Home » Modeling » TMF (Xtext) » dangling reference error in XBlockExpression when accessing properties(define JvmType of property programmatically)
icon5.gif  dangling reference error in XBlockExpression when accessing properties [message #755124] Mon, 07 November 2011 08:26 Go to next message
Hallo,
I am new to Xtext and have a problem with my DSL. It is derived from the domainmodel example (using xtext 2.0.1):
Entity:
	{Entity}
	abstract?='abstract'? 'entity' name=ValidID ('extends' superType=[Entity|QualifiedName])? '{'
		(properties+=Property ("," properties+=Property)*)?
		methods+=Method*
Property:
	ToOneAssociation | ... ;
ToOneAssociation:
	{ToOneAssociation}
	(protected?='#'|'-')?
	name=ValidID ':' access=AccessConfig? 'ref'
	fromMany?='*'?
	entity=[Entity|QualifiedName]
	('backref' backReference=[Property|ValidID])?
	notNull?='notNull'?
	unique?='unique'?
	validator=[Validator|QualifiedName]?;
Entities and field types with getters and setters are mapped to JvmTypes in an IJvmModelInferrer like this:
	@Inject extension IJvmModelAssociator jvmModelAssociator
	@Inject TypeReferences types
	@Inject extension IJvmModelAssociations associations
	def transform(Entity entity) {
		val jvmType = typesFactory.createJvmGenericType
		jvmType.simpleName = entity.name
		jvmType.packageName = entity.packageName
		jvmType.visibility = JvmVisibility::PUBLIC
		entity.associatePrimary(jvmType)
		for (p : entity.properties)
			associateProperty(p, jvmType)
		newArrayList(jvmType as JvmDeclaredType)
	def dispatch associateProperty(ToOneAssociation p, JvmGenericType jvmType) {
		transformProperty(property, jvmTypeRef(property.entity), jvmType)
	... {more dispatched associateProperty methods} ...
	def void transformProperty(Property property, JvmTypeReference fieldType, JvmGenericType jvmType) {
		val jvmField = typesFactory.createJvmField
		val access = property.access
		jvmField.simpleName = property.name
		jvmField.type = cloneWithProxies(fieldType)
		jvmField.visibility = jvmVisibility(property)
		jvmType.members += jvmField
		property.associatePrimary(jvmField)
		if (access == null || access.getter) {
			val jvmGetter = typesFactory.createJvmOperation
			jvmGetter.simpleName = "get" + property.name.toFirstUpper
			jvmGetter.returnType = cloneWithProxies(fieldType)
			jvmGetter.visibility = JvmVisibility::PUBLIC
			jvmType.members += jvmGetter
			property.associatePrimary(jvmGetter)
		if (access == null || access.setter) {
			val jvmSetter = typesFactory.createJvmOperation
			val parameter = typesFactory.createJvmFormalParameter
			parameter.name = property.name.toFirstUpper
			parameter.parameterType = cloneWithProxies(fieldType)
			jvmSetter.simpleName = "set" + property.name.toFirstUpper
			jvmSetter.visibility = JvmVisibility::PUBLIC
			jvmSetter.parameters += parameter
			jvmType.members += jvmSetter
			property.associatePrimary(jvmSetter)
	def JvmTypeReference jvmTypeRef(Entity type) {
		var jvmType = type.jvmElements.filter(typeof(JvmType)).head
		if (jvmType == null) {
			transform(type)
				throw new IllegalArgumentException("Cannot resolve type " + type.name)
		types.createTypeRef(jvmType)
The following example code with my DSL shows what I want to do and contains my problem:
package test {
	entity A {
		created : java.util.Date,
		propertyToB : ref B
		testOp() : void {
			propertyToB.[color=red]propertyToA[/color].created.^time
	entity B {
		propertyToA : ref A
I can access every property with autocompletion. But afterwards Eclipse marks the nested property access propertyToA as error but not the propertyB access before and not the following java.util.Date property which type is included by the xbase grammar rule JvmTypeReference.
