Home » Language IDEs » C / C++ IDE (CDT) » Enable C99 standard
Enable C99 standard [message #754977] Sun, 06 November 2011 04:52 Go to next message
I need to compile my C program using C99 standard.
I did not find any option in Eclipse about how to modify gcc flags.
Re: Enable C99 standard [message #754996 is a reply to message #754977] Sun, 06 November 2011 09:16 Go to previous messageGo to next message
Il Sun, 06 Nov 2011 10:52:52 +0100, Caterpillar ha scritto:
> I need to compile my C program using C99 standard. I did not find any
Right click the project->Properties then select c/c++ build->settings and
modify the command line pattern
Bye, Leo
Re: Enable C99 standard [message #755011 is a reply to message #754996] Sun, 06 November 2011 13:51 Go to previous messageGo to next message
For other people who will have my same problem:
follow Leo suggestion, and then under C/C++ Build you will find Settings, go to GCC C compiler -> Miscellaneus -> and add the flag -std=c99
[Updated on: Sun, 06 November 2011 13:51] by Moderator
Re: Enable C99 standard [message #755766 is a reply to message #754977] Wed, 09 November 2011 09:23 Go to previous message
[Updated on: Wed, 09 November 2011 11:51] by Moderator
Previous Topic:How to get code completion (MacOS eclipse CDT)
Next Topic:Re: How to get code completion
Current Time: Wed Jul 30 21:50:01 EDT 2025
Powered by FUDForum. Page generated in 0.11328 seconds
