Home » Language IDEs » PHP Development Tools (PDT) » Unable to define servers
Re: Unable to define servers [message #75178 is a reply to message #75160] |
Tue, 08 July 2008 04:20   |
Tried to, but still not working.
On error seems to be key binding conflict with WindowBuilder (which
should not be a big issue).
Further down I see classes missing- this is with the current 2.0 nightly
build. I'm a little clueless though which one is the root cause here?
!SESSION 2008-07-08 10:14:10.765
eclipse.buildId=I20080617-2000
java.version=1.6.0_10-beta
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.jface 2 0 2008-07-08 10:14:57.687
!MESSAGE Keybinding conflicts occurred. They may interfere with normal
accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2008-07-08 10:14:57.687
!MESSAGE A conflict occurred for ALT+SHIFT+D H:
Binding(ALT+SHIFT+D H,
ParameterizedCommand(Command(com.swtdesigner.gwt.launch.juni tGWTLaunchShortcut.debug,Debug GWT JUnit Test,
Category(org.eclipse.debug.ui.category.run,Run/Debug,Run/Deb ug command
category,true),
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
ParameterizedCommand(Command(org.eclipse.php.deubg.ui.phpexe Shortcut.debug,Debug PHP Script,
Debug PHP Script,
category,true),
,,true),null),
!MESSAGE A conflict occurred for ALT+SHIFT+X H:
Binding(ALT+SHIFT+X H,
ParameterizedCommand(Command(com.swtdesigner.gwt.launch.juni tGWTLaunchShortcut.run,Run GWT JUnit Test,
Run GWT JUnit Test,
category,true),
,,true),null),
ParameterizedCommand(Command(org.eclipse.php.deubg.ui.phpexe Shortcut.run,Run PHP Script,
Run PHP Script,
category,true),
,,true),null),
!ENTRY org.eclipse.osgi 4 0 2008-07-08 10:15:29.140
!MESSAGE An error occurred while automatically activating bundle
org.eclipse.php.core (393).
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.php.internal.core.PHPCorePlugin.start() of bundle
org.eclipse.php.core.
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1028)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:984)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:427)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:368)
at
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:33)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:441)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at
org.eclipse.php.internal.server.ui.PHPServersConfigurationBl ock.populateServerList(Unknown
Source)
at
org.eclipse.php.internal.server.ui.PHPServersConfigurationBl ock.initialize(Unknown
Source)
at
org.eclipse.php.internal.ui.preferences.AbstractConfiguratio nBlockPreferencePage.initialize(Unknown
Source)
at
org.eclipse.php.internal.ui.preferences.AbstractConfiguratio nBlockPreferencePage.createContents(Unknown
Source)
at
org.eclipse.jface.preference.PreferencePage.createControl(Pr eferencePage.java:235)
at
org.eclipse.php.internal.ui.preferences.AbstractConfiguratio nBlockPreferencePage.createControl(Unknown
Source)
at
org.eclipse.jface.preference.PreferenceDialog.createPageCont rol(PreferenceDialog.java:1466)
at
org.eclipse.jface.preference.PreferenceDialog$14.run(Prefere nceDialog.java:1223)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at
org.eclipse.jface.preference.PreferenceDialog.showPage(Prefe renceDialog.java:1217)
at
org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.sho wPage(FilteredPreferenceDialog.java:570)
at
org.eclipse.jface.preference.PreferenceDialog$10.run(Prefere nceDialog.java:700)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at
org.eclipse.jface.preference.PreferenceDialog$9.selectionCha nged(PreferenceDialog.java:696)
at
org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:842)
at
org.eclipse.jface.viewers.StructuredViewer.firePostSelection Changed(StructuredViewer.java:840)
at
org.eclipse.jface.viewers.StructuredViewer.handlePostSelect( StructuredViewer.java:1153)
at
org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected( StructuredViewer.java:1178)
at
org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(O penStrategy.java:250)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.ja va:244)
at org.eclipse.jface.util.OpenStrategy$3.run(OpenStrategy.java: 418)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at
org.eclipse.ui.internal.OpenPreferencesAction.run(OpenPrefer encesAction.java:65)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:583)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:500)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
Caused by: org.eclipse.core.internal.resources.ResourceException:
Resource '/ASOLoader' is not open.
at
org.eclipse.core.internal.resources.Project.checkAccessible( Project.java:116)
at
org.eclipse.core.internal.resources.Project.getDescription(P roject.java:357)
at org.eclipse.php.internal.core.PHPCorePlugin.convertProjects( Unknown
Source)
at org.eclipse.php.internal.core.PHPCorePlugin.start(Unknown Source)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:1009)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1003)
... 78 more
Root exception:
org.eclipse.core.internal.resources.ResourceException: Resource
at
at
Source)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
at
at
Source)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.jface 4 2 2008-07-08 10:15:29.187
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
java.lang.NoClassDefFoundError:
org/eclipse/php/internal/core/util/preferences/IXMLPreferenc esStorable
at
Source)
at
Source)
at
Source)
at
Source)
at
at
Source)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
at
at
at
at
at
at
at
at
... 63 more
Caused by: org.osgi.framework.BundleException: Exception in
at
at
at
at
at
at
... 73 more
at
at
Source)
at
at
... 78 more
Toshihiro wrote:
> You can investigate workspace/.metadata/.log file.
> See also
> http://dev.eclipse.org/newslists/news.eclipse.tools.pdt/msg0 1331.html
> [news.eclipse.tools.pdt] Re: Where is PDT's preferences file? - Regards
> Bug #204525
> Otherwise, try creating new workspace.
Re: Unable to define servers [message #75243 is a reply to message #75178] |
Tue, 08 July 2008 10:24  |
Fixed by removing all pdt preference files and installing today's
integration build- thanks!
Current Time: Sat Jul 26 23:22:30 EDT 2025
Powered by FUDForum. Page generated in 1.07762 seconds
