Home » Eclipse Projects » Rich Client Platform (RCP) » Unexpected "Unable to find view with id" errors
Unexpected "Unable to find view with id" errors [message #755149] Mon, 07 November 2011 09:26 Go to next message
This is my perspective:
package ru.microdigital.cms.plugins.other.test.framework.ui;
import org.eclipse.ui.IPageLayout;
public class TestFrameworkPerspective implements IPerspectiveFactory {
	public void createInitialLayout(IPageLayout layout) {
		layout.addView("ru.microdigital.cms.plugins.other.test.framework.ui.bundles.ModelsTreeView", IPageLayout.LEFT, 0.33f, IPageLayout.ID_EDITOR_AREA);
		layout.addView("org.eclipse.ui.console.ConsoleView", IPageLayout.BOTTOM, 0.6f, IPageLayout.ID_EDITOR_AREA);
		layout.addView("org.eclipse.ui.views.PropertySheet", IPageLayout.RIGHT, 0.6f, IPageLayout.ID_EDITOR_AREA);
When starting the program, I get warning messages:
!ENTRY org.eclipse.ui 4 4 2011-11-07 18:23:30.835
!MESSAGE Unable to find view with id: org.eclipse.ui.console.ConsoleView, when creating perspective ru.microdigital.cms.plugins.other.test.framework.ui.perspective
!ENTRY org.eclipse.ui 4 4 2011-11-07 18:23:30.842
!MESSAGE Unable to find view with id: org.eclipse.ui.views.PropertySheet, when creating perspective ru.microdigital.cms.plugins.other.test.framework.ui.perspective
and the views don't show up. However, org.eclipse.ui.views and org.eclipse.ui.console, which provide these views, are both in my main UI plugin's dependencies, and there are no messages about failing to resolve them. What could be going wrong here?
Re: Unexpected "Unable to find view with id" errors [message #755227 is a reply to message #755149] Mon, 07 November 2011 13:20 Go to previous messageGo to next message
Could you check that they're in your launch config as well, and do a quick check with the OSGi console (ss)? Although you're right, if your main UI plugin had a require-bundle on those bundles, unless they were optional it should have killed them as well.
PW
Re: Unexpected "Unable to find view with id" errors [message #755345 is a reply to message #755227] Tue, 08 November 2011 03:35 Go to previous messageGo to next message
My launch config contains only one feature, which contains both of them. In OSGi console they are both <<LAZY>> at startup (main plugin is ACTIVE, of course), and `start`ing them doesn't give any error messages.
[Updated on: Tue, 08 November 2011 03:36] by Moderator
Re: Unexpected "Unable to find view with id" errors [message #755352 is a reply to message #755345] Tue, 08 November 2011 03:48 Go to previous messageGo to next message
After terminating the application, deleting workspace data folder, and starting again they are ACTIVE, but the views still don't appear Sad
Re: Unexpected "Unable to find view with id" errors [message #755370 is a reply to message #755352] Tue, 08 November 2011 04:51 Go to previous messageGo to next message
They are even shown by `pt` command:
osgi> pt -v org.eclipse.ui.views
Extension point: org.eclipse.ui.views [from org.eclipse.ui]
Extension(s):
null [from org.eclipse.ui]
   <category>
      name = General
      id = org.eclipse.ui
   </category>
   <view>
      class = org.eclipse.ui.internal.ViewIntroAdapterPart
      category = org.eclipse.ui
      name = Welcome
      id = org.eclipse.ui.internal.introview
   </view>
   <stickyView>
      location = RIGHT
   </stickyView>
null [from org.eclipse.ui.ide]
   <view>
      name = Progress
      icon = $nl$/icons/full/eview16/pview.gif
      class = org.eclipse.ui.internal.progress.ProgressView
      id = org.eclipse.ui.views.ProgressView
   </view>
   <view>
      name = Navigator
      icon = $nl$/icons/full/eview16/filenav_nav.gif
      class = org.eclipse.ui.views.navigator.ResourceNavigator