The error says:
The feature 'feature' of 'org.eclipse.xtext.xbase.impl.XMemberFeatureCallImplCustom@2c405913{platform:/resource/Testxy/src/SampleEntities.crudsl#/0/@elements.3/@elements.1/@methods.0/@body/@expressions.1/@memberCallTarget}'
contains a dangling reference 'org.eclipse.xtext.common.types.impl.JvmOperationImpl@5b6a3d73{#///@members.7}'
and eclipse throws a NullPointerException at org.eclipse.xtext.resource.IGlobalServiceProvider$ResourceServiceProviderImpl.findService(IGlobalServiceProvider.java:59)
I've read that every persistent element in an EMF model has to be registered in Resource.contents to be indexed. Makes sense. Although it says that xbase registers its used JvmTypes by itself in the model root I tried to register every entity's JvmType in the transform(entity) method by writing
entity.eResource.contents.add(jvmType)
This makes my access error disappear but comes up with an eclipse exception with dialog window:
!MESSAGE org.eclipse.xtext.linking.lazy.LazyLinkingResource - resolution of uriFragment 'xtextLink_::0.0.3.1.2.4.0.6::1::/0' failed.
!STACK 0
org.eclipse.emf.common.util.BasicEList$BasicIndexOutOfBoundsException: index=3, size=0
at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:352)
at org.eclipse.xtext.linking.lazy.LazyURIEncoder.resolveShortFragment(LazyURIEncoder.java:100)
at org.eclipse.xtext.linking.lazy.LazyURIEncoder.decode(LazyURIEncoder.java:80)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:157)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.resolveLazyCrossReference(LazyLinkingResource.java:139)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.resolveLazyCrossReferences(LazyLinkingResource.java:103)
at org.eclipse.xtext.EcoreUtil2.resolveLazyCrossReferences(EcoreUtil2.java:417)
at org.eclipse.xtext.validation.ResourceValidatorImpl.resolveProxies(ResourceValidatorImpl.java:127)
at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:62)
at org.eclipse.xtext.ui.editor.validation.ValidationJob$1.exec(ValidationJob.java:79)
at org.eclipse.xtext.ui.editor.validation.ValidationJob$1.exec(ValidationJob.java:1)
at org.eclipse.xtext.util.concurrent.AbstractReadWriteAcces.readOnly(AbstractReadWriteAcces.java:32)
at org.eclipse.xtext.ui.editor.model.XtextDocument.readOnly(XtextDocument.java:86)
at org.eclipse.xtext.ui.editor.validation.ValidationJob.createIssues(ValidationJob.java:75)
at org.eclipse.xtext.ui.editor.validation.ValidationJob.run(ValidationJob.java:64)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
HELP, PLEASE!
Simply, I want to access properties with JvmTypes of my entities in a XBlockExpression having defined the JvmType of every property programmatically because I do not want users create associations to other java types than the defined entities.
regards,
Max
[Updated on: Mon, 07 November 2011 22:46] by Moderator
Re: dangling reference error in XBlockExpression when accessing properties [message #755506 is a reply to message #755124] Tue, 08 November 2011 11:42 Go to previous messageGo to next message
I am stuck on this problem!!!
I do not understand this.
My problem in a few words:
I want to have a grammar similar to that from the domain model example but without declaration of specific java types. Instead I want to define the types programmatically. In case of an entity reference I use the JvmGenericType declared for that entity but in the DSL the grammar rule for that is not [JvmTypeReference] but ref (*) [Entity]. Lists shall also not be declared as explicit java types in the DSL but as keywords list or set with the optional keyword * afterwards marking that property as manyToMany association. Inside the IJvmModelInferrer instance I declare properties with these keywords as JvmTypeReference of java.util.List/Set. With such limitations I want to be able to define the grammar context free but dependent of special types.
Shorter: I want to have a clear context free separation of *toMany/*toOne associations and normal attributes without analysing the given JvmTypeReferences and collection types.
Help, please!!!
regards,
Max
[Updated on: Tue, 08 November 2011 11:42] by Moderator
Re: dangling reference error in XBlockExpression when accessing properties [message #755548 is a reply to message #755506] Tue, 08 November 2011 14:08 Go to previous messageGo to next message
Hi Max,
please make sure that the XbaseLazyLinker is bound for your language.
Sebastian
> I want have a grammar similar to that from the domain model example but
> Help, please!!!
> regards,
> Max
Re: dangling reference error in XBlockExpression when accessing properties [message #755569 is a reply to message #755548] Tue, 08 November 2011 15:08 Go to previous messageGo to next message
Hey,
My grammar extends org.eclipse.xtext.xbase.Xbase.
Included in GenerateCrudsl.mwe2:
fragment = xbase.XbaseGeneratorFragment {}
For this reason generated in AbstractCrudslRuntime
public Class<? extends org.eclipse.xtext.linking.ILinker> bindILinker() {
	return org.eclipse.xtext.xbase.jvmmodel.JvmModelXbaseLazyLinker.class;
Any other idea?
