Create a new Aspect wizard giving error in AJDT. [message #657499] |
Wed, 02 March 2011 21:13  |
I have installed AJDT plugin(2.1.1) on eclipse 3.6. I'm trying to apply the AspectJ functionality on my existing code. ADJT is installed correctly and working perfectly. It is able to understand all the existing Aspects etc. Excellient !!
But, when I try to create a new aspect , it is giving an error message asking to view the log. In the log, following is the error.... . Did anyone get this error, is this a bug ? Please suggest. Cannot find any help on the web.
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:421)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 1008)
at org.eclipse.jdt.internal.ui.wizards.NewElementWizard.perform Finish(NewElementWizard.java:133)
at org.eclipse.ajdt.internal.ui.wizards.NewAspectCreationWizard .performFinish(NewAspectCreationWizard.java:60)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:811)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:430)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:234)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHa ndler(WizardHandler.java:254)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(Wizar dHandler.java:274)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:241)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(C ommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
at org.eclipse.ajdt.internal.ui.wizards.AJNewTypeWizardPage.ajc $interMethod$org_eclipse_ajdt_internal_ui_wizards_AJNewTypeW izardPage$org_eclipse_ajdt_internal_ui_wizards_NewTypeWizard Page$createAJType(AJNewTypeWizardPage.aj:268)
at org.eclipse.ajdt.internal.ui.wizards.NewTypeWizardPage.ajc$i nterMethodDispatch2$org_eclipse_ajdt_internal_ui_wizards_AJN ewTypeWizardPage$createAJType(NewTypeWizardPage.java:1)
at org.eclipse.ajdt.internal.ui.wizards.AJNewTypeWizardPage.ajc $interMethodDispatch1$org_eclipse_ajdt_internal_ui_wizards_A JNewTypeWizardPage$org_eclipse_ajdt_internal_ui_wizards_NewT ypeWizardPage$createAJType(AJNewTypeWizardPage.aj)
at org.eclipse.ajdt.internal.ui.wizards.NewTypeWizardPage.creat eType_aroundBody7$advice(NewTypeWizardPage.java:450)
at org.eclipse.ajdt.internal.ui.wizards.NewTypeWizardPage.creat eType(NewTypeWizardPage.java:1)
at org.eclipse.ajdt.internal.ui.wizards.NewAspectCreationWizard .finishPage(NewAspectCreationWizard.java:75)
at org.eclipse.jdt.internal.ui.wizards.NewElementWizard$2.run(N ewElementWizard.java:117)
at org.eclipse.jdt.internal.core.BatchOperation.executeOperatio n(BatchOperation.java:39)
at org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaMod elOperation.java:728)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1975)
at org.eclipse.jdt.core.JavaCore.run(JavaCore.java:4777)
at org.eclipse.jdt.internal.ui.actions.WorkbenchRunnableAdapter .run(WorkbenchRunnableAdapter.java:106)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
Root exception:
at org.eclipse.ajdt.internal.ui.wizards.AJNewTypeWizardPage.ajc $interMethod$org_eclipse_ajdt_internal_ui_wizards_AJNewTypeW izardPage$org_eclipse_ajdt_internal_ui_wizards_NewTypeWizard Page$createAJType(AJNewTypeWizardPage.aj:268) at org.eclipse.ajdt.internal.ui.wizards.NewTypeWizardPage.ajc$i nterMethodDispatch2$org_eclipse_ajdt_internal_ui_wizards_AJN ewTypeWizardPage$createAJType(NewTypeWizardPage.java:1)
FUDForum. Page generated in 0.05050 seconds
