Home » Modeling » OCL » EEnumLiteral and Integer
EEnumLiteral and Integer [message #754631] Thu, 03 November 2011 12:42 Go to next message
In Ecore, EEnumLiterals have an associated numeric value.
How can this value be obtained (as Integer) in an OCL expression defined for the Ecore model which defines an EEnum ?
Vlad
Re: EEnumLiteral and Integer [message #754691 is a reply to message #754631] Thu, 03 November 2011 16:55 Go to previous messageGo to next message
You cannot do this directly; it's contrary to the UML philosophy of
Enumerations.
If you just want to establish an order then you can use the index in the
enumerations.
e.g.
MyEnumeration.allInstances()->asOrderedSet()->indexOf(MyEnumeration::MyEnumerationLiteral)
NB the asOrderedSet() is because allInstances is specified to return a
Set rather than an OrderedSet. The implementation happens to be an
OrderedSet so ->asOrderedSet() does a type-cast. [This could be changed
in a future OMG OCL specification, except that this allInstances() is
inconsistent with Classifier.allInstances().
MyEnumeration.ownedLiterals()->indexOf(MyEnumeration::MyEnumerationLiteral)
is a more likely future (that should work now with the new pivot rather
than Ecore binding).]
If you really want the Ecore value, you must provide a Java helper
function. The library Ecore binding is not easy to extend, so I would
recommend defining a helper in some arbitrary class so that you can do
myArbitraryClass.getMyEnumerationValue(myEnumerationLiteral)
and invoke the one line hand-coded Java in the arbitrary class.
[The new pivot binding has a modelled library so you could add an
Enumeration::value derived property mapped to a Java class that would do
what you want for any Enumeration.]
Ed Willink
On 03/11/2011 17:42, Vlad Gheorghe wrote:
> Hello,
> Regards,
> Vlad
Re: EEnumLiteral and Integer [message #754960 is a reply to message #754691] Sat, 05 November 2011 17:10 Go to previous messageGo to next message
Thank you for the response - informative, as always.
I tried to implement the utility class, but I couldn't find a way to define a class-scope operation in EMF (that is, static method in Java). That means that I need to have an instance of the utility class in order to call the helper operation from OCL.
Am I missing something here ?
(I know this belongs to the EMF forum, but I feel that the solution is trivial...)
Vlad Gheorghe
Re: EEnumLiteral and Integer [message #754965 is a reply to message #754960] Sat, 05 November 2011 17:57 Go to previous message
Indeed you cannot define a cklass scope methosd.
Define an instnace scpe method in which the 'self' is never actually used.
Ed Willink
> trivial...)
> Regards,
> Vlad Gheorghe
Previous Topic:How to get the elements of OCL document (.ocl)
Next Topic:Validate an ecore model with ocl constraint from a standalone application
Current Time: Wed Nov 05 14:01:21 EST 2025
Powered by FUDForum. Page generated in 0.03461 seconds
