NullPointerException if I create a VisualClass [message #74804] |
Tue, 14 December 2004 05:47  |
If I create a VisualClass I always receive a NullPointerException.
in the .log is:
eclipse.buildId=I200409240800
java.version=1.4.2_05
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=de_DE
!ENTRY org.eclipse.osgi Dez 08, 2004 12:51:45.329
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTError: No more handles
at org.eclipse.swt.SWT.error(SWT.java:2717)
at org.eclipse.swt.SWT.error(SWT.java:2616)
at org.eclipse.swt.SWT.error(SWT.java:2587)
at org.eclipse.swt.widgets.Display.createDisplay(Display.java:7 16)
at org.eclipse.swt.widgets.Display.create(Display.java:701)
at org.eclipse.swt.graphics.Device.<init>(Device.java:113)
at org.eclipse.swt.widgets.Display.<init>(Display.java:409)
at org.eclipse.swt.widgets.Display.<init>(Display.java:405)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:295)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:156)
at org.eclipse.ui.internal.ide.IDEApplication.createDisplay(IDE Application.java:127)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:78)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Any help available (e.g. Plattform parameters for handles....)?
Greetings
Andreas
Re: NullPointerException if I create a VisualClass [message #74851 is a reply to message #74804] |
Tue, 14 December 2004 10:18   |
There has got to be more errors in the .log because this trace has
nothing to do with the VE. It is confusing because this trace indicates
it never even got to the point of bringing up an Eclipse workspace, let
alone start VE.
I also don't know what you mean by deinstalling gtk bindings. VE needs
to have gtk available. Does that mean it is not available?
Also on SUSE, there is a problem in the etc/.hosts file, it has
localhost defined twice, and this screws things up. Go to your
etc/.hosts file and make sure localhost is defined only on the 127.0.0.1
line, and is removed from the :::0 line.
FreeGroup wrote:
> in the .log is:
> !STACK 1
> at
Rich Kulp
the correct .log [message #75050 is a reply to message #75027] |
Tue, 14 December 2004 15:18   |
Annotation: If I create a runtime-workspace the VE works fine....
!ENTRY org.eclipse.jem.proxy 2 0 Dez 14, 2004 21:15:49.185
!MESSAGE
!STACK 0
IWAV0073I *** RemoteVM Exception - Trace from Remote VM:
java.lang.NoClassDefFoundError: org/eclipse/swt/internal/gtk/GdkEventMotion
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:141)
at org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:143)
at org.eclipse.jem.internal.proxy.vm.remote.ConnectionThread.ru n(ConnectionThread.java:47)
IWAV0074I *** Local StackTrace:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanProxyP roxy:
at
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.createThrowableBeanProxy(REMThrowableBeanTypeProxy.java: 34)
at
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.newBeanProxy(REMThrowableBeanTypeProxy.java:65)
at
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.getBeanProxy(REMStandardBeanProxyFactory.java:454)
at
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.processErrorReturn(REMStandardBeanProxyFactory.java:50 5)
at
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getClassReturn(REMStandardBeanTypeProxyFactory.jav a:313)
at
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.createBeanTypeProxy(REMStandardBeanTypeProxyFactor y.java:173)
at
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getBeanTypeProxy(REMStandardBeanTypeProxyFactory.j ava:290)
at
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getBeanTypeProxy(REMStandardBeanTypeProxyFactory.j ava:237)
at
org.eclipse.ve.internal.java.core.BeanProxyAdapter.primInsta ntiateBeanProxy(BeanProxyAdapter.java:857)
at
org.eclipse.ve.internal.java.core.BeanProxyAdapter.instantia teBeanProxy(BeanProxyAdapter.java:755)
at
org.eclipse.ve.internal.swt.FreeFormControlHostAdapter.add(F reeFormControlHostAdapter.java:77)
at org.eclipse.ve.internal.swt.ControlProxyAdapter.setTarget(Co ntrolProxyAdapter.java:330)
at
org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapte rList.didAdd(BasicNotifierImpl.java:71)
at org.eclipse.emf.common.util.BasicEList.addUnique(BasicEList. java:619)
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:5 99)
at
org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapte rList.add(BasicNotifierImpl.java:115)
at
org.eclipse.emf.common.notify.impl.AdapterFactoryImpl.associ ate(AdapterFactoryImpl.java:161)
at
org.eclipse.emf.common.notify.impl.AdapterFactoryImpl.adaptN ew(AdapterFactoryImpl.java:113)