      id = org.eclipse.ui.views.ResourceNavigator
   </view>
   <view>
      allowMultiple = true
      class = org.eclipse.ui.internal.views.markers.BookmarksView
      icon = $nl$/icons/full/eview16/bkmrk_nav.gif
      id = org.eclipse.ui.views.BookmarkView
      name = Bookmarks
   </view>
   <view>
      class = org.eclipse.ui.internal.views.markers.TasksView
      icon = $nl$/icons/full/eview16/tasks_tsk.gif
      id = org.eclipse.ui.views.TaskList
      name = Tasks
   </view>
   <view>
      class = org.eclipse.ui.internal.views.markers.ProblemsView
      icon = $nl$/icons/full/eview16/problems_view.gif
      id = org.eclipse.ui.views.ProblemView
      name = Problems
   </view>
   <view>
      class = org.eclipse.ui.internal.views.markers.AllMarkersView
      id = org.eclipse.ui.views.AllMarkersView
      name = Markers
   </view>
null [from org.eclipse.m2e.core.ui]
   <category>
      id = org.eclipse.m2e.core.views.repositories
      name = Maven
   </category>
   <view>
      id = org.eclipse.m2e.core.views.MavenRepositoryView
      category = org.eclipse.m2e.core.views.repositories
      class = org.eclipse.m2e.core.ui.internal.views.MavenRepositoryView
      icon = icons/maven_indexes.gif
      name = Maven Repositories
   </view>
null [from org.eclipse.search]
   <view>
      id = org.eclipse.search.SearchResultView
      name = Classic Search
      class = org.eclipse.search.internal.ui.SearchResultView
      icon = $nl$/icons/full/eview16/searchres.gif
   </view>
   <view>
      name = Search
      class = org.eclipse.search2.internal.ui.SearchView
      id = org.eclipse.search.ui.views.SearchView
   </view>
null [from org.eclipse.team.ui]
   <category>
      name = Team
      id = org.eclipse.team.ui
   </category>
   <view>
      name = Synchronize
      icon = $nl$/icons/full/eview16/synch_synch.gif
      fastViewWidthRatio = 0.25
      category = org.eclipse.team.ui
      class = org.eclipse.team.internal.ui.synchronize.SynchronizeView
      id = org.eclipse.team.sync.views.SynchronizeView
   </view>
   <view>
      class = org.eclipse.team.internal.ui.history.GenericHistoryView
      icon = icons/full/eview16/history_view.gif
      id = org.eclipse.team.ui.GenericHistoryView
      name = History
   </view>
null [from org.eclipse.ui.console]
   <view>
      class = org.eclipse.ui.internal.console.ConsoleView
      icon = $nl$/icons/full/cview16/console_view.gif
      name = Console
      id = org.eclipse.ui.console.ConsoleView
   </view>
null [from org.eclipse.ui.views]
   <view>
      class = org.eclipse.ui.views.properties.PropertySheet
      icon = $nl$/icons/full/eview16/prop_ps.gif
      id = org.eclipse.ui.views.PropertySheet
      name = Properties
   </view>
   <view>
      name = Outline
      icon = $nl$/icons/full/eview16/outline_co.gif
      class = org.eclipse.ui.views.contentoutline.ContentOutline
      id = org.eclipse.ui.views.ContentOutline
   </view>
null [from ru.microdigital.cms.plugins.other.test.framework.ui]
   <view>
      class = ru.microdigital.cms.plugins.other.test.framework.ui.bundles.ModelsTreeView
      id = ru.microdigital.cms.plugins.other.test.framework.ui.bundles.ModelsTreeView
      name = Drivers and Models
   </view>
Re: Unexpected "Unable to find view with id" errors [message #755384 is a reply to message #755227] Tue, 08 November 2011 05:33 Go to previous message
The problem was with a wrong activityPatternBinding, which was filtering these views out Embarrassed
Previous Topic:TreeViewer with individual cell control
Next Topic:Problems when deselecting any plugins in target platform
Current Time: Sat Jul 26 08:00:00 EDT 2025
Powered by FUDForum. Page generated in 0.09705 seconds
