Home » Eclipse Projects » Eclipse Platform » Master/slave problem
Master/slave problem [message #755279] Mon, 07 November 2011 17:06 Go to next message
I have view A with a tree viewer and view B with a table viewer.
The tree viewer has 2 levels; on the second levels it list the children(s) on first level. In the same time when a entry of first level is selected in the tree viewer the table viewer from view B is populated with entries. This works correctly so far.
Problem:
When I added support in table viewer for editing support, allowing the user to change the table values I do not see the tree viewer automatically updated.
Question(s):
1. Is there an automated mechanism to signal back to the tree viewer that it needs to be refreshed/updated?
Re: Master/slave problem [message #755397 is a reply to message #755279] Tue, 08 November 2011 05:59 Go to previous messageGo to next message
Am 07.11.11 23:06, schrieb Catalin Gerea:
> Problem:
> Question(s):
See my answer to your other question. You have to call viewer.update(o,null)
The other option is to use Eclipse Databindings Viewer Support.
Tom
Re: Master/slave problem [message #755582 is a reply to message #755397] Tue, 08 November 2011 16:01 Go to previous messageGo to next message
Hello Tom
I have 2 viewers in 2 separate views. In my EditingSupport setValue() method I do call viewer.update(o, null);, but this has effect only on the second view (the details view). The first view (the master view) is not refreshed at all.
As far as I saw Eclipse Databindings Viewer Support is effective only when a single view is involved and not two views. Do you have some kind of snippet for this case?
Re: Master/slave problem [message #755633 is a reply to message #755582] Wed, 09 November 2011 02:21 Go to previous message
No when using SWT-Databinding and both Views show the same underlying
Object they would be updated both!
Tom
Am 08.11.11 22:01, schrieb Catalin Gerea:
> Hello Tom
Previous Topic:Viewer with editing support and properties view
Next Topic:What is the preferred way to to addHelpListener in a FormEditor?
Current Time: Fri Jul 18 17:22:14 EDT 2025
Powered by FUDForum. Page generated in 0.03770 seconds
