Home » Language IDEs » PHP Development Tools (PDT) » pdt 1.1 freezes eclipse
pdt 1.1 freezes eclipse [message #74990] |
Sat, 05 July 2008 14:55  |
Hi all,
i'm having an issue here with PDT 1.1.0 and eclipse 3.4.0 on Windows Vista.
In some cases eclipse totally freezes for 10-15 seconds when moving
the cursor over a method call on an object, ie someobject->foo().
I've already turned off Occurence Marking, and taken out any additional
libraries in the project preferences, restarted eclipse using the -clean
flag.
Anyone has an idea what might going on during those 10 seconds, or how to
track this problem down ?
Thanks!
Robert Gruendler
Re: pdt 1.1 freezes eclipse [message #75057 is a reply to message #75013] |
Mon, 07 July 2008 06:01   |
Here's the complete log output when starting eclipse with the following
flags:
-console -noexit -consolelog -debug
************************ START LOG ***********************************
Start VM: -Xms40m
-Xmx256m
-XX:MaxPermSize=256m
-Djava.class.path=C:\Users\sobert\Desktop\eclipse\plugins\or g.eclipse.equinox.launcher_1.0.100.v20080509-1800.jar
-os win32
-ws win32
-arch x86
-showsplash
C:\Users\sobert\Desktop\eclipse\\plugins\org.eclipse.platfor m_3.3.100.v200806172000\splash.bmp
-launcher C:\Users\sobert\Desktop\eclipse\eclipse.exe
-name Eclipse
--launcher.library
C:\Users\sobert\Desktop\eclipse\plugins\org.eclipse.equinox. launcher.win32.win32.x86_1.0.100.v20080509-1800\eclipse_1114 .dll
-startup
C:\Users\sobert\Desktop\eclipse\plugins\org.eclipse.equinox. launcher_1.0.100.v20080509-1800.jar
-console
-noexit
-consolelog
-debug
-vm C:\Program Files\Java\jre1.6.0_06\bin\client\jvm.dll
-vmargs
-Xms40m
-Xmx256m
Install location:
file:/c:/Users/sobert/Desktop/eclipse/
Configuration file:
file:/c:/Users/sobert/Desktop/eclipse/configuration/config.i ni loaded
Configuration location:
Framework located:
file:/c:/Users/sobert/Desktop/eclipse/plugins/org.eclipse.os gi_3.4.0.v20080605-1900.jar
Framework classpath:
Splash location:
Debug options:
file:/C:/Users/sobert/Desktop/eclipse/.options not found
osgi> Time to load bundles: 16
Starting application: 1872
!SESSION 2008-07-07 11:51:27.447
eclipse.buildId=I20080617-2000
java.version=1.6.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_AT
Command-line arguments: -os win32 -ws win32 -arch x86 -console
-consolelog -debug
!ENTRY org.eclipse.ui 2 0 2008-07-07 11:51:31.472
!MESSAGE Warnings while parsing the key bindings from the
'org.eclipse.ui.commands' extension point
!SUBENTRY 1 org.eclipse.ui 2 0 2008-07-07 11:51:31.488
!MESSAGE Cannot bind to an undefined command:
plug-in='org.eclipse.tm.terminal', id='org.eclipse.tm.terminal.command1'
!SUBENTRY 1 org.eclipse.ui 2 0 2008-07-07 11:51:31.503
!SUBENTRY 1 org.eclipse.ui 2 0 2008-07-07 11:51:31.534
!SUBENTRY 1 org.eclipse.ui 2 0 2008-07-07 11:51:31.550
!SUBENTRY 1 org.eclipse.ui 2 0 2008-07-07 11:51:31.581
!SUBENTRY 1 org.eclipse.ui 2 0 2008-07-07 11:51:31.597
!SUBENTRY 1 org.eclipse.ui 2 0 2008-07-07 11:51:31.628
!ENTRY org.eclipse.jface 2 0 2008-07-07 11:51:44.888
!MESSAGE Keybinding conflicts occurred. They may interfere with normal
accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2008-07-07 11:51:44.919
!MESSAGE A conflict occurred for CTRL+I:
Binding(CTRL+I,
ParameterizedCommand(Command(org.eclipse.wst.sse.ui.format.a ctive.elements,Format
Active Elements,
Format active elements,
Category(org.eclipse.ui.category.edit,Edit,null,true),
LegacyHandlerWrapper(ActionHandler(action=org.eclipse.ui.texteditor.TextOperationAction@e6f8d7)),
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.php.ui.phpEditorScope,,,system)
Binding(CTRL+I,
Active Elements,
,,true),null),
org.eclipse.wst.sse.ui.structuredTextEditorScope,,,system)
!SUBENTRY 1 org.eclipse.jface 2 0 2008-07-07 11:51:45.106
!MESSAGE A conflict occurred for CTRL+SHIFT+F:
Binding(CTRL+SHIFT+F,
ParameterizedCommand(Command(org.eclipse.wst.sse.ui.format.d ocument,Format,
Format selection,
LegacyHandlerWrapper(ActionHandler(action=org.eclipse.ui.texteditor.TextOperationAction@1db2215)),
