Home » Modeling » M2T (model-to-text transformation) » [acceleo 3.2] queries and nested Sequence of model objects
[acceleo 3.2] queries and nested Sequence of model objects [message #755460] Tue, 08 November 2011 10:18 Go to next message
I'm really trying hard to figure out what I'm doing wrong, but without any success.
I have these 2 queries. Basically, the first one gives direct 'successors' of a node (prio), and the second one will trigger recursive calls to build lists of all successors (direct & indirect).
[query private upper(aPrio : PriorityDeclaration) : Sequence(PriorityDeclaration) =
    let at : AType = aPrio.eContainer(AType) in
        at.priorities->select(e:PriorityDeclaration | aPrio.high = e.low)->asSequence()
[query private uppers(aPrio : PriorityDeclaration) : Sequence(Sequence(PriorityDeclaration)) =
    aPrio.upper()->collectNested(uppers()->union(Sequence{aPrio}))
Problem is that when calling the second query, I get «strange» results: I can call it, but I can't iterate over its result:
[for (it : Sequence(PriorityDeclaration) | prio.uppers())]
[for (u : PriorityDeclaration | it)]
[u.name/]
[/for]
[/for]
Invalid type for iteration at line 172 in Module generateAtomType for block for (it). java.util.ArrayList was not an instanceof PriorityDeclaration.
but if I simply "print" the result:
[it/]
[/for]
I get:
 bla.impl.PriorityDeclarationImpl@8eae04 (name: P2)bla.impl.PriorityDeclarationImpl@a86d12 (name: P1)
So, the objects are here, but I don't really understand what's happening.
Any help greatly appreciated !
Re: [acceleo 3.2] queries and nested Sequence of model objects [message #755508 is a reply to message #755460] Tue, 08 November 2011 11:42 Go to previous messageGo to next message
Hi Marc
OCL did not originally support nested collections, hence the need for
collectNested() to fix the dubious behaviour of collect(). I'm not
convinced that this is sufficient to make nested collections sound
specification-wise.
It is not until OCL 2.3 that will find a hint that
Sequence(Sequence(PriorityDeclaration)) might be valid. There's
certainly insufficient specification to make it consistently valid.
The new pivot binding of Eclipse OCL supports the nested declarations,
but Acceleo is using the Ecore binding where you may find nested
collections a bit suspect, unless Acceleo has worked around bugs.
I recommend using Collections of single part Tuples rather than
Collections of Collections to work around the limitations and perhaps
get better diagnostics when your code rather than the tool is at fault.
Ed Willink
On 08/11/2011 15:18, Marc wrote:
> Hello,
> any success.
> [u.name/]
> [/for]
> [/for]
> [it/]
> [/for]
> I get:
Re: [acceleo 3.2] queries and nested Sequence of model objects [message #755641 is a reply to message #755508] Wed, 09 November 2011 03:17 Go to previous messageGo to next message
Edward Willink wrote on Tue, 08 November 2011 11:42
Hi Marc
Thanks very much for the explanation and the tip.
I'm now trying to understand how to use Tuple inside acceleo, but can't find any example using Tuple and I'm having a hard time understand the various docs... How am I supposed to modify my current queries ? I can't even find how to specify my return type correctly...
[query private uppers(aPrio : PriorityDeclaration) : Sequence(Tuple(Sequence(PriorityDeclaration))) =
[query private uppers(aPrio : PriorityDeclaration) : Sequence(Tuple(n:Sequence(PriorityDeclaration))) =
All combinations found in various documentation won't please acceleo.
Thanks!
Marc
Re: [acceleo 3.2] queries and nested Sequence of model objects [message #755661 is a reply to message #755641] Wed, 09 November 2011 04:04 Go to previous messageGo to next message
I can't use syntax defined in http://help.eclipse.org/indigo/index.jsp?topic=%2Forg.eclipse.ocl.doc%2Fhelp%2Findex.html
In fact, acceleo doesn't know the 'Tuple' type (it won't autocomplete it as it would with Set, Sequence, etc). I checked that I was really using OCL 3.1. I've even reinstalled completely eclipse.
I'm really confused here Sad. Which "OCL reference" should be used while using acceleo 3.2 ? This one:
http://help.eclipse.org/helios/topic/org.eclipse.acceleo.doc/doc/html/ocl_operation_reference.html
does reference 'Tuple', but never explains how to use it (or even declare a Tuple type).
