Home » Archived » Buckminster » [solved] PSF example? Getting "Cannot resolve 'psf:PSFProvider'"
icon5.gif  [solved] PSF example? Getting "Cannot resolve 'psf:PSFProvider'" [message #756446] Sun, 13 November 2011 07:03 Go to next message
Hi everyone, I need help again; I can't get the PSFProvider to work:
vs$ ./buckminster -L DEBUG -data ~/ws-bucky import /Users/vs/Documents/rcos-workspace/documentation/Eclipse/rcos.cquery
import '/Users/vs/Documents/rcos-workspace/documentation/Eclipse/rcos.cquery'
Platform install location: /Users/vs/bucky
Target platform provided by class org.eclipse.buckminster.pde.internal.PDETargetPlatform
edu.unu.iist.rcos.modeler:eclipse.feature: Using resolver rmap
edu.unu.iist.rcos.modeler:eclipse.feature: Using resolver Local resolver
edu.unu.iist.rcos.modeler:eclipse.feature: Trying provider local(materialized)
No materialization found for edu.unu.iist.rcos.modeler:eclipse.feature
edu.unu.iist.rcos.modeler:eclipse.feature: Trying provider local(workspace)
No open workspace project found that corresponds to edu.unu.iist.rcos.modeler:eclipse.feature
edu.unu.iist.rcos.modeler:eclipse.feature: Trying provider local(target)
edu.unu.iist.rcos.modeler:eclipse.feature: Rejecting provider eclipse.platform(feature/edu.unu.iist.rcos.modeler): No component match was found
ERROR   [0001] : org.xml.sax.SAXParseException: cvc-elt.4.2: Cannot resolve 'psf:PSFProvider' to a type definition for element 'rm:provider'.: file:/Users/vs/Documents/rcos-workspace/documentation/Eclipse/rcos.rmap at line: 6 column: 34
INFO:  TAG-ID 0001 = Query for edu.unu.iist.rcos.modeler:eclipse.feature
The rmap looks like this:
<rm:rmap xmlns:rm="http://www.eclipse.org/buckminster/RMap-1.0" xmlns:xi="http://www.w3.org/2001/XMLSchema-instance" xmlns:psf="http://www.eclipse.org/buckminster/PSFProvider-1.0">
  <rm:locator pattern="edu.unu" searchPathRef="rCOS"/>
  <rm:searchPath name="rCOS">
<rm:provider xi:type="psf:PSFProvider" psfFile="rCOS-Modeler.psf" readerType="svn" componentTypes="osgi.bundle,eclipse.feature,buckminster"
   mutable="false" source="true">
        <rm:uri format="http://svn.re.po/path/" />
</rm:provider>
</rm:searchPath>
</rm:rmap>
I tried comparing it with the Maven provider, but it seems the plugins are structured completely different. In case you're asking, the PSF provider plugin is installed from the buckminster 3.7 headless site, yes Wink
As usual, any help is greatly appreciated!
Volker
[Updated on: Wed, 07 December 2011 07:00] by Moderator
Re: PSF example? Getting "Cannot resolve 'psf:PSFProvider'" [message #756871 is a reply to message #756446] Tue, 15 November 2011 06:59 Go to previous messageGo to next message
Still no progress with this problem. Unfortunately, again I don't know how to debug that since a lot of middleware seems to be involved. Given that nobody seems to be able to say "works fine for me", I'm thinking of filing a bug...
Any comments?
-Volker
Re: PSF example? Getting &quot;Cannot resolve 'psf:PSFProvider'&quot; [message #759390 is a reply to message #756871] Mon, 28 November 2011 09:32 Go to previous messageGo to next message
Hi Volker,
Sorry for late reply. From the looks of it the "Buckminster - Team Project Set (PSF) support" feature isn't active. Can
you please verify that it is installed and that there are no errors pertaining to it in the error log?
- thomas
> Any comments?
> -Volker
Re: PSF example? Getting &quot;Cannot resolve 'psf:PSFProvider'&quot; [message #759397 is a reply to message #759390] Mon, 28 November 2011 09:47 Go to previous messageGo to next message
Hi Thomas, thanks for looking into this!
There's no entry whatsoever in workspace/.metadata/.log, the Buckminster PSF plugin was installed through "buckminster install" and is in the plugin directory in both installations where I tried.
Anywhere else I should look?
Update
Tracing the invocation of buckminster using 'truss' on Solaris shows no sign of it actually ever looking at ANY of the plugin/*psf*-files.
-Volker
[Updated on: Mon, 28 November 2011 10:30] by Moderator
Re: PSF example? Getting &amp;quot;Cannot resolve 'psf:PSFProvider'&amp;quot; [message #759438 is a reply to message #759397] Mon, 28 November 2011 11:42 Go to previous messageGo to next message
This looks like the result of a merge gone bad a while back. Can you please file a bugzilla on this?
- thomas
> installed" and is in the plugin directory in both installations where I tried.
> -Volker
Re: PSF example? Getting &amp;quot;Cannot resolve 'psf:PSFProvider'&amp;quot; [message #759443 is a reply to message #759438] Mon, 28 November 2011 12:17 Go to previous messageGo to next message
Ticket: https://bugs.eclipse.org/bugs/show_bug.cgi?id=364977
-Volker
Re: PSF example? Getting &amp;quot;Cannot resolve 'psf:PSFProvider'&amp;quot; [message #759847 is a reply to message #759443] Wed, 30 November 2011 05:04 Go to previous message
Great, it's working fine now!
-V
Previous Topic:headless Buckminster build fails with "Unbound classpath container" on OSX Lion
Next Topic:PSF with empty CVS password?
Current Time: Fri Jul 25 04:53:15 EDT 2025
Powered by FUDForum. Page generated in 0.07190 seconds
