Home » General (non-technical) » Project Proposals » Paho includes message broker?
Paho includes message broker? [message #754742] Fri, 04 November 2011 03:36 Go to next message
The Paho project proposal is a little unclear about the likely scope of the initial contribution. For instance, what components of IBM Lotus Expeditor micro broker will it include? For instance, will the contribution include a message broker or is it limited to MQTT client libraries?
Re: Paho includes message broker? [message #754769 is a reply to message #754742] Fri, 04 November 2011 05:30 Go to previous messageGo to next message
Hi Glyn. I thought the proposal was reasonably clear about the initial contribution "The initial code contribution to Paho will include Java and C client-side implementations the MQTT protocol, contributed by IBM." ... in the scope section we also mention our intent to include a broker as we move forward. There are freely-available brokers around so this was not an initial priority but clearly it is under discussion as to what Paho should include. I'll blog about this soon but the post on mqtt.org also talks about this which should help clarify.
Re: Paho includes message broker? [message #754780 is a reply to message #754769] Fri, 04 November 2011 06:41 Go to previous messageGo to next message
Thanks Andy. The word "broker" is not used in the proposal, so perhaps the text could be tweaked?
As you may know, I've used micro broker in the past and it would be great technology to include at some stage.
icon10.gif  Re: Paho includes message broker? [message #755883 is a reply to message #754742] Wed, 09 November 2011 20:32 Go to previous messageGo to next message
Does this project relate or connect to Really Smaller Message Broker project in IBM?
Any cooperation or dependency between Paho and Really Smaller Message Broker?
Re: Paho includes message broker? [message #755887 is a reply to message #755883] Wed, 09 November 2011 20:51 Go to previous messageGo to next message
The MQTT client code being contributed in this project will work with RSMB but there is no dependency. The client code will work with brokers that support the MQTT protocol.
....Scott
Re: Paho includes message broker? [message #756383 is a reply to message #755887] Sat, 12 November 2011 09:04 Go to previous messageGo to next message
Scott/Wayne,
Please add me for Eclipse UOMo to the list of interested parties in the Paho
proposal.
- Werner Keil, Eclipse UOMo
should do.
Werner
Re: Paho includes message broker? [message #758253 is a reply to message #756383] Tue, 22 November 2011 08:00 Go to previous message
I worked with Andy way back when MQTT started and would like to get involved with this.
We made some MQTT bridges for Industrial Controllers in Rockwell.
Since that time a lot has happened, I think I can add some value to the contributors.
Gavan
Previous Topic:error with visual editor plug in
Next Topic:Understanding eclipse
Current Time: Sat Jul 26 21:20:25 EDT 2025
Powered by FUDForum. Page generated in 0.04724 seconds
