Home » Modeling » Graphiti » Know the Co-ordinates(Move Shape into another shape completely)
Know the Co-ordinates [message #753456] Thu, 27 October 2011 06:42 Go to next message
Hi ,
I have to restrict move of a shape into another shape , i have done the coding in the
canMoveShape method of my MoveFeature, but when the shape is completely inside another
shape then the validation fails.
Can someone tell me what's the best way to add such a restriction.
Mak
Re: Know the Co-ordinates [message #753476 is a reply to message #753456] Thu, 27 October 2011 08:32 Go to previous messageGo to next message
can you please show us the code of your canMoveShape method?
Re: Know the Co-ordinates [message #753673 is a reply to message #753476] Fri, 28 October 2011 05:56 Go to previous messageGo to next message
ContainerShape shapeToMove = (ContainerShape) context.getPictogramElement();
Object obj = getBusinessObjectForPictogramElement(shapeToMove);
if (obj instanceof A || obj instanceof B|| obj instanceof C) {
ContainerShape container = shapeToMove.getContainer();
int containerWidth = container.getGraphicsAlgorithm().getWidth();
int containerHeight = container.getGraphicsAlgorithm().getHeight();
int shapeWidth = shapeToMove.getGraphicsAlgorithm().getWidth();
int shapeHeight = shapeToMove.getGraphicsAlgorithm().getHeight();
int shapeX = context.getX();
int shapeY = context.getY();
EList<Shape> children = container.getChildren();
for (Shape node : children) {
if (node instanceof ContainerShape && node != shapeToMove) {
int nodeX = node.getGraphicsAlgorithm().getX();
int nodeY = node.getGraphicsAlgorithm().getY();
int nodeWitdth = node.getGraphicsAlgorithm().getWidth();
int nodeHeight = node.getGraphicsAlgorithm().getHeight();
if ((nodeY < shapeY && nodeY + nodeHeight > shapeY) || (nodeY > shapeY && shapeY + shapeHeight > nodeY)) {
if (shapeX > nodeX && shapeX < nodeX + nodeWitdth) {
System.out.println("FC == 1");
return false;
if (shapeX == nodeX) {
System.out.println("FC == 2");
return false;
if (shapeX < nodeX && shapeX + shapeWidth > nodeX) {
System.out.println("FC == 3");
return false;
} else if (nodeY == shapeY) {
if (nodeX < shapeX && nodeX + nodeWitdth > shapeX) {
System.out.println("FC == 4");
return false;
if (nodeX == shapeX || nodeX + nodeWitdth == shapeX + shapeWidth) {
System.out.println("FC ==5");
return false;
if (nodeX > shapeX && shapeX + shapeWidth < nodeX) {
System.out.println("FC == 6");
return false;
// move towards right
if ((shapeX + shapeWidth) > containerWidth) {
System.out.println("move Right");
return false;
// move towards left
if (shapeX < 0) {
System.out.println("move left");
return false;
// move towards bottom
if ((shapeY + shapeHeight) > containerHeight) {
System.out.println("bottom");
return false;
// move towards top;
if (shapeY < 30) {
System.out.println("top");
return false;
// if (shapeX + shapeWidth < GraphitiUtil.getCurrentGraphicalViewer().getDiagram().getChildren().get(0).getGraphicsAlgorithm().getWidth())
// shapeToMove.getGraphicsAlgorithm().get
// System.out.println("core");
// return false;
return true;
I have put system.out.print.. to knw the co-ordinates while i am holding(moving) the shape inside another shape completely.
Pls note : container is diagram , the above code checks generically if a shapeToMove can be moved to a new position taking into account all other diagram childern.
[Updated on: Fri, 28 October 2011 06:12] by Moderator
Re: Know the Co-ordinates [message #753676 is a reply to message #753673] Fri, 28 October 2011 06:06 Go to previous messageGo to next message
I think you should not use
but the
getTargetContainer()
from the context.
Andreas
Re: Know the Co-ordinates [message #753946 is a reply to message #753676] Mon, 31 October 2011 02:27 Go to previous message
Hi Andread,
Thanks for your reply. It was really useful, I din't notice that the
targetContainer
was available in the context.
I have adapted accordingly.
Solved Laughing
Move Shape into another shape completely, check using
context.getTargetContainer()
and you can return false where you do not want to allow.
You will have to restrict based on co-ordinates when moving within the same container(adding some padding etc..)
Mak
[Updated on: Mon, 31 October 2011 02:34] by Moderator
Previous Topic:Testing Graphiti Applications
Next Topic:Display workspace-located image
Current Time: Thu Jul 24 21:48:56 EDT 2025
Powered by FUDForum. Page generated in 0.25790 seconds