Re: [acceleo 3.2] queries and nested Sequence of model objects [message #755662 is a reply to message #755641] Wed, 09 November 2011 04:04 Go to previous messageGo to next message
Hi Marc
The following OCLinEcore test code has some tuples in it that may
inspire you
class Company
attribute name : String { ordered };
property employees#company : Employee[*] { ordered composes };
attribute size : CompanySizeKind { ordered derived readonly
transient volatile }
derivation:
let table : Set(Tuple(range : Sequence(Integer), size :
CompanySizeKind)) =
Set{Tuple{range = Sequence{0..49}, size =
CompanySizeKind::small},
Tuple{range = Sequence{50..999}, size =
CompanySizeKind::medium},
Tuple{range = Sequence{1000..1000000}, size =
CompanySizeKind::large}}
in table->any(range->includes(employees->size())).size;
Ed Willink
>> Hi Marc
>> perhaps get better diagnostics when your code rather than the tool is
>> at fault.
> Thanks!
> Marc
Re: [acceleo 3.2] queries and nested Sequence of model objects [message #755671 is a reply to message #755662] Wed, 09 November 2011 04:17 Go to previous messageGo to next message
Edward Willink wrote on Wed, 09 November 2011 04:04
Hi Marc
CompanySizeKind)) =
Thanks very much. Alas, I've already seen such examples (I've been googling non-stop since 8h00 this morning...), but acceleo won't let me use 'Tuple' ...
[Some more tests during redaction]
Ok, looks like I can use Tuple, but not as return type of queries.
This works:
[query public testTuple(aPrio : PriorityDeclaration) : OclAny =
let table : Tuple(i : Integer) = Tuple{i=1} in
table
This gives me a 'Invalid Type: Tuple(i: Integer)' on the first line :
[query public testTuple(aPrio : PriorityDeclaration) : Tuple(i : Integer) =
table
Is there something special about return types in acceleo queries ?
[Updated on: Wed, 09 November 2011 04:32] by Moderator
Re: [acceleo 3.2] queries and nested Sequence of model objects [message #755677 is a reply to message #755671] Wed, 09 November 2011 04:47 Go to previous messageGo to next message
I was so close ! I thought I'd be able to cast my Tuple of sequence to and from OclAny, but doing that raises a new error:
org.eclipse.ocl.cst.impl.TupleTypeCSImpl cannot be cast to org.eclipse.ocl.cst.SimpleNameCS
I'm begining to run out of workaround Smile
Re: [acceleo 3.2] queries and nested Sequence of model objects [message #755683 is a reply to message #755677] Wed, 09 November 2011 05:05 Go to previous messageGo to next message
If you need to handle this:
[u.name/]
[/for]
[/for]
You may try to call '->flatten' to obtain a single collection like this:
[for (u : PriorityDeclaration | prio.uppers()->flatten())]
[u.name/]
[/for]
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Google+: stephane.begaudeau
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
Re: [acceleo 3.2] queries and nested Sequence of model objects [message #755684 is a reply to message #755683] Wed, 09 November 2011 05:09 Go to previous messageGo to next message
Unfortunately, my example was over-simple. I can't simply flatten everything. But I'll try, and if flatten() works, maybe I can come up with a workdaround !
Thanks!
Re: [acceleo 3.2] queries and nested Sequence of model objects [message #755690 is a reply to message #755684] Wed, 09 November 2011 05:22 Go to previous messageGo to next message
Hi Marc
Your attempts at using Tuple seem to be introducing more problems than
they solve. Do not use oclAsType or OclAny until you've understood the
problems.
Tuple should just work in Acceleo since Acceleo should just be using
underlying OCL functionality that works.
Therefore find out if
a simple Tuple type can be declared.
a simple TupleLiteral can be defined.
a Tuple variable can be initialised
as pure OCL embedded inside a query, then as declarations of [let/],
[query/] arguments and returns.
Then you'll know whether the bugs are in your understanding, OCL,
Acceleo and may be able to compromise.
Ed Willink
> Thanks!
