Home » Archived » EGL Development Tools » Unable to compile EGL code(NullpointerException on invocation of EGL2IR.main();)
Unable to compile EGL code [message #755076] Mon, 07 November 2011 04:54 Go to next message
As I didn't find any documentation on this, here's the code that I figured out for compiling an EGL file into IR files:
I've added these plug in dependencies:
- org.eclipse.edt.mof.egl
- org.eclipse.edt.mof.eglx.services
- org.eclipse.edt.mof.eglx.persistence.sql
- org.eclipse.ect.compiler
	public static void compileFile(File toCompile, ArrayList<File> eglPathDirectories, File outputDir){
		String[] compileArgs = new String[7];
		int i = 0;
		compileArgs[i++] = SOURCE_PATH;
		StringBuffer eglPath = new StringBuffer();
		for (File file : eglPathDirectories) {
			eglPath.append(file.getAbsolutePath() + ";");
		compileArgs[i++] = eglPath.toString();
		compileArgs[i++] = IR_OUTPUT_PATH;
		outputDir.mkdirs();
		compileArgs[i++] = outputDir.getAbsolutePath();
		compileArgs[i++] = IS_VAG_COMPATIBLE;
		compileArgs[i++] = CLEAN;
		compileArgs[i++] = toCompile.getAbsolutePath();
		EGL2IR.main(compileArgs);
This code is called like this:
		File tocompFile = new File("C:/Users/BVC/TestIndigo/JUnitEGLSimple_EDT/EGLSource/haha/abc.egl");
		ArrayList<File> eglPathDirs = new ArrayList<File>();
		eglPathDirs.add(new File("C:/Users/BVC/TestIndigo/JUnitEGLSimple_EDT/EGLSource"));
		File outputDir = new File("C:/Temp/EGL_Bin_Small_New");
		Compile.compileFile(tocompFile, eglPathDirs, outputDir);
The exception I get is:
Processing Part: abc
Bootstrap initialize...
org.eclipse.edt.compiler.internal.core.builder.BuildException: java.lang.NullPointerException
	at org.eclipse.edt.compiler.AbstractProcessingQueue.process(AbstractProcessingQueue.java:189)
	at org.eclipse.edt.compiler.AbstractProcessingQueue.process(AbstractProcessingQueue.java:154)
	at org.eclipse.edt.compiler.tools.EGLC.compile(EGLC.java:135)
	at org.eclipse.edt.compiler.tools.EGL2IR.compile(EGL2IR.java:89)
	at org.eclipse.edt.compiler.tools.EGL2IR.main(EGL2IR.java:54)
	at org.eclipse.edt.compiler.tools.EGL2IR.main(EGL2IR.java:47)
	at edtapi.Compile.compileFile(Compile.java:43)
	at edtapi.actions.SampleAction.run(SampleAction.java:44)
	at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
	at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
	at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
	at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
	at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
	at org.eclipse.edt.compiler.internal.egl2mof.Egl2MofPart.handleVisitPart(Egl2MofPart.java:414)
	at org.eclipse.edt.compiler.internal.egl2mof.Egl2MofPart.defaultHandleVisitPart(Egl2MofPart.java:383)
	at org.eclipse.edt.compiler.internal.egl2mof.Egl2MofPart.visit(Egl2MofPart.java:216)
	at org.eclipse.edt.compiler.core.ast.Library.accept(Library.java:49)
	at org.eclipse.edt.compiler.internal.egl2mof.Egl2Mof.convert(Egl2Mof.java:160)
	at org.eclipse.edt.compiler.Processor.createIRFromBoundAST2(Processor.java:164)
	at org.eclipse.edt.compiler.Processor.level03Compile(Processor.java:120)
	at org.eclipse.edt.compiler.AbstractProcessingQueue.process(AbstractProcessingQueue.java:171)
	... 37 more
Re: Unable to compile EGL code [message #755107 is a reply to message #755076] Mon, 07 November 2011 07:26 Go to previous messageGo to next message
More info: I'm using the 0.7.M3 build.
Re: Unable to compile EGL code [message #755131 is a reply to message #755107] Mon, 07 November 2011 08:36 Go to previous messageGo to next message
Bart,
Please open a defect in Bugzilla -
https: //bugs.eclipse.org/bugs/enter_bug.cgi?product=EDT
(NOTE: The Eclipse forum won't let me post links yet, so you will need to remove the space between https: and //. This link goes directly to the 'Enter Bug' page for the EDT component)
The component would be Compiler.
Please include all of the information from your post.
-Brian
Re: Unable to compile EGL code [message #755147 is a reply to message #755076] Mon, 07 November 2011 09:19 Go to previous messageGo to next message
The error you are getting could only be caused by our egl.mofar file not being read when the system parts are set up (which means that none of our system parts are initialized).
I am confused because the stack trace you have shown is from an EDT build (your Compiler.compileFile() code does not seem to be on the stack).
When you open the bug, could you provide the entire .log file.
Also, if possible, could you include the plugin that you developed?
Paul
Re: Unable to compile EGL code [message #755184 is a reply to message #755076] Mon, 07 November 2011 10:52 Go to previous message
Bug 363057 is submitted.
Previous Topic:WHY "The type SQLRecord cannot be resolved" ?
Next Topic:how to do @Overrides in EDT
Current Time: Thu Jul 24 21:28:13 EDT 2025
Powered by FUDForum. Page generated in 0.07088 seconds