The example dsl code once again:
package test {
	entity A {
		propertyToB : ref B
		testOp() : void {
			propertyToB.propertyToA
	entity B {
		propertyToA : ref A
In testOp(): Access to propertyToB is valid. Access to propertyToA is marked as error:
The feature 'feature' of 'org.eclipse.xtext.xbase.impl.XMemberFeatureCallImplCustom@7ed655a8{platform:/resource/Testxy/src/SampleEntities.crudsl#/0/@elements.3/@elements.0/@methods.0/@body/@expressions.1/@memberCallTarget/@memberCallTarget}'
   contains a dangling reference 'org.eclipse.xtext.common.types.impl.JvmOperationImpl@6a85a2b6{#///@members.4}'
regards,
Max
[Updated on: Tue, 08 November 2011 15:16] by Moderator
Re: dangling reference error in XBlockExpression when accessing properties [message #755574 is a reply to message #755569] Tue, 08 November 2011 15:28 Go to previous messageGo to next message
Hi Max,
please make sure that you invoke disassociate on the root element of
your resource prior to adding new associations.
Sebastian
On 08.11.11 21:08, Max wrote:
> Hey,
> Included in GenerateMyLang.mwe2:
> For this reason generated in AbstractMyLanguageRuntime
> Any other idea?
> regards,
> Max
Re: dangling reference error in XBlockExpression when accessing properties [message #755589 is a reply to message #755574] Tue, 08 November 2011 16:20 Go to previous messageGo to next message
Hey Sebastian,
I call sourceObj.disassociate() once before I start mapping like in domainmodel example:
	override List<? extends JvmDeclaredType> inferJvmModel(EObject sourceObject) {
		sourceObject.disassociate()
		transform(sourceObject).toList()
	def dispatch Iterable<JvmDeclaredType> transform(Crudsl model) {
		model.elements.map(e | transform(e)).flatten
	def dispatch Iterable<JvmDeclaredType> transform(PackageDeclaration packageDecl) {
		packageDecl.elements.map(e | transform(e)).flatten
	def dispatch Iterable<JvmDeclaredType> transform(Entity entity) {...
Entities and Properties are mapped via associatePrimary() as you can see in my first post.
Another idea? Confused
The error may rely on the jvmTypeRef() method (see #1)?
regards,
Max
[Updated on: Wed, 09 November 2011 13:46] by Moderator
Re: dangling reference error in XBlockExpression when accessing properties [message #755897 is a reply to message #755589] Thu, 10 November 2011 00:38 Go to previous messageGo to next message
Now I realised that Xtext 2.1 is already available using the update site. I had installed Xtext 2.0.1 from eclipse marketplace before that.
With Xtext 2.1 everything works. Great!
Thanks for your help, Sebastian.
The only thing is I iterate over the whole grammar twice register types first and their elements afterwards to create bidirectional references.
Is there a better approach?
I expected the initializer closures of the JvmTypesBuilder.toClass() method calls beeing called after all elements are mapped to JvmTypes but it is called directly after every single type mapping. Sad
regards,
Max
[Updated on: Thu, 10 November 2011 01:01] by Moderator
Re: dangling reference error in XBlockExpression when accessing properties [message #755902 is a reply to message #755897] Thu, 10 November 2011 01:27 Go to previous messageGo to next message
> method calls beeing called after every element is mapped to a JvmType
> but it is called directly after every single type mapping. :(
> regards,
> Max
Hi Max,
you may want to use create functions for that purpose:
http://www.eclipse.org/Xtext/documentation/2_1_0/02-Xtend_Classes_Functions.php#CreateFunctions
Sebastian
Re: dangling reference error in XBlockExpression when accessing properties [message #756069 is a reply to message #755902] Thu, 10 November 2011 13:42 Go to previous messageGo to next message
Thanks a lot!!! Very good approach.
