Home » Modeling » Epsilon » [Eugenia] Call operations from Formatting.eol
[Eugenia] Call operations from Formatting.eol [message #754998] Sun, 06 November 2011 09:45 Go to next message
First, I would like to congratulate you for Eugenia. It's such a great tool to customize its GMF editor, especially when one doesn't have so much time to dig deeper into GMF.
To create rhombs, arrows and other figures, I have found useful operations in Formatting.eol from Eugenia sources but I didn't find a way to call them.
Is there a way to call Eugenia operations ? For the moment, I'm copying the operations which I'm interested in.
aoyou
Re: [Eugenia] Call operations from Formatting.eol [message #756220 is a reply to message #754998] Fri, 11 November 2011 09:41 Go to previous message
aoyou2002 wrote on Sun, 06 November 2011 09:45
Which ones? We recently added support for using SVG figures and polygons to the latest interim versions: see this page for details (figure="polygon" or figure="svg" in @gmf.node, for instance). Are you using those?
We recommend using polishing transformations instead of directly calling operations in the EuGENia transformations, as these might change from one version to the next. Here is an example of how to use them.
Still, if you really want to use them, you should be able to import the EuGENia .eol script like this:
import "platform:/plugin/org.eclipse.epsilon.eugenia/Formatting.eol";
I just wrote this off the top of my head, so it might not work as it is. It's been a while since I last had to do something like this. Again, this will couple your EOL code to the version of EuGENia you use: we might change the operation you're using at any moment, breaking your code Sad.
For these reasons, I'd suggest that you used the new annotations added in the last interim version (relevant bug). If these do not work for you, then you should try using polishing transformations, copying the bits of EOL code that you need.
[Updated on: Fri, 11 November 2011 09:42] by Moderator
Previous Topic:EVL and Payprus
Next Topic:GMF editor doesn't draw nodes
Current Time: Thu Jul 24 21:32:34 EDT 2025
Powered by FUDForum. Page generated in 0.03552 seconds
