JSDAI install problem [message #754713] |
Thu, 03 November 2011 20:28  |
I'm trying to install and use JSDAI (www.jsdai.net) under ubuntu 11.o4
with Eclipse Ganimede to no avail. The installation message I receive
when installing the plugin is,
Cannot complete the install because one or more required items could not
be found.
Software being installed: JSDAI Express-G Editor 4.3.0.v201010271301
(net.jsdai.express_g.feature.feature.group 4.3.0.v201010271301)
Missing requirement: JSDAI Common 4.1.6.v201010271301 (net.jsdai.common
4.1.6.v201010271301) requires 'bundle org.eclipse.ui [3.6.0,4.0.0)' but
it could not be found
Cannot satisfy dependency:
From: JSDAI ExpressDoc 4.1.6.v201010262121 (net.jsdai.express_doc
4.1.6.v201010262121)
To: bundle net.jsdai.common [4.1.0,5.0.0)
To: net.jsdai.impexpWizards [4.1.3.v200806021255]
From: JSDAI ExpressDoc Import/Export Wizard declarations
4.1.3.v200806021255 (net.jsdai.impexpWizards 4.1.3.v200806021255)
To: bundle net.jsdai.express_doc [4.1.0,5.0.0)
Would anyone know how to help me, please?
Thanks in advance,
Andre Luiz
Re: JSDAI install problem [message #758136 is a reply to message #756782] |
Mon, 21 November 2011 22:18   |
I'm trying to install packages in Eclipse Indigo under Ubuntu 11.04 as
you suggested and receive this error message,
be found.
Software currently installed: Shared profile 1.0.0.1316138634362
(SharedProfile_epp.package.java 1.0.0.1316138634362)
Missing requirement: Shared profile 1.0.0.1316138634362
(SharedProfile_epp.package.java 1.0.0.1316138634362) requires
'org.maven.ide.eclipse [1.0.100.20110804-1717]' but it could not be found
BTW, I removed all pre-installed eclipse because it was the Ganymede
version. Now, it is installed under /usr/lib/eclipse_indigo/eclipse as
shown below,
andreltr@stech:~$ cd /usr/lib/eclipse
andreltr@stech:/usr/lib/eclipse$ ls
plugins
andreltr@stech:/usr/lib/eclipse$ ls ../eclipse_indigo/
eclipse
andreltr@stech:/usr/lib/eclipse$ ls ../eclipse_indigo/eclipse/
about_files dropins eclipse.ini libcairo-swt.so readme
about.html eclipse epl-v10.html notice.html
artifacts.xml eclipse_indigo features p2
configuration eclipse_indigo~ icon.xpm plugins
Nothing can be installed any longer. Would anyone be able to help me
please?
Thanks in advance,
Andre Luiz
On Mon, 14 Nov 2011 22:54:25 -0600, David Wegener wrote:
> On 11/13/2011 07:14 PM, Andre Luiz Tietbohl Ramos wrote:
>> Hello,
>> Thanks for the response. I installed Indigo Service Release 1 and
>> received the following error,
>> not be found.
>> found
>> I have the following eclipse_indigo executable script,
>> #!/bin/sh
>> # work around for e#290395 / LP: #458703 #
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=290395 #
>> https://bugs.launchpad.net/bugs/458703 export GDK_NATIVE_WINDOWS=true
>> export MOZILLA_FIVE_HOME="/usr/lib/xulrunner-$(/usr/bin/xulrunner-1.9.2
>> -- gre-version)"
>> #ECLIPSE=/usr/lib/eclipse/eclipse
>> ECLIPSE=/usr/lib/eclipse_indigo/eclipse/eclipse
>> inject_update_site(){
>> if [ ! -e "$1" ] ; then
>> echo "W: Cannot find $1" 2>&1
>> return 1
>> fi
>> cat ->>"$1"<<EOF
>> repositories/http\:__download.eclipse.org_releases_galileo/enabled=true
isSystem=false
>> nickname=Galileo Update Site
>> repositories/http\:__download.eclipse.org_releases_galileo/uri=http\://
>> download.eclipse.org/releases/galileo/ EOF
>> if [ ! -d ~/.eclipse/ ] ; then
>> $ECLIPSE -clean -initialize || exit $? settings=`echo
>> ~/.eclipse/org.eclipse.platform_*/p2/
>> org.eclipse.equinox.p2.engine/profileRegistry/
>> PlatformProfile.profile/.data/.settings/`
>> if [ ! -d "$settings" ] ; then
>> echo "W: Cannot inject update-sites, cannot find the correct
>> config." 2>&1
>> else
>> ( inject_update_site "$settings/
>> org.eclipse.equinox.p2.metadata.repository.prefs"&& \
>> org.eclipse.equinox.p2.artifact.repository.prefs"&& \
>> echo "I: Injected update sites" ) || echo "W: Could not inject
>> update sites." 2>&1
>> fi
>> fi
>> exec $ECLIPSE "$@"
>> Any further help greatly appreciated,
>> Andre Luiz
> The launch script indicates that you installed Eclipse from the Ubuntu
> repositories. Don't do this. You will have problems installing
> additional software.
> Uninstall the Eclipse and download a package directly from the Eclipse
> download page.
Re: JSDAI install problem [message #758363 is a reply to message #758136] |
Tue, 22 November 2011 16:24  |
On 11/21/2011 09:18 PM, Andre Luiz Tietbohl Ramos wrote:
> Hello,
> be found.
Eclipse seems to be looking for the Maven plugin. I'm not sure if it is
required by something you are trying to install or something already
installed.
You could try to install the Maven plugin from the Indigo update site.
The version referenced appears to be the current version on the update site.
> shown below,
> plugins
> eclipse
> please?
> Thanks in advance,
> Andre Luiz
>>> Hello,
>>> not be found.
>>> found
>>> #!/bin/sh
>>> -- gre-version)"
>>> return 1
>>> fi
>>> cat ->>"$1"<<EOF
> isSystem=false
>>> config." 2>&1
>>> else
>>> update sites." 2>&1
>>> fi
>>> fi
>>> exec $ECLIPSE "$@"
>>> Andre Luiz
>> download page.
FUDForum. Page generated in 0.16881 seconds
