Buckminster 3.7 materialize doesn't materialize for other platforms (it did in 3.6) [message #756620] |
Mon, 14 November 2011 09:24  |
I use buckminster to materialize a CQuery which includes the following:
<cq:property key="target.arch" value="*"/>
<cq:property key="target.os" value="*"/>
<cq:property key="target.ws" value="*"/>
This is into a fresh workspace with an empty target platform. What's supposed to happen is that the target platform is populated with plugins for all architectures. However, in 3.7, it only gets the plugins for the platform doing the materialize. In 3.6, it correctly fetches for all architectures.
The problem in 3.7 seems to be there for both IDE and command line materialize. For command line materialize, I checked some earlier 3.7 releases, and the problem was still there.
Here's what 3.7 materializes:
$ find tp/ -name "org.eclipse.swt*"
tp/plugins/org.eclipse.swt_3.7.1.v3738a.jar
tp/plugins/org.eclipse.swt.gtk.linux.x86_3.7.1.v3738a.jar
$ find tp/ -name "org.eclipse.equinox.launcher*"
tp/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.1.100.v20110505
tp/plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
Here's what 3.6 materializes:
tp/plugins/org.eclipse.swt.gtk.solaris.sparc_3.7.1.v3738a.jar
tp/plugins/org.eclipse.swt.gtk.linux.ppc64_3.7.1.v3738a.jar
tp/plugins/org.eclipse.swt.gtk.aix.ppc_3.7.1.v3738a.jar
tp/plugins/org.eclipse.swt.carbon.macosx_3.7.1.v3738a.jar
tp/plugins/org.eclipse.swt.gtk.solaris.x86_3.7.1.v3738a.jar
tp/plugins/org.eclipse.swt.gtk.linux.s390_3.7.1.v3738a.jar
tp/plugins/org.eclipse.swt.cocoa.macosx.x86_64_3.7.1.v3738a.jar
tp/plugins/org.eclipse.swt.win32.win32.x86_3.7.1.v3738a.jar
tp/plugins/org.eclipse.swt.win32.win32.x86_64_3.7.1.v3738a.jar
tp/plugins/org.eclipse.swt.gtk.hpux.ia64_32_3.7.1.v3738a.jar
tp/plugins/org.eclipse.swt.cocoa.macosx_3.7.1.v3738a.jar
tp/plugins/org.eclipse.swt.gtk.linux.s390x_3.7.1.v3738a.jar
tp/plugins/org.eclipse.swt.gtk.aix.ppc64_3.7.1.v3738a.jar
tp/plugins/org.eclipse.swt.gtk.linux.x86_64_3.7.1.v3738a.jar
tp/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.100.v20110505
tp/plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.100.v20110502
tp/plugins/org.eclipse.equinox.launcher.gtk.linux.s390x_1.1.100.v20110505
tp/plugins/org.eclipse.equinox.launcher.cocoa.macosx_1.1.100.v20110502
tp/plugins/org.eclipse.equinox.launcher.gtk.solaris.x86_1.1.100.v20110505
tp/plugins/org.eclipse.equinox.launcher.gtk.hpux.ia64_32_1.0.0.v20110502
tp/plugins/org.eclipse.equinox.launcher.carbon.macosx_1.1.100.v20110502
tp/plugins/org.eclipse.equinox.launcher.gtk.linux.ppc64_1.0.100.v20110505
tp/plugins/org.eclipse.equinox.launcher.gtk.aix.ppc64_1.1.0.v20110530
tp/plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.100.v20110502
tp/plugins/org.eclipse.equinox.launcher.gtk.solaris.sparc_1.1.100.v20110505
tp/plugins/org.eclipse.equinox.launcher.gtk.aix.ppc_1.1.0.v20110530
tp/plugins/org.eclipse.equinox.launcher.gtk.linux.s390_1.1.100.v20110505
tp/plugins/org.eclipse.equinox.launcher.cocoa.macosx.x86_64_1.1.100.v20110502
Note that when I refer to 3.7 and 3.6, that's the Eclipse/Buckminster version doing the materialize. As it happens, the CQuery I used uses a target platform from 3.7 (Indigo). As a test, I switched back to using a target platform from 3.6 (Helios). The problem persisted.
Is this a bug (in which case I'll open a bugzilla), or has something changed by design in Indigo?
Matthew
Re: Buckminster 3.7 materialize doesn't materialize for other platforms (it did in 3.6) [message #756793 is a reply to message #756620] |
Tue, 15 November 2011 02:05   |
Hi Matthew,
We run multi platform materializations all the time with 3.7 without problems. We do this in several and very different
projects. What you encounter here must somehow be specific to your setup.
It would be helpful if you can provide a reproducible example in a bugzilla.
Kind Regards,
Thomas Hallgren
> Thanks
> Matthew
Re: Buckminster 3.7 materialize doesn't materialize for other platforms (it did in 3.6) [message #793605 is a reply to message #756870] |
Wed, 08 February 2012 05:39  |
I have opened bugzilla https://bugs.eclipse.org/bugs/show_bug.cgi?id=370928 for this problem. The bugzilla includes a publically-visible CQuery and repository to reproduce the problem.
Summary of problem:
A CQuery properties tab defines properties "x=1" and "y=2". An Advisor node defines properties "y=100" and "z=3". Then for components that are selected by that advisor node, properties "x=1", "y=100", "z=3" should apply, with "x" inheritered and not overridden, "y" overidden, and "z" added.
That was how it worked in Buckminster 3.6. However, in Buckminster 3.7, for components that are selected by that advisor node, only properties "y=100", "z=3" applied, with "x" not inherited.
Matthew
FUDForum. Page generated in 0.03817 seconds
