Home » Modeling » Epsilon » [Eugenia] Using Phantom Nodes
[Eugenia] Using Phantom Nodes [message #754963] Sat, 05 November 2011 17:33 Go to next message
i got a problem using Phantom Nodes in my Models.
Here is the experimental Code from my .emf file.
@namespace(uri="filesystemtest", prefix="filesystemtest")
@gmf(foo="bar")
package filesystem;
@gmf.diagram(foo="bar")
class Filesystem {
    val Drive[*] drives;
@gmf.node(label="name")
class Drive {
  @gmf.link(label="containsFolder")
  val Folder[*] contentFolder;
  attr String name;
@gmf.node(label="name",phantom ="true")
class Folder {
    @gmf.link(label="containsFile")
    val File[*] contentFile;
    attr String name;
@gmf.node(label = "name",phantom="true")
class File {
    attr String name;
I think its really simple for now. All i want to achieve a tree-like structure for the example on the web pages.
But it doesnt work. The generated code always got 3 errors.
One in :
DriveCanonicalEditPolicy.java and
FileCanonicalEditPolicy.java and
FolderCanonicalEditPolicy.java
The curious thing is, i got the same error when i try to run the example from eclipse sites.
(sorry it is my first post and the forum tells me i cant use links until the fifth post)
Is there anything im doing wrong ?
Greetings
Snakebyte
Re: [Eugenia] Using Phantom Nodes [message #754983 is a reply to message #754963] Sun, 06 November 2011 06:39 Go to previous messageGo to next message
Hi Snakebyte,
That's odd. I've just generated an editor from your .emf snippet and it works for me, with no compile errors at all.
I'd suggest that you remove all the generated code and try again, using the "Eugenia > Generate GMF editor" context menu entry from your .emf file. Sometimes, if you have been tweaking the .emf file again and again, the code generation process will not clean up some obsolete code and it will not compile. It's happened to me a few times.
Antonio
Re: [Eugenia] Using Phantom Nodes [message #754984 is a reply to message #754983] Sun, 06 November 2011 06:47 Go to previous messageGo to next message
Hi Antonio,
thanks for your answer.
I already realized the issue you mentioned.
Because of that, i already create a complete new model from the .emf file. Generating all from the beginning everytime.
I even copy the code, created a complete new project, und rerun the generation.
But the issue is the same.
Any other suggestions ?
Can that be anything about versioning of GMF/EMF/Eclipse/Eugenia ?
Greetings
Re: [Eugenia] Using Phantom Nodes [message #756239 is a reply to message #754984] Fri, 11 November 2011 10:59 Go to previous messageGo to next message
No sugestions ?
Re: [Eugenia] Using Phantom Nodes [message #756338 is a reply to message #756239] Sat, 12 November 2011 03:25 Go to previous messageGo to next message
Given that it works fine for Antonio, I could only suggest trying this
in a fresh Eclipse/GMF/Epsilon installation assembled following the
instructions available here: http://www.eclipse.org/gmt/epsilon/download/
Dimitris
On 11/11/2011 15:59, Snakebyte wrote:
> No sugestions ?
Re: [Eugenia] Using Phantom Nodes [message #758319 is a reply to message #756338] Tue, 22 November 2011 12:39 Go to previous message
Thanks for your suggestions.
When im installing a fresh new eclipse und plugins it works.
Seems to be anything about versioning.
Previous Topic:[EVL] Quick fixes are not found
Next Topic:[Eugenia] Changing Icons / Canvas
Current Time: Thu Jul 24 23:18:20 EDT 2025
Powered by FUDForum. Page generated in 0.04048 seconds
