Home » Eclipse Projects » EclipseLink » persisting a hashmap(problems with persisting a hashmap)
icon5.gif  persisting a hashmap [message #753524] Thu, 27 October 2011 11:08 Go to next message
I have problems persisting a simple Hashmap with eclipselink.
I try to generate tables from my entitys but the table generation chrashes with some exception. I wrote some simple classes, created persistence.xml with eclipese Dali tools, added class by class and creted the Tables from the Entitys . Everthing works fine until i add an entity containing hashmaps
To demonstrate my problem i wrote a small sample code.
Class Bar
package com.jpatest;
import javax.persistence.Id;
import javax.persistence.GeneratedValue;
import javax.persistence.Entity;
import org.eclipse.persistence.annotations.ReadOnly;
@Entity
public class Bar {
	@Id
	@GeneratedValue
	private int id;
	private String mystring;
	private int myint;
	public String getMystring() {
		return mystring;
	public void setMystring(String mystring) {
		this.mystring = mystring;
	public int getMyint() {
		return myint;
	public void setMyint(int myint) {
		this.myint = myint;
	public int getId() {
		return id;
	public void setId(int id) {
		this.id = id;
class Foo
import java.util.HashMap;
import javax.persistence.Inheritance;
import javax.persistence.MapKeyColumn;
import static javax.persistence.InheritanceType.JOINED;
import javax.persistence.OneToMany;
import static javax.persistence.FetchType.EAGER;
import javax.persistence.JoinColumn;
import javax.persistence.SequenceGenerator;
@Entity
public class Foo {
	@Id
	@GeneratedValue
	private int id;
	private int myint;
	@OneToMany(fetch = EAGER, targetEntity = com.jpatest.Bar.class)
	@MapKeyColumn(name="barid")
	private HashMap<String, Bar> mymap;
		return mystring;
		return myint;
		this.myint = myint;
	public HashMap<String, Bar> getMymap() {
		return mymap;
	public void setMymap(HashMap<String, Bar> mymap) {
		this.mymap = mymap;
		return id;
		this.id = id;
persistence.xml
	<persistence-unit name="jpatest" transaction-type="RESOURCE_LOCAL">
		<class>jpatest.User</class>
		<class>jpatest.Adress</class>
		<properties>
			<property name="javax.persistence.jdbc.url" value="jdbc:mysql://localhost:3306/jpatest"/>
			<property name="javax.persistence.jdbc.user" value="jpatest"/>
			<property name="javax.persistence.jdbc.password" value="########"/>
			<property name="javax.persistence.jdbc.driver" value="com.mysql.jdbc.Driver"/>
			<property name="eclipselink.ddl-generation.output-mode" value="both"/>
			<property name="eclipselink.ddl-generation" value="create-tables"/>
		</properties>
	</persistence-unit>
</persistence>
Exceptions
Runtime Exceptions:
javax.persistence.PersistenceException: Exception [EclipseLink-0] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.IntegrityException
Descriptor Exceptions:
Exception [EclipseLink-163] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.DescriptorException
Exception Description: This mapping's attribute class does not match the collection class.  [class java.util.Hashtable] cannot be assigned to [class java.util.HashMap].
Mapping: org.eclipse.persistence.mappings.ManyToManyMapping[mymap]
Descriptor: RelationalDescriptor(com.jpatest.Foo --> [DatabaseTable(FOO)])
Exception [EclipseLink-41] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.DescriptorException
Exception Description: A non-read-only mapping must be defined for the sequence number field.
Runtime Exceptions:
	at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:501)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.getDatabaseSession(EntityManagerFactoryDelegate.java:188)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.createEntityManagerImpl(EntityManagerFactoryDelegate.java:277)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:290)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:268)
	at org.eclipse.jpt.eclipselink.core.ddlgen.Main.perform(Main.java:86)
	at org.eclipse.jpt.eclipselink.core.ddlgen.Main.execute(Main.java:77)
	at org.eclipse.jpt.eclipselink.core.ddlgen.Main.main(Main.java:64)
Caused by: Exception [EclipseLink-0] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.IntegrityException
Any suggestions ? Please help Wink
Enviroment: Eclipse Indigo, Eclipselink 2.3.0, Mysql Server 5.5, Windows Xp or MacOs Lion
Re: persisting a hashmap [message #754046 is a reply to message #753524] Mon, 31 October 2011 11:15 Go to previous message
You should define the variable as Map not HashMap. JPA requires that you use the interface so that LAZY and other features work.
However, EclipseLink should allow HashMap if using EAGER, so please log a bug for this. You could probably use a DescriptorCustomizer and set the collection class in the mapping to HashMap.
Previous Topic:Cache Coordination issue
Next Topic:persisting a hashmap
Current Time: Sat Jul 26 06:18:07 EDT 2025
Powered by FUDForum. Page generated in 0.07346 seconds
