Home » Archived » SeMantic Information Logistics Architecture (SMILA) » Validate adding a new attribute works
Validate adding a new attribute works [message #755670] Wed, 09 November 2011 04:13 Go to next message
I'm writing a pipelet for SMILA and adding a new Attribute using
blackboard.getMetadata(id).put(attrName, value);
in the process() method. With the search website activated in the 5
minutes to success I can't see the new attribute. How can I verify the
attribute is indeed added to the record? Is there a REST API which I can
use?
Best,
Stephan
Stephan Mehlhase
Phone: +49-6221-533213
Email: stephan.mehlhase@eml-d.villa-bosch.de
European Media Laboratory GmbH
Schloss-Wolfsbrunnenweg 35
69118 Heidelberg
Amtsgericht Mannheim / HRB 335719
Managing Partner: Dr. h. c. Dr.-Ing. E. h. Klaus Tschira, Scientific and
Managing
Director: Prof. Dr.-Ing. Andreas Reuter
http://www.eml-development.de
Testen Sie auch unsere neue Android Applikation zur Mediensteuerung:
http://market.android.com/search?q=pname:org.eml.upnp
Re: Validate adding a new attribute works [message #755703 is a reply to message #755670] Wed, 09 November 2011 05:43 Go to previous messageGo to next message
Am 09.11.2011, 10:13 Uhr, schrieb Stephan Mehlhase
<stephan.mehlhase@eml.org>:
> use?
To see a new attribute in the result list, you must add it to the index
configuration:
* configuration/org.eclipse.smila.search.datadictionary/DataDictionary.xml
* configuration/org.eclipse.smila.lucene/Mappings.xml
and to the list of "resultAttributes" in the XSL stylesheet producing the
result page:
* configuration/org.eclipse.smila.search.servlet/SMILASearchDefault.xsl
(or SMILASearchAdvanced.xsl, if you use this one)
Then after rebuilding in the index you should see the new attribute.
Depending on what you are doing exactly you may be able to test your
pipeline using the
REST API by POSTing an appropriate record to
/smila/pipeline/<pipelinename>/process, then
you should see in the result if the attribute was set. However, this will
currently not help
if you are using attachments, because you can't add them to the request.
We are working on this (;
Jürgen.
Re: Validate adding a new attribute works [message #755903 is a reply to message #755703] Thu, 10 November 2011 01:39 Go to previous message
thanks. It worked :)
Best,
Stephan
On 11/09/2011 11:43 AM, Juergen Schumacher wrote:
>> can use?
> configuration:
> the result page:
> pipeline using the
> will currently not help
> Cheers,
> Jürgen.
Stephan Mehlhase
69118 Heidelberg
Managing
Previous Topic:Release 0.9 is out!
Next Topic:Attribute Max Size?
Current Time: Sat Jul 26 08:03:24 EDT 2025
Powered by FUDForum. Page generated in 0.03324 seconds
