Home » Modeling » TMF (Xtext) » [Xtext 2.1] Problems extending Xbase
[Xtext 2.1] Problems extending Xbase [message #755505] Tue, 08 November 2011 11:39 Go to next message
Trying to migrate my DSLs from 2.0.1 to 2.1.0, I came across new
validation error, which do not make any sense to me.
Here is an example DSL, which only overrides one Xbase rule with the
exact same content as in Xbase.xtext:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.xbase.Xbase
import "http://www.eclipse.org/xtext/xbase/Xbase"
import "http://www.eclipse.org/xtext/common/JavaVMTypes" as types
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Model:
{Model};
XCastedExpression returns XExpression:
XMemberFeatureCall (=>({XCastedExpression.target=current} 'as')
type=JvmTypeReference)*;
This results in the validation error:
Cannot find compatible feature type in sealed EClass XCastedExpression
from imported package http://www.eclipse.org/xtext/xbase/Xbase:
The existing reference 'type' has an incompatible type 'null'.
The expected type is 'JvmTypeReference'.
Do I do anything wrong or is this a recently introduced bug?
I'd appreciate any hints!
Kai
Re: [Xtext 2.1] Problems extending Xbase [message #755507 is a reply to message #755505] Tue, 08 November 2011 11:42 Go to previous messageGo to next message
I can confirm this problem.
See http://www.eclipse.org/forums/index.php/t/261672/
Re: [Xtext 2.1] Problems extending Xbase [message #755513 is a reply to message #755507] Tue, 08 November 2011 11:46 Go to previous messageGo to next message
Thanks for the link, I have put myself on cc on this bug.
Have you figured out any workaround? Waiting for 2.1.1 does not sound
like an option to me :-S
Am 11/8/2011 5:42 PM, schrieb Goran:
Re: [Xtext 2.1] Problems extending Xbase [message #755516 is a reply to message #755513] Tue, 08 November 2011 11:58 Go to previous messageGo to next message
Unfortunately I don't have not found a workaround.
This is indeed a very nasty bug.
When is the release date for 2.1.1?
[Updated on: Tue, 08 November 2011 11:58] by Moderator
Re: [Xtext 2.1] Problems extending Xbase [message #755518 is a reply to message #755516] Tue, 08 November 2011 12:00 Go to previous messageGo to next message
Isnt this a UI Only Problem. At least the Workflow runs through. ~Christian
Re: [Xtext 2.1] Problems extending Xbase [message #755521 is a reply to message #755518] Tue, 08 November 2011 12:05 Go to previous messageGo to next message
Yes indeed it's a UI only problem. However it's not nice to see a lot of unnecessary errors in the editor when working on a big grammar. Wink
Re: [Xtext 2.1] Problems extending Xbase [message #755526 is a reply to message #755518] Tue, 08 November 2011 12:11 Go to previous messageGo to next message
Right, my problems with the workflow (which worked on 2.0.1) seem to be
unrelated to the issue described here.
So the workaround is to "simply ignore" - that will do, thanks.
Re: [Xtext 2.1] Problems extending Xbase [message #755549 is a reply to message #755513] Tue, 08 November 2011 14:10 Go to previous messageGo to next message
Hi Kai,
we'll release 2.1.1 at the end of this week. You may want to try the
latest nightly build and use the new quickfixes on the validation marker
that you'll get on the package import declaration.
Sebastian
Re: [Xtext 2.1] Problems extending Xbase [message #755551 is a reply to message #755549] Tue, 08 November 2011 14:17 Go to previous messageGo to next message
woow that's really great. Didn't expect it so fast Wink
Re: [Xtext 2.1] Problems extending Xbase [message #755822 is a reply to message #755551] Wed, 09 November 2011 12:03 Go to previous messageGo to next message
On 08.11.11 20:17, Goran wrote:
> woow that's really great. Didn't expect it so fast ;)
Just to keep you posted: The fix was pushed into the repo.
Sebastian
Re: [Xtext 2.1] Problems extending Xbase [message #755939 is a reply to message #755822] Thu, 10 November 2011 04:25 Go to previous messageGo to next message
Sebastian,
I tried the nightly build however I still got the same problem.
Could it be that I didn't do the update correctly?
From a fresh eclipse-SDK-3.7.1-Xtext-2.1.0-linux-gtk-x86_64 distribution I did:
- Install New Software
- Add
- Choose the downloaded nightly build archive tmf-xtext-Update-N201111081203.zip
- select the "TMF Xtext" and on Next it says that an update will be done
- Next, Finish, etc
Still the problem with the same grammar.
Thanks in advance
[Updated on: Thu, 10 November 2011 04:26] by Moderator
Re: [Xtext 2.1] Problems extending Xbase [message #755942 is a reply to message #755939] Thu, 10 November 2011 04:29 Go to previous messageGo to next message
Hi Goran,
I guess this simply didn't yet have the fix - Sebastian's commit was
only done yesterday (i.e. on the 9th, while your nb was from the 8th):
http://git.eclipse.org/c/tmf/org.eclipse.xtext.git/commit/?id=0416ee275fa7b8786e2624b4b489b7eca7a8d646
Kai
Re: [Xtext 2.1] Problems extending Xbase [message #755943 is a reply to message #755942] Thu, 10 November 2011 04:31 Go to previous messageGo to next message
ahhhh Of course!!!
Re: [Xtext 2.1] Problems extending Xbase [message #755957 is a reply to message #755943] Thu, 10 November 2011 05:17 Go to previous messageGo to next message
On 10.11.11 10:31, Goran wrote:
> ahhhh Of course!!!
> Thanks
You may want to use this update site:
https://hudson.eclipse.org/hudson/job/Xtext-nightly-Maintenance/lastSuccessfulBuild/artifact/xtext.p2.repository/
Sebastian
Re: [Xtext 2.1] Problems extending Xbase [message #756005 is a reply to message #755957] Thu, 10 November 2011 08:04 Go to previous messageGo to next message
Thanks Sebastian,
I updated and indeed the problem went away for the XVariableDeclaration rule.
However I still get the same error for the name feature when using the following rule in an extension of Xbase:
FullJvmFormalParameter returns jvmTypes::JvmFormalParameter:
	{FullJvmFormalParameter} final ?= 'final'? parameterType=JvmTypeReference name=ValidID;
~Goran
[Updated on: Thu, 10 November 2011 08:05] by Moderator
Re: [Xtext 2.1] Problems extending Xbase [message #756065 is a reply to message #756005] Thu, 10 November 2011 12:55 Go to previous messageGo to next message
Hi Goran,
I can reproduce this one and will make a fix available soon.
Thanks for the example.
Sebastian
On 10.11.11 14:04, Goran wrote:
> Thanks Sebastian,
> rule.
> following rule:
> ~Goran
Re: [Xtext 2.1] Problems extending Xbase [message #756096 is a reply to message #756065] Thu, 10 November 2011 15:44 Go to previous message
On 10.11.11 18:55, Sebastian Zarnekow wrote:
> Hi Goran,
> Regards,
> Sebastian
The fix is available in next master and maintenance build.
Sebastian
Previous Topic:[xtext2.1] problem implementing custom formatter
Next Topic:Generating "void" methods using JvmTypesBuilder.toMethod.
Current Time: Sat Jul 26 10:28:38 EDT 2025
Powered by FUDForum. Page generated in 0.47934 seconds
