Home » Modeling » Graphiti » Call Direct Edit feature
Call Direct Edit feature [message #756064] Thu, 10 November 2011 12:50 Go to next message
I have set up a custom feature to handle double click events. From this, I would like to call my DirectEditFeature. I can easily get the appropriate feature, but execute() is defined as a no-op it seems.
There is documentation for calling direct edit immediately after object creation, but this solution doesn't work if the object has already been created.
So, is there a way to invoke direct edit? (And why not implement the execute method?)
Adrian.
Re: Call Direct Edit feature [message #756182 is a reply to message #756064] Fri, 11 November 2011 07:09 Go to previous messageGo to next message
After providing the directEditingInfo (I gues that is what you mean) you
will have to enforce a refresh on the diagram editor
(DiagramEditor.refresh()). That should enable direct editing.
HTH,
Michael
Re: Call Direct Edit feature [message #756252 is a reply to message #756182] Fri, 11 November 2011 11:35 Go to previous message
Yes, it works now. Many thanks!
For anyone looking to do the same you will need code something like:
IDirectEditingInfo directEditingInfo =
getFeatureProvider().getDirectEditingInfo();
directEditingInfo.setMainPictogramElement(pe);
//pe should be shape and ga text
directEditingInfo.setPictogramElement(s);
directEditingInfo.setGraphicsAlgorithm(s.getGraphicsAlgorithm());
directEditingInfo.setActive(true);
getDiagramEditor().refresh();
[Updated on: Fri, 11 November 2011 11:41] by Moderator
Previous Topic:Connections with Horizontal start and end & Moving Bendpoints
Next Topic:Getting IProject instance associated to a Diagram
Current Time: Wed Jul 23 04:37:04 EDT 2025
Powered by FUDForum. Page generated in 0.31436 seconds
