Home » Modeling » UML2 » Iterative export of ecore to UML2(How to preserve the identity of the generated UML2 elements over iterative exports of the same source ecore model ?)
Iterative export of ecore to UML2 [message #755667] Wed, 09 November 2011 04:12 Go to next message
Suppose that we have an ecore model (M.ecore), which we want to convert to an UML model, so that it can be referenced in other UML models as a design artefact.
During development, it is expected that M.ecore is changed several times, and M.uml must be updated each time.
The problem is that at each 'Export model...' run on M.genmodel, M.uml is generated, but with different xmi:id attributes.
How can the xmi:id attributes be preserved from the existing target model for the unchanged model elements ?
Vlad Gheorghe
Re: Iterative export of ecore to UML2 [message #755689 is a reply to message #755667] Wed, 09 November 2011 05:18 Go to previous messageGo to next message
Hi Vlad
I recommend using *.uml as your primary artefact and *.ecore as a
derived artefact.
Sadly the editor tooling isn't as good.
Papyrus Class Diagrams are ok.
UML Model editor is quite painful.
OCLinEcore can load but cannot yet save UML.
Ed Willink
On 09/11/2011 09:12, Vlad Gheorghe wrote:
> Hello,
> Regards,
> Vlad Gheorghe
Re: Iterative export of ecore to UML2 [message #756482 is a reply to message #755689] Sun, 13 November 2011 16:47 Go to previous messageGo to next message
Thanks Ed for the recommendations.
I was still wondering whether this feature of the Ecore2UML exporter exist, or if there are any plans regarding it.
I guess I'm not the only one having these questions..
Vlad Gheorghe
Re: Iterative export of ecore to UML2 [message #756518 is a reply to message #756482] Mon, 14 November 2011 02:14 Go to previous messageGo to next message
Vlad,
No, there's no feature to preserve generated xmi:id values between
exports. It sounds like a useful feature. (Or better might to be
generate IDs based on the qualified names of the corresponding things in
Ecore rather than generating new IDs each time.)
> Regards,
> Vlad Gheorghe
Re: Iterative export of ecore to UML2 [message #756551 is a reply to message #756518] Mon, 14 November 2011 04:43 Go to previous messageGo to next message
Hi Ed,
It seems to me that you made a confusion in your answer because this is another Vlad and not the real Omondo Vlad you has posted the Id demand and complaining about EMF trying to more DSL oriented and not enough UML focus !!
Too bad that such a fantastic project has made this stupid architecture decision at its creation in 2000.
Vlad
Omondo
Re: Iterative export of ecore to UML2 [message #756600 is a reply to message #756551] Mon, 14 November 2011 08:40 Go to previous messageGo to next message
Vlad,
Comments below.
On 14/11/2011 10:43 AM, Vlad Varnica wrote:
> Hi Ed,
I'm pretty sure he's a real person too and no, I didn't confuse the two
of you at all.
It's impossible to make sense of this ungrammatical atrocity.
Have you not flogged this horse to death yet?
> Vlad Omondo
Re: Iterative export of ecore to UML2 [message #756720 is a reply to message #756482] Mon, 14 November 2011 14:40 Go to previous messageGo to next message
Hi Vlad
This is getting very confusing, quite apart from 2*Ed and 2*Vlad,
Ecore2UML was not part of the earlier discussion.
You want stable xmi:ids for Ecore->UML.
I suggested reversing the direction so that UML is stable.
Ed Merks suggests that stable Ecore->UML xmi:ids might be useful.
Arguably, from a purely modeling perspective, the Ecore and UML variants
are just two representations of one model and so they should not have
distinct unique identities. You could therefore just re-use the Ecore
xmi:ids in the UML exports for the 1:1 objects and define a simple
algorithm for the non 1:1 xmi:ids. (I think MDT/OCL's Ecore2Pivot and
UML2Pivot is the only 'loader' that tries to allow arbitrary intermixing
of Ecore and UML meta-models, so don't try intermixing.)
Ed Willink
Re: Iterative export of ecore to UML2 [message #756916 is a reply to message #756720] Tue, 15 November 2011 09:28 Go to previous message
Hi Ed,
Did you see the Eclipse movie ?
This movie is about Bella, whose high school graduation is fast approaching, is forced to choose between her love for vampire Edward (e.g EMF) and her friendship with werewolf Jacob (e.g. UML).
[Updated on: Thu, 17 November 2011 05:05] by Moderator
Previous Topic:loading a uml-profile
Next Topic:How to add an InstanceSpecification to a Package
Current Time: Wed Jul 23 09:29:55 EDT 2025
Powered by FUDForum. Page generated in 0.07219 seconds
