Home » Modeling » TMF (Xtext) » Whitespace problem in comma separated list
Whitespace problem in comma separated list [message #756569] Mon, 14 November 2011 06:26 Go to next message
Dear xtexters,
I'm trying to specify the grammar for a comma separated list, like "[1, 2, 3]".
However, I cannot manage to solve the whitespace problem. My editor forces me to write "[1,2,3]". How do I enable some form of whitespace insensitivity?
Here is my grammar:
Array:
'[' values+=INT ((',' values+=INT)*)?']';
Thank you very much.
Re: Whitespace problem in comma separated list [message #756585 is a reply to message #756569] Mon, 14 November 2011 07:16 Go to previous messageGo to next message
This is described in the documentation.
hidden(WS, SL_COMMENT, ML_COMMENT)
If you are using the default terminals, you get this out of the box. If
not, you have to make your terminals hidden (whatever you call the
hidden ones).
As an example, in my DSL, I have this:
grammar org.cloudsmith.geppetto.pp.dsl.PP hidden(WS, SL_COMMENT, ML_COMMENT)
- henrik
On 11/14/11 12:26 PM, steffen.schuette wrote:
> Dear xtexters,
> 2, 3]".
> insensitivity?
> Here is my grammar:
> Array:
Re: Whitespace problem in comma separated list [message #756668 is a reply to message #756585] Mon, 14 November 2011 10:51 Go to previous messageGo to next message
thanks for the fast response. I am using the default terminals so it should work. But it doesn't. Just to be sure I created a demo project using the Project wizard. Then, an array like defined above works also with whitespaces. However, for my grammar it doesn't.
Ther must be some other token confusing the parser (or me). Do you have any idea where I can take a closer look?
The grammar is too large for dissecting it here.
The syntax error highlighted by the editor is: "mismatched input ', ' expecting ']'"
Here is my exact definition:
grammar de.offis.mosaik.mosl.MoSL with org.eclipse.xtext.common.Terminals
ParameterValues:
parameter=[Parameter] '=' '[' values+=INT((',' values+=INT)*)?']';
Thanks.
Re: Whitespace problem in comma separated list [message #756717 is a reply to message #756668] Mon, 14 November 2011 14:13 Go to previous message
Ditching the '?' might be a good idea, as * already means 0 or more times.
Furthermore, check whether any of the "rule call paths" to ParameterValues define a hidden without the WS terminal. hidden() works in a cascading way.
Previous Topic:Xtend and Charset fun
Next Topic:Cannot override final binding bug in 2.2?
Current Time: Sat Jul 19 03:54:48 EDT 2025
Powered by FUDForum. Page generated in 0.07338 seconds