at org.eclipse.emf.ecore.util.EcoreUtil.getRegisteredAdapter(Ec oreUtil.java:100)
at
org.eclipse.ve.internal.java.core.BeanProxyUtilities.getBean ProxyHost(BeanProxyUtilities.java:353)
at
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itSetting(CompositionProxyAdapter.java:156)
at
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itBeanProxy(CompositionProxyAdapter.java:119)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1488)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
!ENTRY org.eclipse.jem.proxy 2 0 Dez 14, 2004 21:15:49.483
!MESSAGE
+++ Warning +++: Tue Dec 14 21:15:49 CET 2004 Project (de.tif.jacob.designer)-VM for
de.tif.jacob.designer:err>java.lang.NoClassDefFoundError: org/eclipse/swt/internal/gtk/OS
!ENTRY org.eclipse.jem.proxy 2 0 Dez 14, 2004 21:15:49.484
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 Dez 14, 2004 21:15:49.486
!MESSAGE
de.tif.jacob.designer:err> at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 63)
!ENTRY org.eclipse.jem.proxy 2 0 Dez 14, 2004 21:15:49.487
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 Dez 14, 2004 21:15:49.488
!MESSAGE
de.tif.jacob.designer:err> at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 54)
!ENTRY org.eclipse.jem.proxy 2 0 Dez 14, 2004 21:15:49.489
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 Dez 14, 2004 21:15:49.490
!MESSAGE
de.tif.jacob.designer:err> at org.eclipse.swt.widgets.Display.<clinit>(Display.java:118)
!ENTRY org.eclipse.jem.proxy 2 0 Dez 14, 2004 21:15:49.491
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 Dez 14, 2004 21:15:49.492
!MESSAGE
org.eclipse.ve.internal.swt.targetvm.Environment$1.run(Envir onment.java:32)
!ENTRY org.eclipse.jem.proxy 2 0 Dez 14, 2004 21:15:49.493
!MESSAGE
!ENTRY org.eclipse.ve.java.core 4 0 Dez 14, 2004 21:15:49.495
!MESSAGE Exception thrown.
!STACK 0
at org.eclipse.jem.internal.proxy.swt.DisplayManager.syncExec(D isplayManager.java:453)
at
org.eclipse.jem.internal.proxy.swt.JavaStandardSWTBeanConsta nts.invokeSyncExec(JavaStandardSWTBeanConstants.java:135)
at org.eclipse.ve.internal.swt.WidgetProxyAdapter.invokeSyncExe c(WidgetProxyAdapter.java:65)
at
org.eclipse.ve.internal.swt.ControlProxyAdapter.basicInitial izationStringAllocation(ControlProxyAdapter.java:70)
at
org.eclipse.ve.internal.java.core.BeanProxyAdapter.primInsta ntiateBeanProxy(BeanProxyAdapter.java:861)
at
at
at
at
at
at
at
at
at
at
Re: the correct .log [message #75274 is a reply to message #75064] |
Fri, 17 December 2004 13:18  |
Rich Kulp wrote:
> For some reason you are missing the GdkEventMotion, whatever that is.
> There is something wrong with your installation. Since it works when you
> start from runtime-workspace that means there is something different
> between the two eclipse installations, or settings on them. Are you sure
> you have Eclipse SWT for GTK installed correctly. It appears to be
> missing the Eclipse GTK SWT fragments, or at least the code from them.
....after 3 days I dosen't continue with the VE.
I will layout my 2-3 Dialogs direkt with the API. :-(
It is not possible to run the VE in my Eclipse
greetings
Andreas
Re: NullPointerException if I create a VisualClass [message #603887 is a reply to message #74804] |
alone start VE.
FreeGroup wrote:
> in the .log is:
> !STACK 1
> at
Rich Kulp
Re: NullPointerException if I create a VisualClass [message #603896 is a reply to message #74851] |
Tue, 14 December 2004 10:21  |
Or is it hosts/.etc (? I forget which is it called).
Rich Kulp
Re: NullPointerException if I create a VisualClass [message #603908 is a reply to message #74851] |
Tue, 14 December 2004 14:52  |
> alone start VE.
I'm have clean up my workspace (I create a runtime-workspace for plugin
development) and in this workspace it runs fine.
I can address the wrong setting in my workspace (and I don't want delete them)
There is no more in the .log file!
Any help?
I have deinstalle the gtk-qt-engine which maps the gui from gnome gtk to the KDE
settings/font/gui elements....a gui bridge - I think.
see: https://bugs.eclipse.org/bugs/show_bug.cgi?id=77928
Thanks for the hint...I think I can comment out the line
Greetings
Andreas
the correct .log [message #603912 is a reply to message #75027] |
!MESSAGE
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: the correct .log [message #603917 is a reply to message #75050] |
Tue, 14 December 2004 17:10  |
> !MESSAGE
> !STACK 0
Rich Kulp
Re: the correct .log [message #603962 is a reply to message #75064] |
greetings
Andreas
FUDForum. Page generated in 0.49126 seconds
