Home » Archived » BIRT » How to increase column width in excel report
How to increase column width in excel report [message #755422] Tue, 08 November 2011 07:46 Go to next message
Hi, I need increase column width in excel report. In report designer has column good width, but in report is very small. Can someone give me the point how to solve this issue? My report is in attachment
Thanks.
Re: How to increase column width in excel report [message #755561 is a reply to message #755422] Tue, 08 November 2011 14:49 Go to previous messageGo to next message
Does it work if you change the layout to fixed and then increase the
size of the master page?
Jason
> Thanks.
Re: How to increase column width in excel report [message #755933 is a reply to message #755561] Thu, 10 November 2011 04:09 Go to previous messageGo to next message
Thanks for reply. I tryed to change MasterPage type from A4 to custom, ande then inrease page width. But IDE complains, that I have to specified page size, when I set page type to custom. Can I ask please what I have to set? (I set page width and height).
Re: How to increase column width in excel report [message #756057 is a reply to message #755933] Thu, 10 November 2011 12:07 Go to previous message
You set the height and width on the same property view. You should also
try fixed layout. I modified the report and it is attached.
Jason
Previous Topic:Problems build BIRT 3.7.1
Next Topic:Footer Locked
Current Time: Fri Jul 25 09:55:04 EDT 2025
Powered by FUDForum. Page generated in 0.04336 seconds