,,true),null),
Format selection,
,,true),null),
!SUBENTRY 1 org.eclipse.jface 2 0 2008-07-07 11:51:45.278
!MESSAGE A conflict occurred for CTRL+SHIFT+P:
Binding(CTRL+SHIFT+P,
ParameterizedCommand(Command(org.eclipse.php.ui.editor.goto. matching.bracket,Go
to Matching Bracket,
Moves the cursor to the matching bracket,
Category(org.eclipse.ui.category.navigate,Navigate,null,true ),
LegacyHandlerWrapper(ActionHandler(action= org.eclipse.php.internal.ui.actions.GotoMatchingBracketActio n @19ac2e3)),
,,true),null),
ParameterizedCommand(Command(org.eclipse.wst.sse.ui.goto.mat ching.bracket,Matching
Bracket,
Go to Matching Bracket,
org.eclipse.wst.sse.ui.StructuredTextEditor$GotoMatchingBracketHandler@1710374,
,,true),null),
!SUBENTRY 1 org.eclipse.jface 2 0 2008-07-07 11:51:45.465
!MESSAGE A conflict occurred for CTRL+SHIFT+/:
Binding(CTRL+SHIFT+/,
ParameterizedCommand(Command(org.eclipse.php.ui.edit.text.ad d.block.comment,Add
Block Comment,
Enclose the selection with a block comment,
Category(org.eclipse.php.ui.category.source,Source,PHP
Source Actions,true),
LegacyHandlerWrapper(ActionHandler(action= org.eclipse.php.internal.ui.actions.AddBlockCommentActionDel egate @99c4cc)),
,,true),null),
ParameterizedCommand(Command(org.eclipse.wst.sse.ui.add.bloc k.comment,Add
Block Comment,
Add Block Comment,
,,true),null),
!SUBENTRY 1 org.eclipse.jface 2 0 2008-07-07 11:51:45.637
!MESSAGE A conflict occurred for F3:
Binding(F3,
ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.ja va.open.editor,Open
Declaration,
Open an editor on the selected element,
,,true),null),
org.eclipse.ui.contexts.window,,,system)
Binding(F3,
ParameterizedCommand(Command(org.eclipse.php.ui.edit.text.Op enDeclaration,Open
Declaration,
Open the declaration of the selected element,
LegacyHandlerWrapper(ActionHandler(action=org.eclipse.php.internal.ui.actions.OpenDeclarationAction@147480e)),
,,true),null),
Binding(F3,
ParameterizedCommand(Command(org.eclipse.wst.sse.ui.open.fil e.from.source,Open
Selection,
Open an editor on the selected link,
LegacyHandlerWrapper(ActionHandler(action= org.eclipse.wst.sse.ui.internal.hyperlink.OpenHyperlinkActio n @cbbdf3)),
,,true),null),
!SUBENTRY 1 org.eclipse.jface 2 0 2008-07-07 11:51:45.902
!MESSAGE A conflict occurred for CTRL+SHIFT+\:
Binding(CTRL+SHIFT+\,
ParameterizedCommand(Command(org.eclipse.php.ui.edit.text.re move.block.comment,Remove
Block Comment,
Remove the block comment enclosing the selection,
LegacyHandlerWrapper(ActionHandler(action= org.eclipse.php.internal.ui.actions.RemoveBlockCommentAction Delegate @23af64)),
,,true),null),
ParameterizedCommand(Command(org.eclipse.wst.sse.ui.remove.b lock.comment,Remove
Block Comment,
Remove Block Comment,
,,true),null),
Application Started: 19141
!ENTRY org.eclipse.wst.common.project.facet.core 4 0 2008-07-07 11:51:48.367
!MESSAGE Project facet jst.web has not been defined. It is used in
plugin org.eclipse.wst.jsdt.web.core.
!ENTRY org.eclipse.wst.common.project.facet.core 4 0 2008-07-07 11:51:48.507
*************************** END LOG ***********************************
This is the output of eclipse during startup, without any interaction.
There is no more output when moving the cursor over a method call,
resulting in the already mentioned freeze. The freeze only occurs upon
certain method calls of external library objects, in my case falls
to objects of the Doctrine ORM library, or calls to objects of the
symfony library.
Eclipse recovers from the freeze after about 10-15 seconds, there is
no more debug output afterwards.
Again, my system specs:
Windows Vista Ultimate SP1 32 bit
Eclipse 3.4.0
PDT 1.1.0
I hope this is somewhat useful.
best
-robert
David Muir schrieb:
> I've been having the same issue. I'll try to get a full report tomorrow.
> Is there a bug already open for this issue? I've looked a couple of
> times this past week, but couldn't find anything. Also, when will the
> first milestone be out? The wiki says today, but the front page says 2
> months ago...
