic:FieldEditors beginner problem
Next Topic:Does WB support customized control tree?
Current Time: Thu Jul 24 18:52:28 EDT 2025
Powered by FUDForum. Page generated in 0.03473 seconds
