Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Log output
[Teneo] Log output [message #75352] |
Tue, 13 March 2007 18:07  |
Originally posted by: irbull.cs.uvic.ca
Martin,
I thought you presentation at EclipseCon was one of the best ones I saw
all week. I was really impressed with what you have done with EMF and
database persistence. I decided to download Teneo and give it a try.
I got Teneo from the EMFT update site and I got Hibernate from
hibernate.org. I think I have your library sample working, except I get
no log output. I remembered you had very verbose output in your
presentation. In fact, the only output I get is:
log4j:WARN No appenders could be found for logger
(org.eclipse.emf.teneo.hibernate.HbHelper).
log4j:WARN Please initialize the log4j system properly
I just looked at your presentation again, and I didn't see any reference
to a log4j initialization. I have added the log4j.jar file to my
project. Any other thoughts?
cheers,
ian
Re: [Teneo] Log output [message #75369 is a reply to message #75352] |
Tue, 13 March 2007 18:49   |
--------------060800050700040606040106
Hi Ian,
Thanks, always nice to get positive feedback!
You probably need to put a log4j.properties file somewhere. I attached one for you. It is not nicely
formatted or precise in its settings but it works for me. To get the most output all the levels
should be set at debug, to get the least output the best level is error.
It is always a bit trial of error to find the best location for this file. Normally the root of the
src tree is the best location (so just under src). You need to ensure that the build step copies
log4j.properties to the output directory (check the build properties in the plugin definitions).
gr. Martin
Ian Bull wrote:
> Martin,
> cheers,
> ian
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
name="log4j.properties"
Content-Disposition: inline;
filename="log4j.properties"
# Set root logger level to error and its only appender to A1.
log4j.rootCategory=error, A1
# A1 is set to be a ConsoleAppender.
log4j.appender.A1=org.apache.log4j.ConsoleAppender
# A1 uses PatternLayout.
log4j.appender.A1.layout=org.apache.log4j.PatternLayout
log4j.appender.A1.layout.ConversionPattern=%-4r [%t] %-5p %c %x - %m%n
#log4j.logger.org.hibernate=info
#org.hibernate.pretty
### log HQL query parser activity
log4j.logger.org.hibernate.hql.ast.AST=info
### log just the SQL
log4j.logger.org.hibernate.SQL=debug
### log JDBC bind parameters ###
log4j.logger.org.hibernate.type=info
#log4j.logger.org.hibernate.type=info
### log schema export/update ###
log4j.logger.org.hibernate.tool.hbm2ddl=info
### log HQL parse trees
log4j.logger.org.hibernate.hql=info
### log cache activity ###
log4j.logger.org.hibernate.cache=info
### log transaction activity
log4j.logger.org.hibernate.transaction=info
### log JDBC resource acquisition
log4j.logger.org.hibernate.jdbc=info
### enable the following line if you want to track down connection ###
### leakages when using DriverManagerConnectionProvider ###
log4j.logger.org.hibernate.connection.DriverManagerConnectio nProvider=info
--------------060800050700040606040106--
Re: [Teneo] Log output [message #75658 is a reply to message #75369] |
Wed, 14 March 2007 13:00  |
Thanks Martin,
Works like a charm!
cheers,
ian
Martin Taal wrote:
> Hi Ian,
> one for you. It is not nicely formatted or precise in its settings but
> it works for me. To get the most output all the levels should be set at
> file. Normally the root of the src tree is the best location (so just
> gr. Martin
> Ian Bull wrote:
>> Martin,
>> saw all week. I was really impressed with what you have done with EMF
>> and database persistence. I decided to download Teneo and give it a try.
>> get no log output. I remembered you had very verbose output in your
>> reference to a log4j initialization. I have added the log4j.jar file
>> to my project. Any other thoughts?
>> cheers,
>> ian
Re: [Teneo] Log output [message #603590 is a reply to message #75352] |
Hi Ian,
gr. Martin
Ian Bull wrote:
> Martin,
> cheers,
> ian
The Netherlands
Re: [Teneo] Log output [message #603659 is a reply to message #75369] |
Thanks Martin,
Works like a charm!
cheers,
ian
Martin Taal wrote:
> Hi Ian,
> gr. Martin
> Ian Bull wrote:
>> Martin,
>> cheers,
>> ian
Current Time: Wed Sep 03 20:02:35 EDT 2025
Powered by FUDForum. Page generated in 0.05000 seconds
