how the gmf editor supports a constraint in the ecore model [message #756326] |
Fri, 11 November 2011 21:31  |
I am trying simply to understand how the gmf editor respond to a ecore class constraint. For example, in the gmf editor (result of a new eclipse instance) how can I know if a mandatory class attribute has been set? For what I understand, when an new eclipse instance is created it can not display that information. But will the plugin display it? If not, what are the possible and "simple" solutions that I should look for.
I am doing this for my MSc thesis, changing an existing dsl from a college to validate a single attribute so I can parse the resulting file and proceed with my real MSc work.
Re: how the gmf editor supports a constraint in the ecore model [message #759476 is a reply to message #756326] |
Mon, 28 November 2011 14:14  |
Hi, Patricia
I think I can help you. Please, see this simple emf meta model.
@namespace(uri="family", prefix="family")
package family;
@gmf.diagram(foo="bar")
class Parents
val Father[*] fathers;
val Mother[*] mothers;
@gmf.node(label="name")
class Father{
attr String name;
class Mother{
attr String name;
If you create a gmf Editor (a new eclipse instance) and Click Edit->Validate nothing will show up. But if you change the property 'name' in this way
attr String name; --> attr String[1] name;
the property 'name' will be automatically mandatory. So, in gmf editor (new eclipse instance) if the property 'name' is not set and if you click Edit->Validate you'll get an error like this: <<The required feature 'name' of '<Parents>::<Father>' must be set>>
Anyway, I followed the tutorial Dimitrius has talked about. Actually, I didn't need to perform all the actions described there. All I needed to do was:
Having written the constraints, the next step is to bind them to the GMF editor. To do this, we switch to the Extensions tab of MANIFEST.MF and add the org.eclipse.epsilon.evl.emf.validation extension. Then we right-click it and add a new constraintBinding. In thenamespaceURI field of the extension we set the value to <<name of your package>> and in the constraints field we select the <<file .evl which contains the constraints>> EVL file we created in Step 3.
In any case, just let us know if you were successfull, ok ?
FUDForum. Page generated in 0.15187 seconds
