Home » Archived » BIRT » Viewer session expired issue(Viewer session expired issue on BIRT reports)
Viewer session expired issue [message #716093] Tue, 16 August 2011 08:52 Go to next message
Hey Jason
I have been intermittently getting an error / alert box during BIRT report loading saying "Viewer session has expired".
I am trying to render the BIRT report on the jsp file using the birt.tld. I use the birt:viewer tag here.
I have seen a lot of posts related to this topic but without any definitive solution.Could you please comment on this error? Please get back if you need any further assistance from me on the same.
Thanks much in anticipation.
Gaurav
Re: Viewer session expired issue [message #716235 is a reply to message #716093] Tue, 16 August 2011 14:01 Go to previous messageGo to next message
Gaurav,
Is there anyway in your code to reproduce the issue where we could test
it? Can you post the code and version of birt you are using?
Jason
On 8/16/2011 8:52 AM, Gaurav wrote:
> Hey Jason
> Regards
> Gaurav
Re: Viewer session expired issue [message #717064 is a reply to message #716235] Fri, 19 August 2011 03:44 Go to previous messageGo to next message
Hey Jason,
Thanks for the reply and apologies for not writing earlier.
This issue is very inconsistent but let me check if I could arrange for a sample code for your team to test.
Best Regards
Gaurav
Re: Viewer session expired issue [message #735223 is a reply to message #716235] Tue, 11 October 2011 05:46 Go to previous messageGo to next message
Hey Jason
Its been long since I wrote on this issue. Unfortunately, this issue still haunts me. The only positive that has come up is I have been able to reproduce this issue, in a not very elegant fashion though.
What I noticed is that I get a "Viewing Session is not available or expired" every time I restart my tomcat server. This is the only consistent manner in which the error shows up.
I have a struts web application running on the apache-tomcat-6.0.18 server which interacts with the BIRT viewer(running on the same server in a different web app) via birt.tld using the frameset mapping.
Would this information help?
Thanks again.
Best Regards
Gaurav
Re: Viewer session expired issue [message #735285 is a reply to message #735223] Tue, 11 October 2011 08:31 Go to previous messageGo to next message
Also after doing a View Source on the screen,I noticed that the report which fails has an incorrect(compared with the folder name in the document folder) value for the field "Constants.viewingSessionId" in the java.
Following is the code from Attributes.jsp of the birt viewer project.
<script type="text/javascript">
// <![CDATA[
Constants.nullValue = '<%= IBirtConstants.NULL_VALUE %>';
// Request attributes
if ( !Constants.request )
Constants.request = {};
Constants.request.format = '<%= ParameterAccessor.getFormat(request) %>';
Constants.request.rtl = <%= ParameterAccessor.isRtl( request ) %>;
Constants.request.isDesigner = <%= ParameterAccessor.isDesigner() %>;
Constants.request.servletPath = "<%= request.getAttribute( "ServletPath" ) %>".substr(1);
<% IViewingSession viewingSession = ViewingSessionUtil.getSession(request);
String subSessionId = null;
if ( viewingSession != null )
subSessionId = viewingSession.getId();
Constants.viewingSessionId = <%= subSessionId!=null?"\"" + subSessionId + "\"":"null" %>;
</script>
[Updated on: Tue, 11 October 2011 09:22] by Moderator
Re: Viewer session expired issue [message #735302 is a reply to message #735285] Tue, 11 October 2011 09:40 Go to previous messageGo to next message
Can you open a bugzilla entry with steps to reproduce and post the bugid
here?
Jason
> java.
> Not sure where this value gets populated from and how.
Re: Viewer session expired issue [message #754345 is a reply to message #735302] Wed, 02 November 2011 05:27 Go to previous messageGo to next message
Any updates on the Bug 342625. The issue I am facing is similar.
Re: Viewer session expired issue [message #755251 is a reply to message #754345] Mon, 07 November 2011 14:41 Go to previous messageGo to next message
Have you tried this with BIRT 3.7?
Jason
Re: Viewer session expired issue [message #755426 is a reply to message #755251] Tue, 08 November 2011 08:23 Go to previous messageGo to next message
Not really, haven't tried 3.7.
Re: Viewer session expired issue [message #755562 is a reply to message #755426] Tue, 08 November 2011 14:49 Go to previous message
Can you try it as a test?
Jason
Previous Topic:Dynamic HTML formatted tooltip in crosstab
Next Topic:Manipulate elements manually over script
Current Time: Sat Jul 26 21:21:07 EDT 2025
Powered by FUDForum. Page generated in 0.04802 seconds
