Home » Modeling » M2T (model-to-text transformation) » missing org.eclipse.jet(After installing the JET SDK)
missing org.eclipse.jet [message #754232] Tue, 01 November 2011 10:29 Go to next message
I installed the JET SDK via Helios update site, ie. download.eclipse.org/releases/helios. After completion, I restarted Eclipse, and proceeded to create a JET Transformation Project via File->New. The project has several errors all relating to the fact it could not find "org.eclipse.jet" as indicated by the plugin dependencies error marker. As a result, JET2Writer, JET2Context, JET2Template, etc. are all not found. I would have thought this plugin to be with the SDK?
Re: missing org.eclipse.jet [message #754255 is a reply to message #754232] Tue, 01 November 2011 12:19 Go to previous message
Murray:
I'm not sure what is going on. I have just done a quick smoke test that verified that I was able to install JET from the Helios site. I used:
* The Eclipse 3.6.2 SDK ZIP
* an IBM JVM (1.6-based)
* On the Helios update site, I selected on JET SDK, and let p2 find everything else (parts of EMF and UML2)
I then did a successful smoke test: created a JET project and ran it against an input.
One suggestion. You are reporting compile errors, in particular, a missing org.eclipse.jet plug-in. Is it possible that org.eclipse.jet is not in your target platform?
Paul
Previous Topic:[acceleo 3.2] dependency problem with jar
Next Topic:Acceleo: Get an Activity from Operation
Current Time: Sun Jul 20 05:36:06 EDT 2025
Powered by FUDForum. Page generated in 0.03803 seconds
