Home » Modeling » TMF (Xtext) » Problem with compatible feature type when redefining variable declaration from xbase
Problem with compatible feature type when redefining variable declaration from xbase [message #755219] Mon, 07 November 2011 12:43 Go to next message
In an attempt to redefine the syntax of variable declarations from Xbase, I came accross the following error message in the JavaVariableDeclarator rule:
Cannot find compatible feature type in sealed EClass XVariableDeclaration from imported package http://www.eclipse.org/xtext/xbase/Xbase: The existing reference 'type' has an incompatible type 'null'. The expected type is 'JvmTypeReference'.
The error message is show in the editor but the project seems to build successfully.
Here is the grammar:
grammar org.xtext.example.mydsl1.MyDsl with org.eclipse.xtext.xbase.annotations.XbaseWithAnnotations
generate myDsl "http://www.xtext.org/example/mydsl1/MyDsl"
import "http://www.eclipse.org/xtext/xbase/Xbase" as xbase
import "http://www.eclipse.org/xtext/common/JavaVMTypes" as jvmTypes
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
JavaVariableDeclarator  returns xbase::XVariableDeclaration:
	type=JvmTypeReference name=ValidID ('=' right=XExpression)? ';'
I can't seem to find the problem. Something with my configuration?
Re: Problem with compatible feature type when redefining variable declaration from xbase [message #755246 is a reply to message #755219] Mon, 07 November 2011 13:56 Go to previous messageGo to next message
I get a similar error for the name feature: "Cannot find compatible type for features" when overriding the FullJvmFormalParameter rule:
FullJvmFormalParameter returns jvmTypes::JvmFormalParameter:
	{FullJvmFormalParameter} final ?= 'final'? parameterType=JvmTypeReference name=ValidID;
Is there something I obviously overlooked?
Re: Problem with compatible feature type when redefining variable declaration from xbase [message #755253 is a reply to message #755219] Mon, 07 November 2011 14:45 Go to previous messageGo to next message
Hi Goran,
please try to trigger a build by changing the manifest of your project
or add the common.types plugin explicitly as a dependency.
Hope that helps,
Sebastian
> successfully.
Re: Problem with compatible feature type when redefining variable declaration from xbase [message #755264 is a reply to message #755253] Mon, 07 November 2011 15:20 Go to previous messageGo to next message
I have common.types already as a dependency.
Triggering a build by changing the manifest did not help. What else can I do?
Re: Problem with compatible feature type when redefining variable declaration from xbase [message #755266 is a reply to message #755264] Mon, 07 November 2011 15:27 Go to previous messageGo to next message
I could reproduce the problem by simply creating a new Xtext project and modifying the MyDsl.xtext as follows:
grammar org.xtext.example.mydsl2.MyDsl with org.eclipse.xtext.xbase.annotations.XbaseWithAnnotations
generate myDsl "http://www.xtext.org/example/mydsl2/MyDsl"
Model:
	greetings+=Greeting*;
Greeting:
	'Hello' name=ID '!';
JavaVariableDeclarator  returns XVariableDeclaration:
	{XVariableDeclaration} writeable?='final'? (type=JvmTypeReference name=ValidID) ('=' right=XExpression)? ';'
Saving the grammar triggers a build and common.types is automatically added to the manifest.
The grammar doesn't make very sense but it demonstrates the same problem.
~Goran
Re: Problem with compatible feature type when redefining variable declaration from xbase [message #755270 is a reply to message #755266] Mon, 07 November 2011 16:03 Go to previous messageGo to next message
I have another question with regard to the example of the 'JavaVariableDeclarator' rule.
In this particular rule I want the value of "writeable" to be false instead of true when the 'final' keyword is present.
This causes an error message when assigning a value to a non-final variable in the editor.
Any tips on how to deal with this?
~Goran
Re: Problem with compatible feature type when redefining variable declaration from xbase [message #755385 is a reply to message #755270] Tue, 08 November 2011 05:37 Go to previous messageGo to next message
I am getting a lot of these problems when inheriting from XBase and redefining rules. It seems to be a bug.
Could anyone reproduce this error message?
Re: Problem with compatible feature type when redefining variable declaration from xbase [message #755387 is a reply to message #755385] Tue, 08 November 2011 05:42 Go to previous messageGo to next message
No it works for me with your example grammar
Re: Problem with compatible feature type when redefining variable declaration from xbase [message #755392 is a reply to message #755387] Tue, 08 November 2011 05:49 Go to previous messageGo to next message
hmmm very strange. I guess I'll do a reinstall.
Re: Problem with compatible feature type when redefining variable declaration from xbase [message #755404 is a reply to message #755392] Tue, 08 November 2011 06:22 Go to previous messageGo to next message
I get the exact strange problem with a fresh install.
I just downloaded the Xtext 2.1.0 Distribution (Indigo) from http://xtext.itemis.com/xtext/language=en/36553/downloads
Creating a new Xtext project and using the grammar I posted previously results in the same error message.
Re: Problem with compatible feature type when redefining variable declaration from xbase [message #755406 is a reply to message #755404] Tue, 08 November 2011 06:27 Go to previous messageGo to next message
Yes downloading a new distro i get the error too
Re: Problem with compatible feature type when redefining variable declaration from xbase [message #755498 is a reply to message #755404] Tue, 08 November 2011 11:33 Go to previous messageGo to next message
Hi Goran,
we'll investigate further and try to tackle the problem for 2.1.1
Thanks for pointing the problem out,
Sebastian
Re: Problem with compatible feature type when redefining variable declaration from xbase [message #755502 is a reply to message #755406] Tue, 08 November 2011 11:38 Go to previous message
Thanks for confirming.
I created a bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=363196
Previous Topic:error "Could not serialize EObject via backtracking"
Next Topic:Formatting guides?
Current Time: Sat Jul 19 00:53:21 EDT 2025
Powered by FUDForum. Page generated in 0.27871 seconds
