Home » Eclipse Projects » Virgo » Virgo Kernel and Felix(use of felix in Virgo Kernel)
Virgo Kernel and Felix [message #754243] Tue, 01 November 2011 11:44 Go to next message
Yesterday I downloaded Virgo Kernel and started using it. When I ran "help" from the osgi> console, I saw that Virgo Kernel uses a number of console commans from the Felix project. How are Virgo Kernel and Felix related? Does Virgo Kernel use both/either Equinox and Felix?
My guess was that Virgo Kernel uses the console commands from felix that get thier information from the standard osgi set of interfaces. Is this the limit to the use of Felix in Virgo, or is it larger?
Re: Virgo Kernel and Felix [message #754271 is a reply to message #754243] Tue, 01 November 2011 13:44 Go to previous messageGo to next message
Virgo uses the Equinox Incubator Console [1], based on Apache Felix Gogo shell. Gogo is is the reference implementation of RFC 147 - the Command Line Interface specification in OSGi. Besides Gogo the Equinox shell has ssh and telnet, JAAS based user authentication and tab completion.
Some Felix components were used in previous versions, but currently Virgo is entirely based on Equinox/Eclipse components, except Gogo of course. It should be possible to use the corresponding Felix equivalents that implement the same part of the OSGi spec (event admin for instance).
[1] http://eclipse.org/equinox/incubator/console/index.php
Re: Virgo Kernel and Felix [message #754274 is a reply to message #754271] Tue, 01 November 2011 14:04 Go to previous message
Just a small clarification: the spec work on RFC 147 was terminated because it was agreed there was no need for it now that Gogo is generally usable. So Gogo is not an official Reference Implementation of an OSGi spec, although from a user's perspective, it's pretty close to that.
Previous Topic:Precompiled JSPs full of ${...}
Next Topic:Problem with org.eclipse.virgo.web.dm;
Current Time: Thu Jul 24 22:31:42 EDT 2025
Powered by FUDForum. Page generated in 0.33160 seconds