Re: pdt 1.1 freezes eclipse [message #76504 is a reply to message #76086] |
Sun, 20 July 2008 09:25   |
I've tested the latest integration build, but the bug is still there.
Somehow i have the feeling that it might have to do something with my
setup here, as this bug pretty much makes pdt unusable and no one else
seems to have this problem.
I'll try it on a Win XP machine as ASAP, maybe it has something to do
with vista.
Michael Spector schrieb:
> You are absolutely right! New PDT build, which is based on new DLTK
> integration build is here:
> http://download.eclipse.org/tools/pdt/downloads/release.php? release=N20080716
> Tianon Gravi wrote:
>> New DTLK Integration build is released. Don't know if the issue is
>> fixed, but it's worth a shot.
>> Michael Spector wrote:
>>> One important fix is still not committed to the CVS, since it's
>>> waiting for the next integration release of DLTK (otherwise nightly
>>> build will not succeed). I'm sure fixed version will be built in a
>>> couple of days.
>>> Robert Gruendler wrote:
>>>> Tried it with the new nightly (org.eclipse.php_feature-N20080709),
>>>> still the same problem.
>>>> Here's a code snippet where the bug occurs:
>>>> $q = Doctrine_Query::create()
>>>> ->from('User u' )
>>>> ->where ('u.id >=20000');
>>>> $this->user = $q->fetchArray();
>>>> If the cursor is put in any of these lines, it freezes for a couple
>>>> of seconds.
>>>> Roy Ganor schrieb:
>>>>> well, the last nightly is identical to the integration build so the
>>>>> problem was not fixed there. For some reason the nightly was not
>>>>> produced (try the next nightly).
Re: pdt 1.1 freezes eclipse [message #76918 is a reply to message #76886] |
Thu, 24 July 2008 05:58   |
Originally posted by: kkunjas.gmail.com
Na Thu, 24 Jul 2008 02:10:41 +0000, David Muir napisao:
> Looks like the issue has been fixed with the latest integration build. I
> might have also goofed before by installing the DLTK runtime, but not
> the SDK.
> Anyway, looks like the crazy annoying 10 second wait has now been
> reduced to a 1-2 second wait for content assist, and it no longer locks
> up when you mouse-over a object method. Would be nice if it was still
> faster with the content assist, but it's good enough to work with. Good
> job guys! :-)
hm, i'm still having the same problem, even worse now. I have tried
several clean installs with latest integration and nightlies, and still no
luck.
for me, eclipse freezes on selecting with mouse on php code...
btw. how do you install on ganyamede?
i took latest j2ee 34.4 build, and just added latest dltk and pdt ( as
stated on integration build page)
Re: pdt 1.1 freezes eclipse [message #77155 is a reply to message #77124] |
Fri, 25 July 2008 07:37   |
Na Thu, 24 Jul 2008 23:11:47 +0000, David Muir napisao:
> I installed:
> GEF 3.4 SDK version from Ganymede update site. WTP 3.0 SDK version from
> I then downloaded:
> The latest DLTK Core Frameworks Integration 1.0 SDK version from DLTK
> download page.
> The latest PDT Integration build from PDT download page.
> To install DLTK and PDT, unzip the packages into a folder, and add this
> as a local update site in the update manager. I installed DLTK first and
> then PDT (not sure if it matters though).
done exactly that several times, and it's still the same ( a tried a amd64
build of eclipse at home, and same problems occure)
> Once installed, make sure you do a clean rebuild of your projects.
> (Projects->Clean...)
i did a clean build now and now i get "only" about 5 sec freeze when
typing $, >, and selecting text in editor with mouse.
a bit better, but still far from expected...
Thanks for Projects->clean, i didn't know that i must do this on every
upgrade...
Re: pdt 1.1 freezes eclipse [message #77216 is a reply to message #77155] |
Sun, 27 July 2008 03:36   |
Can you tell how many open projects do you have in your workspace, and
what is the estimation of how many PHP line numbers are there?
Do you use some known PHP framework?
Thanks!
>> I installed:
>> I then downloaded:
>> download page.
> upgrade...
Re: pdt 1.1 freezes eclipse [message #78493 is a reply to message #77216] |
Mon, 18 August 2008 07:23  |
Na Sun, 27 Jul 2008 10:36:14 +0300, Michael Spector napisao:
it ranges from 50 - 2000 or even more, depends on the file opened.
I have only one php project open at the time ( but the effect is the same
even if several are opened)
yep, i'm using symfony, propel, doctrine
> Thanks!
np
btw. with latest dltk ( 1.0m1) and latest nightly the freezes are minimal
( around 1 sec, or less) so thing are looking better now, and i can finaly
actualy use PDT ;)
Current Time: Thu Jul 24 21:38:07 EDT 2025
Powered by FUDForum. Page generated in 0.09197 seconds