Re: [acceleo 3.2] queries and nested Sequence of model objects [message #755706 is a reply to message #755690] Wed, 09 November 2011 05:50 Go to previous messageGo to next message
Ed, Marc,
instead of over-complicating the problem and jumping on Tuples (which are useless in Acceleo as I see it, and have a known bug making them unusable in it), let's try and understand the issue.
So "uppers" returns a Collection of Collections, or so the "return type" you define says. Yet I think your return type is wrong :
aPrio.upper() = returns a Sequence. That much is good
aPrio.upper()->collectNested(...) = for each PriorityDeclaration in "aPrio.upper()", call the ... expression. Do not flatten the result.
uppers()->union(Sequence{aPrio}) the "uppers" call returns a Collection of Collection, to which you append a Sequence.
Simplified, here is what you're doing:
Sequence(PriorityDeclaration)->collectNested(Sequence(Sequence(PriorityDeclaration)))
So what you have as a result is :
Sequence(Sequence(Sequence(PriorityDeclaration)))
of course, recursive calls to the "uppers" query will further the nesting level. You potentially get something like
Sequence(Sequence(Sequence(Sequence(Sequence(Sequence(PriorityDeclaration))))))
depending on the number of recursive calls to "uppers". You have to either
1 - re-think what you're doing, or
2 - flatten the result.
[u.name/]
[/for]
[/for]
You can't do that since you have no idea of the actual nesting level of "prio.uppers()". If there was only one recursive call to the "uppers" query, and you actually have a Sequence(Sequence(Sequence()))... Then your code should look like :
[for (it : Sequence(Sequence(PriorityDeclaration)) | prio.uppers())]
[for (u : Sequence(PriorityDeclaration) | it)]
[for (t : PriorityDeclaration | u)]
[t.name/]
[/for]
[/for]
[/for]
I get
Acceleo automatically flattens the collections for the "toString"; this is why you do not "see" the collections here.
Bottom line is : be extra careful when using collectNested. This method does not flatten its result, and you might end up with extraneous levels of nesting within your collection.
Laurent Goubet
Obeo
[Updated on: Wed, 09 November 2011 05:51] by Moderator
Re: [acceleo 3.2] queries and nested Sequence of model objects [message #755756 is a reply to message #755706] Wed, 09 November 2011 09:01 Go to previous messageGo to next message
Laurent, I think you are right (again!). After thinking the algo, I've been modifying the OCL code to "get ir right" but I've only been introducing bugs, in particular because of the collectNested() that I've been using without taking extra care Smile
Thank you both for your precious help that helped me better understand acceleo/OCL.
I'm still confused about the state of Tuple in acceleo, so I'll avoid their use Smile
Thanks again !
Re: [acceleo 3.2] queries and nested Sequence of model objects [message #755762 is a reply to message #755756] Wed, 09 November 2011 09:08 Go to previous messageGo to next message
Marc,
You're welcome Wink.
Marc wrote on Wed, 09 November 2011 09:01
As I hinted, we have known bugs making Tuples non-functional (https://bugs.eclipse.org/bugs/show_bug.cgi?id=340735). It has been known for a long time, yet we have never considered it a priority : we never had to use Tuples in our generators, and no user has ever encountered it until you. I still think that Tuples are somewhat useless ... I may be proven wrong later when some generation requirements force me to use them, but until then I think it only as a complication of the language.
This is only my opinion, and of course we will consider fixing this issue if a user is bitten ... but until then it remains a "future work" Smile.
Laurent Goubet
Obeo
Re: [acceleo 3.2] queries and nested Sequence of model objects [message #755826 is a reply to message #755762] Wed, 09 November 2011 12:15 Go to previous message
I sort of agree; a lot of my usages have ultimately had a better
solution, although they do help disentangling nested Collection
declaration bugs.
My main usages have been in QVTo, where ultimately a Dict can do the job.
In Acceleo, I tend to be forced into custom Java code. Tuples should be
useful for multiple returns, but perhaps this is where the M2T should be
preceeded by a simplifying M2M rather than over-powerful queries and caches.
Tuples will be less useful once OCL supports type constructors.
Ed Willink
Previous Topic:[Jet] Execute alternative from override template
Next Topic:[Acceleo] Standalone application running error
Current Time: Wed Jul 23 08:51:37 EDT 2025
Powered by FUDForum. Page generated in 0.24638 seconds