But there seems to be a problem with the scope in the java code generator of Xtend:
class CrudslJvmModelInferrer extends AbstractModelInferrer {
	@Inject extension JvmTypesBuilder
	@Inject extension IQualifiedNameProvider
	def dispatch infer(Type type, IAcceptor<JvmDeclaredType> acceptor, boolean prelinkingPhase) {
		acceptor.accept(type.toJvmType())
	def create jvmType: type.toClass(type.fullyQualifiedName, null) toJvmType(Type type) {
		... {initialize: associate type's fields with jvmType's fields} ...
generates:
  public JvmGenericType toJvmType(final Type type) {
    final ArrayList<?>_cacheKey = CollectionLiterals.newArrayList(type);
    final JvmGenericType _result;
    synchronized (_createCache_toJvmType) {
      if (_createCache_toJvmType.containsKey(_cacheKey)) {
        return _createCache_toJvmType.get(_cacheKey);
->    CrudslJvmModelInferrer _CrudslJvmModelInferrer = CrudslJvmModelInferrer;
->    CrudslJvmModelInferrer _CrudslJvmModelInferrer_1 = CrudslJvmModelInferrer;
      QualifiedName _fullyQualifiedName = _CrudslJvmModelInferrer_1._iQualifiedNameProvider.getFullyQualifiedName(type);
      JvmGenericType _class = _CrudslJvmModelInferrer._jvmTypesBuilder.toClass(type, _fullyQualifiedName, null);
      _result = _class;
      _createCache_toJvmType.put(_cacheKey, _result);
    _init_toJvmType(_result, type);
    return _result;
"CrudslJvmModelInferrer _CrudslJvmModelInferrer = CrudslJvmModelInferrer;" is an error. It should be
"CrudslJvmModelInferrer _CrudslJvmModelInferrer = this;" and is not neccessary. "this" could also be used, directly.
Somehow, I cannot access "this"/extensions in the first expression of the create function.
Is it a bug or a feature?
regards,
Max
[Updated on: Thu, 10 November 2011 15:55] by Moderator
Re: dangling reference error in XBlockExpression when accessing properties [message #756093 is a reply to message #756069] Thu, 10 November 2011 15:37 Go to previous messageGo to next message
Max,
thanks for the report. This was already fixed for 2.1.1 which will be
available tomorrow.
Sebastian
On 10.11.11 19:42, Max wrote:
> Thanks a lot!!! Very good approach. But there seems to be a problem with
> ... {initialize} ...
> generates:
> _result = _class;
> return _result;
> Is this a bug or do I not understand sth?
> regards,
> Max
Re: dangling reference error in XBlockExpression when accessing properties [message #756098 is a reply to message #756093] Thu, 10 November 2011 16:01 Go to previous messageGo to next message
Great, just in time!!! Laughing
Re: dangling reference error in XBlockExpression when accessing properties [message #756320 is a reply to message #756098] Fri, 11 November 2011 18:22 Go to previous messageGo to next message
Hey,
now I've installed Xtext 2.1.0 release + Xtext 2.1.1 nightly build but wiring bidirectional references does not work with this create function. It throws a StackOverflowError.
Xtend:
	@Inject extension TypeReferences types
		acceptor.accept(type.jvmType)
	def create jvmType: type.toClass(type.fullyQualifiedName, null) jvmType(Type type) {
   		for (p : entity.properties) {
   			val type = p.jvmTypeRef(jvmType)
			jvmType.members += p.toField(p.name, type)
			if (p.access == null || p.access.getter)
				jvmType.members += p.toGetter(p.name, type)
   			if (p.access == null || p.access.setter)
				jvmType.members += p.toSetter(p.name, type)
	def dispatch JvmTypeReference jvmTypeRef(ToOneAssociation p, JvmGenericType jvmType) {
		p.entity.jvmType.createTypeRef()
	... {more dispatched jvmTypeRef() methods} ...
generated java:
  public JvmGenericType jvmType(final Type type) {
    synchronized (_createCache_jvmType) {
      if (_createCache_jvmType.containsKey(_cacheKey)) {
        return _createCache_jvmType.get(_cacheKey);
      QualifiedName _fullyQualifiedName = this._iQualifiedNameProvider.getFullyQualifiedName(type);
      JvmGenericType _class = this._jvmTypesBuilder.toClass(type, _fullyQualifiedName, null);
      _result = _class;
      _createCache_jvmType.put(_cacheKey, _result);
    _init_jvmType(_result, type);
    return _result;
Here the _init_jvmType() method is called directly after instantiating a new object. It doesn't work because initialization requires existing types, which are not yet instantiated. I thought somehow the create function's initializer is called after every element is instantiated?!
In the documentation it seems to be possible to map bidirectional references like this: http://www.eclipse.org/Xtext/documentation/2_1_0/02-Xtend_Classes_Functions.php#CreateFunctions.
What am I doing wrong?
regards,
Max
Re: dangling reference error in XBlockExpression when accessing properties [message #756322 is a reply to message #756320] Fri, 11 November 2011 18:43 Go to previous messageGo to next message
i guess you have a missunderstanding what a create function does:
(1) it looks up the parameter in a cache and if it finds something then this something is return
(2) else it creates a new instance using the "factory" expression
(3) then it calls the "initializer" expression
(4) the result is stored to the cache.
