Home » Eclipse Projects » GEF » Command Stack change and save action(Command Stack change and save action)
Command Stack change and save action [message #754168] Tue, 01 November 2011 03:29 Go to next message
hello friends,
i have an gef based editor the changes in the model causes the isdirty state of the editor to become true and enables the save action .
i have an figure in an editpart for which i have added mouse listener , the mouse presssed event of the listener will causes the figure to resize . the resize is done using an class the executes the command class and i execute it from the editpart by calling the getcommandstack method of the editor instance .
inSpireDesignerEditor.getDomain().getCommandStack().execute( cmd );
i have two problems now .
1. the undo of the command that executed is not working
2. as the figure resizes using the mouse event , the editor save button is not getting enabled , but the is dirty property is true. how to manually eneble the save action from an editpart
[Updated on: Tue, 01 November 2011 03:29] by Moderator
Re: Command Stack change and save action [message #754171 is a reply to message #754168] Tue, 01 November 2011 03:48 Go to previous messageGo to next message
The execution of the command on the stack looks good so far. Concerning your problems,
1) you should check that your command is undoable (canUndo() has to return true) and that you implement undo() properly
2) if you have finished 1) and it still does not work, you should ensure that the save action gets updated when changes to the command stack occur. GraphicalEditor maintains a list of actions (stackActions) for this purpose, which is updated in case the command stack changes. If you are inheriting from GraphicalEditor, make sure UndoAction is contained within this list (which it should in case you have not overwritten createActions() or you have overwritten it with a call to the super implementation). If you are not inheriting from GraphicalEditor, you will have to update the action from within a command stack listener yourself.
Re: Command Stack change and save action [message #754174 is a reply to message #754171] Tue, 01 November 2011 04:06 Go to previous messageGo to next message
hi thanks ,
i have overriden the canundo method and returned true like this
* @see org.eclipse.gef.commands.Command#canUndo()
public boolean canUndo()
// TODO Auto-generated method stub
return true;
still its not working .
my class extends abstractgraphicaleditpart and not graphicaleditor. so you told If you are not inheriting from GraphicalEditor, you will have to update the action from within a command stack listener yourself.
how to update the actions . could you please post in the code?
Re: Command Stack change and save action [message #755563 is a reply to message #754174] Tue, 08 November 2011 14:50 Go to previous message
Take a look into GraphicalEditor#init(IEditorSite, IEditorInput), where the editor gets registered as command stack listener, and within the GraphicalEditor#commandStackChanged(EventObject) method, which in turn gets called upon changes. It calls updateActions(List) to update all actions that depend on changes being made to the command stack.
Previous Topic:Gef Connection source and endpoint location update
Next Topic:ScrollableThumbnail Nullpointer
Current Time: Fri Jul 25 11:08:18 EDT 2025
Powered by FUDForum. Page generated in 0.25464 seconds
