Home » Archived » XML Schema Definition (XSD) » XML and XSD models from string
XML and XSD models from string [message #75146] |
Mon, 04 August 2008 13:27  |
I have my XML and XSDs in DB columns (as strings/text fields).
What is the fastest and best way (regarding memory and performance) to
load the files to ecore models without storing them in a file?
thanks a lot,
André
Re: XML and XSD models from string [message #75268 is a reply to message #75251] |
Tue, 05 August 2008 12:17   |
André,
Comments below.
André Ribeiro wrote:
> Thanks Ed!
> im using the following lines now:
> XMLResource x = new XMLResourceImpl();
> x.load(new URIConverter.ReadableInputStream(cf.getFileContent()),
> null);
> i just dont get how can i then have (/create) an object (Eobject ?)
> that keeps my XML contents and has the model that it validates against?!
> To create the model i am trying to use the XSDEcoreBuilder like
> XSDEcoreBuilder xsdEcoreBuilder = new XSDEcoreBuilder();
> XSDSchema schema = XSDFactory.eINSTANCE.createXSDSchema();
> xsdEcoreBuilder.generate(schema);
> but since there isnt much (java)docs for these parts i dont know
> exactly what this is supposed to do.
I would suggest starting with the library tutorial and generating the
model for the schema you have. Also invoke Generate Test Code and look
at the generated XyzExample.java. This will give you a better starting
point that what you have now. For example, you'll see that it's
important generally to use a resource set and to register a resource
factory.
> My objective is to have an object Model (as the class in OOP) built
> from an XSD and the object (as the object in OOP) that is the XML file.
> Then i should be able to validate my object against my model.
> Is this possible?
Yes, but you're doing everything the hardest way possible. I'd suggest
reading
http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava
and following
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html
for your schema.
> Cheers,
> André
> Ed Merks wrote:
>> André,
>> XMLResource and XSDResourceImpl both support load from a SAX
>> InputSource. A more generic way is to create a resource and x and
>> call x.load(new URIConverter.ReadableInputStream(<xmlStringOrReader>,
>> null). The underlying implementations of XSDResourceImpl and
>> XMLResourceImpl will unwrap the InputStream and access the string or
>> reader directly, thereby avoiding the String -> bytes -> String cost.
>>> Hi,
>>> to load the files to ecore models without storing them in a file?
>>> thanks a lot,
>>> André
Re: XML and XSD models from string [message #75286 is a reply to message #75268] |
Tue, 05 August 2008 14:03  |
much thanks for the leads.
will read them carefully.
cheers,
André
Ed Merks wrote:
> André,
> Comments below.
>> Thanks Ed!
>> null);
> starting point that what you have now. For example, you'll see that
> it's important generally to use a resource set and to register a
> resource factory.
>> Is this possible?
> suggest reading
> and following
> for your schema.
>> Cheers,
>> André
>> Ed Merks wrote:
>>> André,
>>> call x.load(new
>>> URIConverter.ReadableInputStream(<xmlStringOrReader>, null). The
>>> underlying implementations of XSDResourceImpl and XMLResourceImpl
>>> will unwrap the InputStream and access the string or reader
>>>> Hi,
>>>> thanks a lot,
>>>> André
Re: XML and XSD models from string [message #603193 is a reply to message #75146] |
Mon, 04 August 2008 14:42  |
André,
InputSource. A more generic way is to create a resource and x and call
x.load(new URIConverter.ReadableInputStream(<xmlStringOrReader>, null).
The underlying implementations of XSDResourceImpl and XMLResourceImpl
will unwrap the InputStream and access the string or reader directly,
> thanks a lot,
> André
Re: XML and XSD models from string [message #603214 is a reply to message #75163] |
Tue, 05 August 2008 10:20  |
Thanks Ed!
x.load(new URIConverter.ReadableInputStream(cf.getFileContent()), null);
but since there isnt much (java)docs for these parts i dont know exactly
My objective is to have an object Model (as the class in OOP) built from
Is this possible?
André
Ed Merks wrote:
> André,
>> Hi,
>> thanks a lot,
>> André
Re: XML and XSD models from string [message #603219 is a reply to message #75251] |
André,
Comments below.
> Thanks Ed!
> null);
factory.
> Is this possible?
reading
and following
for your schema.
> Cheers,
> André
> Ed Merks wrote:
>> André,
>>> Hi,
>>> thanks a lot,
>>> André
Re: XML and XSD models from string [message #603224 is a reply to message #75268] |
cheers,
André
Ed Merks wrote:
> André,
> Comments below.
>> Thanks Ed!
>> null);
> resource factory.
>> Is this possible?
> suggest reading
> and following
> for your schema.
>> Cheers,
>> André
>> Ed Merks wrote:
>>> André,
>>> call x.load(new
>>>> Hi,
>>>> thanks a lot,
>>>> André
Current Time: Fri Jul 18 15:25:24 EDT 2025
Powered by FUDForum. Page generated in 0.07221 seconds
