implementing into java [message #753811] |
Fri, 28 October 2011 17:13  |
Hi , im student of software development and Im havinf troubles to solve this ! Im kind of stack
Algorithm 4.1. PrefixAverages1(X)
Input: X- a 1-D numerical array of size n
1) Let A = an empty 1-D numerical array of size n
2) For i = 0 to n-1
3) Let s = X[0]
4) For j = 1 to i
5) Let s = s + X[j]
6) End For
7) Let A[i] = s /(i+1)
End For
Output: An n-element array A of numbers such that A[i]
is the average of elements X[0],X[1], ... ,X[i]
Algorithm 4.2. PrefixAverages2(X)
2) Let s = 0
3) For i = 0 to n-1
4) Let s = s + X[i]
5) Let A[i] = s / (i+1)
6) End For
1: Computational Complexity
1) What is the difference between the two algorithms? Read these two algorithms carefully. If necessary, it might be helpful to set up an array yourself and apply these two algorithms on it by running through them by hand for small size values of n.
2) Analyse both algorithms by counting primitive operations and derive T(n) for both algorithms. What is the time complexity (Big-Oh, O(n)) of each algorithm? Which one is the most efficient?
2: Implementation
Implement the two algorithms in Java and perform a thorough experimental analysis of their running times. Plot their running times as a function of their input size as scatter plots. Choose representative values of the size n, and run at least 5 tests for each size value n in your tests
Thank you all in advance
Re: implementing into java [message #753878 is a reply to message #753811] |
Sat, 29 October 2011 16:29  |
This is not the place for asking help with homework questions. I would ask this on stackoverflow.com, just make sure to clearly mark your question with a homework label.
FUDForum. Page generated in 0.02881 seconds
