Home » Eclipse Projects » Rich Client Platform (RCP) » Preferences persistent across installations
Preferences persistent across installations [message #754839] Fri, 04 November 2011 11:08 Go to next message
I am looking for a way to persist preferences across installations of successive versions of our product. Specifically, we need to "remember" a license key when a new version is installed. This version may or may not be installed to the same directory as the previous version.
Any pointers appreciated.
thanks
Paul C. Meehan
Re: Preferences persistent across installations [message #754841 is a reply to message #754839] Fri, 04 November 2011 11:10 Go to previous messageGo to next message
Ideally preferences stored in the Windows registry or an equivalent store on other OS's would seem to make most sense. A globally unique product ID could be the key in the registry, that way all versions of the product would look-up the same entry?
Re: Preferences persistent across installations [message #754847 is a reply to message #754841] Fri, 04 November 2011 11:32 Go to previous messageGo to next message
Just remembered this can be done with Java Preferences (java.util.prefs.Preferences).
thanks
Re: Preferences persistent across installations [message #755086 is a reply to message #754839] Mon, 07 November 2011 05:44 Go to previous messageGo to next message
W dniu 2011-11-04 16:08, Paul Meehan pisze:
PlatformUI.getPreferenceStore()
and
-data @user.home/.directory/ in Platform arguments
Re: Preferences persistent across installations [message #755622 is a reply to message #754839] Tue, 08 November 2011 22:34 Go to previous messageGo to next message
Why not just store the license key in a file in .eclipse/ in the user's
home directory. There are other plug-ins that exactly do that (Equinox
secure store, ...)
Michael
Re: Preferences persistent across installations [message #755977 is a reply to message #755622] Thu, 10 November 2011 06:22 Go to previous messageGo to next message
Michael Pellaton wrote on Tue, 08 November 2011 22:34
secure store, ...)
Michael
I have moved to the idea of storing the license key in a file.
*Problem is I want the same license key file to be available to all users of a machine*
e.g. on Windows 7, no matter what user you log on as you get the same license key. I can't save to the installation directory root as it's in Program Files on Windows 7 which cannot be written to unless your program is "elevated".
So I need a system wide location to read/write the license file, the users home directory won't cut it as it's not visible to ohter users of the same machine.
Paul C. Meehan
Re: Preferences persistent across installations [message #755986 is a reply to message #755977] Thu, 10 November 2011 07:04 Go to previous messageGo to next message
No Message Body
Re: Preferences persistent across installations [message #755988 is a reply to message #755986] Thu, 10 November 2011 07:06 Go to previous messageGo to next message
I'm thinking the root of C drive might be best location for a system wide license key file. But is it always guaranteed to be mapped on Windows? What about Linux and OSX?
Re: Preferences persistent across installations [message #755991 is a reply to message #755988] Thu, 10 November 2011 07:23 Go to previous messageGo to next message
I cannot speak for non-Windows systems, but I can ensure you, that
storing something like this on the C root directory is a very bad idea
for several reasons.
a) The choice of C doesn't ensure that this is the drive where the
Windows OS is installed.
b) If it is installed there, this drive is often under special write
protection and you shouldn't break that.
On Windows systems you should use something like %ALLUSERSPROFILE% or
%PROGRAMDATA% for that purpose. This exist for exactly that purpose: To
share files among users. Don't forget to assign read access to all users
while installing it.
HTH & Greetings from Bremen,
Daniel Krügler
Re: Preferences persistent across installations [message #756189 is a reply to message #755977] Fri, 11 November 2011 07:42 Go to previous messageGo to next message
AFAIK, most license managers solve the problem like:
- they have a default location (%system%\licdata\xyz.lic)
- this default can be overrridden by an environment
and/or registry setting
(possibly also with more than one directory).
Re: Preferences persistent across installations [message #756190 is a reply to message #755988] Fri, 11 November 2011 07:43 Go to previous messageGo to next message
Also it is a pain in the back if an admin locks the location for a user
to store data there. You need the location configurable by the user.
Re: Preferences persistent across installations [message #756206 is a reply to message #756190] Fri, 11 November 2011 08:34 Go to previous message
Thanks all
Previous Topic:Spreadsheet-like cell Editor problem
Next Topic:How to enable my RCP application to use Automatic updates?
Current Time: Fri Jul 25 20:36:36 EDT 2025
Powered by FUDForum. Page generated in 0.06057 seconds
