Home » Eclipse Projects » Eclipse Platform » a feature project including sources
a feature project including sources [message #753868] Sat, 29 October 2011 13:31 Go to next message
when I create a feature project, which I use in an update site project,
I'd like also to create the corresponding source plugins (i.e., besides
creating 'myplugin' feature, I'd like also to have 'myplugin SDK'
feature). Similarly to export a plugin together with its sources...
However, I found no direct way of doing this...
any clue please?
thanks in advance
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: a feature project including sources [message #754097 is a reply to message #753868] Mon, 31 October 2011 14:32 Go to previous messageGo to next message
Are you using PDE to build your plugins? I believe you have to create a source feature that matches your regular feature, and build both (we use a master feature that describes all features we want built).
See http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse.pde.doc.user/tasks/pde_source_generation.htm and http://wiki.eclipse.org/PDEBuild/Individual_Source_Bundles
PW
Re: a feature project including sources [message #755712 is a reply to message #754097] Wed, 09 November 2011 06:20 Go to previous messageGo to next message
Hi, we're using PDE Build to create our plugins and features headlessly and I'm trying to achieve a similar thing, specifically:
1 update site with binary features and plugins for public consumption
1 update site with corresponding source features and plugins for internal consumption
I've had a look at the documentation you referenced and had some success. However, I can only get PDE Build to generate a source feature (and plugins) for my feature when I specifically include the source feature in my origin feature, as referenced here: http://www.wickedshell.net/blog/?p=101
This is obviously not ideal, as I wouldn't be able to install the origin feature independently to the source. I had a look at the JDT feature in CVS and as far as I can tell it doesn't seem to work this way - I couldn't see any generate.feature directive in the build.properties (though it's entirely possible that I was looking in the wrong place Wink )
Could someone point me at an example of how some eclipse component builds a distinct source feature? Or maybe tell me how I can get PDE Build to generate a source feature without having to specifically include it in my origin feature (and ideally into a seperate build repository).
Thanks in advance,
Stew
Re: a feature project including sources [message #756850 is a reply to message #754097] Tue, 15 November 2011 05:55 Go to previous message
> See
I'm building using the "Build" button functionality of the update site
site.xml; this uses internally PDE, right?
cheers
Lorenzo
Previous Topic:create new file template
Next Topic:ModelProvider.validateChange limitations
Current Time: Sat Jul 26 00:24:05 EDT 2025
Powered by FUDForum. Page generated in 0.02920 seconds
