Home » Eclipse Projects » Plugin Development Environment (PDE) » Logging and tracing from your RCP application
Logging and tracing from your RCP application [message #755925] Thu, 10 November 2011 03:43 Go to next message
Hi all,
I was trying to enable debug and tracing using .options configuration file, which was placed in the installation directory of my RCP application, but with no success. The content of the file looks like this:
org.eclipse.ui/debug=true
org.eclipse.ui/perf/showHeapStatus=true
org.eclipse.ui/trace/commands=true
I was wondering if it would possible to control debug settings programatically from the application code.
Any comments are welcome. Thanks in advance!
Re: Logging and tracing from your RCP application [message #755975 is a reply to message #755925] Thu, 10 November 2011 06:11 Go to previous message
I solved it. The problem was the order of the options in the application configuration file (appname.ini). As a result the debug mode was disabled. All platform settings always have to be put before -vmargs option.
In my case:
-trace
-debuf
-clean
-vmargs
-Xmx512M
-Xms128M
[Updated on: Thu, 10 November 2011 06:17] by Moderator
Previous Topic:Juint plug-in test blocked by popup window
Next Topic:pluginPath and dependencies from remote p2 repositories
Current Time: Sat Jul 26 22:31:10 EDT 2025
Powered by FUDForum. Page generated in 0.45239 seconds