=> you can call the conversion to jvm class at every place you need it, so matter if it is at the for loop
when you iterate over all entities, nor if you want to get the jvm type of the references to another entity
since the caching is done before calling the initializer expression there should be no problem with an endless loop
/ stackoverflow.
=> is it really the jvmType function that causes the stackoverflow?
~Christian
[Updated on: Fri, 11 November 2011 18:45] by Moderator
Re: dangling reference error in XBlockExpression when accessing properties [message #756325 is a reply to message #756322] Fri, 11 November 2011 20:24 Go to previous messageGo to next message
Thank you for your answer.
You're right: The jvmType method works well but there seems to be a problem with the result of a create method passed to acceptor.accept(). It may be a proxy because my test eclipse instance has the StackOverflow while resolving proxies (stacktrace only visible when shutting eclipse down for some reason else I only get a window with that short error information):
Error while informing user about event loop exception:
java.lang.StackOverflowError
	at org.eclipse.xtext.common.types.impl.JvmDeclaredTypeImpl.getMembers(JvmDeclaredTypeImpl.java:285)
	at org.eclipse.xtext.common.types.impl.JvmDeclaredTypeImpl.eGet(JvmDeclaredTypeImpl.java:489)
	at org.eclipse.xtext.common.types.impl.JvmGenericTypeImpl.eGet(JvmGenericTypeImpl.java:232)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1021)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1013)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eObjectForURIFragmentSegment(BasicEObjectImpl.java:533)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject(ResourceImpl.java:780)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject(ResourceImpl.java:756)
	at org.eclipse.xtext.resource.XtextResource.access$1(XtextResource.java:1)
	at org.eclipse.xtext.resource.XtextResource$1.getEObject(XtextResource.java:102)
	at org.eclipse.xtext.resource.DefaultFragmentProvider.getEObject(DefaultFragmentProvider.java:26)
	at org.eclipse.xtext.resource.XtextResource.getEObject(XtextResource.java:286)
	at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:211)
	at org.eclipse.xtext.xbase.resource.XbaseResource.access$0(XbaseResource.java:1)
	at org.eclipse.xtext.xbase.resource.XbaseResource$2.exec(XbaseResource.java:227)
	at org.eclipse.xtext.xbase.resource.XbaseResource$2.exec(XbaseResource.java:1)
	at org.eclipse.xtext.util.OnChangeEvictingCache.execWithoutCacheClear(OnChangeEvictingCache.java:121)
	at org.eclipse.xtext.xbase.resource.XbaseResource.getEObject(XbaseResource.java:225)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:219)
	at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:203)
	at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:263)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResolveProxy(BasicEObjectImpl.java:1483)
	at org.eclipse.emf.ecore.util.EcoreEList.resolveProxy(EcoreEList.java:212)
	at org.eclipse.emf.ecore.util.EcoreEList.resolve(EcoreEList.java:167)
	at org.eclipse.emf.ecore.util.EObjectContainmentWithInverseEList$Resolving.resolve(EObjectContainmentWithInverseEList.java:111)
	at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:354)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eObjectForURIFragmentSegment(BasicEObjectImpl.java:545)
works:
	def dispatch void infer(Type type, IAcceptor<JvmDeclaredType> acceptor, boolean prelinkingPhase) {
		acceptor.accept(type.toClass(type.fullyQualifiedName, null))
works:
		type.jvmType
results in the exception above:
This is weird.
regards,
Max
[Updated on: Fri, 11 November 2011 20:32] by Moderator
Re: dangling reference error in XBlockExpression when accessing properties [message #871322 is a reply to message #755589] Fri, 11 May 2012 19:11 Go to previous message
Max, where does this code reside? I tried extending AbstractModelInferrer but there doesn't appear to be a method signature "inferJvmModel" that I can override. Perhaps it is because I'm using Xtext 2.2. I too am having the same problem with dangling references through hierarchical path references when the path traverses an entity in the currently-being-edited (dirty) file.
Best wishes,
Brad
Max wrote on Tue, 08 November 2011 16:20
Hey Sebastian,
regards,
Max
Previous Topic:Parsing and generating annotations
Next Topic:Linker does not check type
Current Time: Thu Jul 24 22:13:12 EDT 2025
Powered by FUDForum. Page generated in 0.06716 seconds
