Home » Eclipse Projects » Eclipse Scout » Remove unused translations ?
Remove unused translations ? [message #735391] Tue, 11 October 2011 12:48 Go to next message
After big modifications in my application, I have a lot of unused translations entries (most of it is garbage).
Is there a possibility to detect (and to remove) all unused Text translations defined in the I18N properties files (Texts_de.properties, Texts.properties, ...) ?
I am looking for some Scout SDK support (maybe in the nls editor ?) or for any other kind of scripts.
Re: Remove unused translations ? [message #735548 is a reply to message #735391] Wed, 12 October 2011 03:20 Go to previous messageGo to next message
Open the NLS Editor execute the 'Show NLS entry usage' context menu on
any entry. In the first column the number of references to a certain
entry is displayed.
Furthermore you are to find the usage in your code with the 'Find
references to 'aKey'' context menu.
/andreas
Re: Remove unused translations ? [message #753440 is a reply to message #735548] Thu, 27 October 2011 05:26 Go to previous messageGo to next message
No Message Body
Re: Remove unused translations ? [message #753441 is a reply to message #753440] Thu, 27 October 2011 05:28 Go to previous message
Thanks for your answer. Do you know if there is a possibility to have some kind of script?
If "entry usage" == 0
then remove the text entry.
This script could use the SDK or not...
Previous Topic:Security with JAAS
Next Topic:Javadoc / Eclipse help
Current Time: Sun Jul 27 03:41:01 EDT 2025
Powered by FUDForum. Page generated in 0.46340 seconds
