Home » Modeling » M2T (model-to-text transformation) » [acceleo 3.2] dependency problem with jar
[acceleo 3.2] dependency problem with jar [message #753561] |
Thu, 27 October 2011 13:12  |
Hi !
I'm using acceleo in a standalone env (I'm using a standalone acceleo compiler for building .emtl & I'm running my application outside of eclipse).
It was working great until very recently, and I don't know why. As I was using a nightly, I cleaned everything and installed acceleo 3.2 and use these jars in my application now.
But it looks like when a module B, located in my.jarB.jar is using module A, located in my.jarA.jar, there is a problem at runtime [previously, I had a problem during standalone compilation, now it's compiling fine, but not running]. I get these kind of error message:
org.eclipse.acceleo.engine.AcceleoEvaluationException: Unresolved compilation error in generation module.
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.switchExpression(AcceleoEvaluationVisitor.java:1671)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.visitExpression(AcceleoEvaluationVisitor.java:1009)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.visitAcceleoQueryInvocation(AcceleoEvaluationVisitor.java:836)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.switchExpression(AcceleoEvaluationVisitor.java:1721)
org.eclipse.acceleo.engine.AcceleoEvaluationException: Invalid result for expression if unresolved query invocation : null() then unresolved query invocation : null().replaceAll('^"', '').replaceAll('"$', '').tokenize(',') else Sequence {} endif->union(getUserIncludes(aType.eContainer(SomeRandomModelClassName))) at line 103 in Module common for query getUserIncludes(SomeOtherModelClassType). Last recorded value of self was SomeModelClassNameImpl@6a435f (name: Atom). Problem found while generating the file 'bla.hpp'.
In fact, the exact dep is 'B1 -> B2 -> A' with modules B1 & B2 in my.jarB.jar and A in my.jarA.jar.
The query that causes this error is in B2 (B1 only calls it):
[query public getUserIncludes(aPackage : SomeRandomModelClassName) : Sequence(String) =
if aPackage.hasAnnotation('cpp', 'include') then
'inc1.hpp,incl2.hpp'.tokenize(',')
else
Sequence{}
endif
[query public getUserIncludes(aType : SomeOtherModelClassType) : Sequence(String) =
(if aType.hasAnnotation('cpp', 'include') then
'incT.hpp'.replaceAll('^"', '').replaceAll('"$', '').tokenize(',')
else
Sequence{}
endif)->union(aType.eContainer(SomeRandomModelClassName).getUserIncludes())
B1 simply class the getUserIncludes(aType : SomeOtherModelClassType) query located in B2. Query "hasAnnotation" is located in module A. Commenting out this call removes all errors. [the tokenizing of the hardcoded strings are stupid and only here to simplify the test case]
I guess the unresolved query invocation : null() are not a good sign.
[Updated on: Thu, 27 October 2011 13:18] by Moderator
Re: [acceleo 3.2] dependency problem with jar [message #753566 is a reply to message #753561] |
Thu, 27 October 2011 14:00   |
Hi Marc
My observation is that the Acceleo 3.1 builder was very enthusiastic
rebuilding everything at the slightest excuse. This enthusiasm has been
'fixed' in 3.2, but now many necessary rebuilds do not occur and some
that do, are not displayed in problem markers or detected by a cannot
launch diagnostic, so you get to see the run-time consequence.
clean doesn't work reliably either.
The workaround seems to be to do dummy edits in MTL files so that you
see the markers. Saving them sometimes clears or reveals others.
Eventually you find your bugs and can execute.
Ed Willink
On 27/10/2011 18:12, Marc wrote:
> Hi !
> eclipse).
> at
> at
> at
> at
> at
> Sequence(String) = if aPackage.hasAnnotation('cpp', 'include') then
> else
> Sequence{}
> endif
> Sequence(String) = (if aType.hasAnnotation('cpp', 'include') then
> else
> Sequence{}
> query. Commenting out this call removes all errors.
Re: [acceleo 3.2] dependency problem with jar [message #753634 is a reply to message #753628] |
Fri, 28 October 2011 03:12   |
On 28/10/2011 07:53, Marc wrote:
> Quote:
>> been 'fixed' in 3.2, but now many necessary rebuilds do not occur and
>> some that do, are not displayed in problem markers or detected by a
>> cannot launch diagnostic, so you get to see the run-time consequence.
> I've seen this behavior quite often inside Eclipse. But here I'm using
> a standalone compiler, and of course I've tried to clean everything
> before launching the build. All templates get compiled, but at
> runtime, intermodule-jars dependencies seem broken.
> I think what you are describing is another issue...
I don't think so.
"unresolved compilation error" means that some reference in the EMTL
file is null, which is a problem that occurs at compile time, but which
is now sometimes not diagnosed till run-time.
It may be that your standalone compiler is failing to report an error
either because you or Acceleo has neglected to a deep search for
Resource.errors, which is important in order to get all proxy resolution
diagnostics. A good place to set a break point is on the
resourceSet.getEObject(proxyURI, false) in EcoreUtil.resolve(EObject
proxy, ResourceSet resourceSet) which is only invoked after
resourceSet.getEObject(proxyURI, true) has failed so it
a) gives you a unique place to look at what the problem URI is
b) a retry that you can single step through if you're still baffled.
Ed Willink
Current Time: Tue Jul 22 23:57:54 EDT 2025
Powered by FUDForum. Page generated in 0.05534 seconds
