Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF] Inheritance across two ecore-files
[EMF] Inheritance across two ecore-files [message #740162] Tue, 18 October 2011 04:17 Go to next message
I have a problem, using the inheritance across two different ecore-files.
I will give a short example to have a better understanding of my issue.
My first ecore file is called A.ecore. It has several eClasses. The root class is A, which has a containment towards B, B has a containment towards C.
The second model I have is called B.ecore. B has as a root class D, which has a containment to E and E has a containment to F. E has as attribute value for eSupertypes B from the A.ecore. (B.ecore is quite similar to A.ecore, only with other names)
I would now expect that I can assign below class A in the instance of A.ecore(My.a) not only B, but also E, because E inherits from B. But in fact I cannot do this.
Has anyone an idea, what mistake I made?
In the wizard for creating B.genmodel, I made a reference of A.genmodel.
I tried to open My.a with the Sample Ecore Editor and go to "load Resource" and load B.ecore into it. The idea was, that the knowledge of B.ecore is first available, after the resource was added.
(This project is just an example, I have a bigger project where I need this inheritance. So I considered to solve this issue on a small example project)
Re: [EMF] Inheritance across two ecore-files [message #740179 is a reply to message #740162] Tue, 18 October 2011 04:31 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
Dominik,<br>
<br>
Comments below.<br>
<br>
On 18/10/2011 10:17 AM, Dominik J wrote:
<blockquote cite="mid:j7jbvf$blb$1@news.eclipse.org" type="cite">Hello,
<br>
<br>
ecore-files. <br>
issue.
<br>
<br>
<br>
<br>
<br>
<br>
B.</blockquote>
What do you mean by assign?  Is this about child creation?<br>
<blockquote><a
href="http://ed-merks.blogspot.com/2008/01/creating-children-you-didnt-know.html">http://ed-merks.blogspot.com/2008/01/creating-children-you-didnt-know.html</a><br>
</blockquote>
<br>
But in fact I cannot do this. <br>
Has anyone an idea, what mistake I made? <br>
A.genmodel. I tried to open My.a with the Sample Ecore Editor and
was added. <br>
<br>
</blockquote>
</body>
</html>
Re: [EMF] Inheritance across two ecore-files [message #740227 is a reply to message #740179] Tue, 18 October 2011 05:38 Go to previous messageGo to next message
Hello Ed, many thanks for your quick answer! Smile
It is in fact exactly the same thing as you explained in your blogpost. But I tried around a little bit and it did not work for me this way. I have now set the eClass B in A.ecore to abstract. In the genmodel I set "Extensible Provider Factory" to true. In B.genmodel I set "Child Creation Extenders" to true. Do I have to do something additional?
Re: [EMF] Inheritance across two ecore-files [message #740234 is a reply to message #740227] Tue, 18 October 2011 05:43 Go to previous messageGo to next message
You've noted the comments about the fact that the plugin.xmls won't
update unless you delete them?
On 18/10/2011 11:38 AM, Dominik J wrote:
> Hello Ed, many thanks for your quick answer! :) It is in fact exactly
Re: [EMF] Inheritance across two ecore-files [message #740274 is a reply to message #740234] Tue, 18 October 2011 06:31 Go to previous messageGo to next message
No I just did overread this, to be honest Sad But now it works in my test environment.
Thank you very much for your quick help! Smile
Re: [EMF] Inheritance across two ecore-files [message #755945 is a reply to message #740162] Thu, 10 November 2011 04:38 Go to previous messageGo to next message
Ok, I worked a little bit further on my project and have a new issue, where I do not know how to handle it.
I extend my one ecore file with another file. Recently the project changed a little bit. Now I do not want to do a child creation, only a reference.
So for example I want to assign in my base ecore file an element from the inheriting ecore. This works fine, but only after I created an instance from the element I want to reference.
I created a container where all the elements, which I want to reference are contained in. After they are contained, I can set the reference on them. Is it possible to provide a list of the inheriting elements, without doing the detour of creating the elements?
Re: [EMF] Inheritance across two ecore-files [message #756014 is a reply to message #755945] Thu, 10 November 2011 08:30 Go to previous messageGo to next message
Dominik,
Comments below.
> reference.
Assign? You mean create a reference to?
Yes, the object has to be reachable somehow...
> elements,
Not sure what you mean by a list of the inheriting elements...
Do you always want to create a new element when populating the reference?
Re: [EMF] Inheritance across two ecore-files [message #756506 is a reply to message #740162] Mon, 14 November 2011 01:40 Go to previous messageGo to next message
I want the object to be reachable without creating it explicitly.
Maybe I can compare it to an enumeration. I can only select the elements, which are available in the inheriting ecore file. Just like an enumeration, but without being actually one. Smile
At the moment I can do a child creation in an instance of my base ecore file, where all the elements from the inheriting ecore file are selectable. Now I only do not want a child creation, only a reference through a property.
Many thanks for your help! Smile
Re: [EMF] Inheritance across two ecore-files [message #756516 is a reply to message #756506] Mon, 14 November 2011 02:09 Go to previous messageGo to next message
Dominik,
Comments below.
So you want it to be created implicitly?
> an enumeration, but without being actually one. :)
> through a property.
Well, clearly if you want to refer to something that doesn't yet exist
you'll need to create it. Also, for serialization, you'll need to be
sure it's added to some containment reference as well.
> Many thanks for your help! :)
This posting doesn't have any question marks.
Re: [EMF] Inheritance across two ecore-files [message #756521 is a reply to message #756516] Mon, 14 November 2011 02:48 Go to previous messageGo to next message
OK, even without question marks you gave me the answer I needed. Wink
So I need to create the object to use it for a reference Smile
Is it possible to do the creation of an object implicitly as you mentioned above? For example, if I create an container, all elements from the inheriting ecore file are created as a child of this container.
Re: [EMF] Inheritance across two ecore-files [message #756527 is a reply to message #756521] Mon, 14 November 2011 03:32 Go to previous message
Dominik,
Comments below.
On 14/11/2011 8:48 AM, Dominik J wrote:
> OK, even without question marks you gave me the answer I needed. ;)
I try my best.
> So I need to create the object to use it for a reference :)
Yes, one way or another.
> mentioned above?
Anything is possible if you specialize commands or property descriptors.
When child creation descriptors are created, you can initialize those
new objects any way that makes sense.
Previous Topic:Is it possible to modify/delete an eReference from an EObject?
Next Topic:EMF and JPA
Current Time: Sat Jul 26 21:22:45 EDT 2025
Powered by FUDForum. Page generated in 0.06603 seconds
