Multiple parameters with For loop [message #756605] |
Mon, 14 November 2011 08:55  |
Hi All,
As per my requirement, i have build a report with parameters such as color and modal. In this report we will get 10 orders (for ex). And the parameters are getting from program like if order is one and the color required then the order #1 and color_0 for second order order#2 color_1 and for order 3rd order Order#3 and modal_2 etc.. Now i have two params. How i can get these by logic. Is this possible with For loop? I am bit differ from Programing side. Please give me example/report. It could be appreciated.
JP
Re: Multiple parameters with For loop [message #757823 is a reply to message #757056] |
Wed, 16 November 2011 11:57  |
JP,
I am still confused. What do you want the logic to do different than
what your sample is doing?
Jason
On 11/16/2011 4:45 AM, JP wrote:
> Jason, thanks for your reply,
> Here is my requirement.
> Ex: we have 5 orders, Every order has to be display in separate page, hence i have applied grouping rule.
> In that every order there is one check box that is a parameter which is passing through program at run time. That i have defined as "param" this param is differ for each order. How i have to define param in Report level. Please suggest me. Attached is the output and sample rpt.
> BIRT 2.6.2
> JP.
FUDForum. Page generated in 0.05973 seconds
